Commit dc00384c authored by Shane Snyder's avatar Shane Snyder
Browse files
bug fix in counter macros: forgot '+'
parent 9801de53
...@@ -75,11 +75,11 @@ ...@@ -75,11 +75,11 @@
} while(0) } while(0)
#define DARSHAN_COUNTER_INC(__rec_p, __counter, __value) do{ \ #define DARSHAN_COUNTER_INC(__rec_p, __counter, __value) do{ \
(__rec_p)->counters[__counter] = __value; \ (__rec_p)->counters[__counter] += __value; \
#define DARSHAN_COUNTER_F_INC(__rec_p, __counter, __value) do{ \ #define DARSHAN_COUNTER_F_INC(__rec_p, __counter, __value) do{ \
(__rec_p)->fcounters[__counter] = __value; \ (__rec_p)->fcounters[__counter] += __value; \
#define DARSHAN_COUNTER_F_INC_NO_OVERLAP(__rec_p, __tm1, __tm2, __last, __counter) do{ \ #define DARSHAN_COUNTER_F_INC_NO_OVERLAP(__rec_p, __tm1, __tm2, __last, __counter) do{ \
...@@ -601,7 +601,7 @@ static void posix_runtime_initialize() ...@@ -601,7 +601,7 @@ static void posix_runtime_initialize()
.disable_instrumentation = &posix_disable_instrumentation, .disable_instrumentation = &posix_disable_instrumentation,
.prepare_for_reduction = &posix_prepare_for_reduction, .prepare_for_reduction = &posix_prepare_for_reduction,
.record_reduction_op = NULL,//&posix_record_reduction_op, .record_reduction_op = &posix_record_reduction_op,
.get_output_data = &posix_get_output_data, .get_output_data = &posix_get_output_data,
.shutdown = &posix_shutdown .shutdown = &posix_shutdown
Markdown is supported
0% or .
Please register or to comment
