Commit 987e299d authored by Misbah Mubarak's avatar Misbah Mubarak
Testing CODES multi-application functionality with time-stepped series data
parent 0b504d2c
...@@ -579,7 +579,6 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){ ...@@ -579,7 +579,6 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
p->local_delay = bytes_to_ns(p->chunk_size, p->local_bandwidth); p->local_delay = bytes_to_ns(p->chunk_size, p->local_bandwidth);
p->global_delay = bytes_to_ns(p->chunk_size, p->global_bandwidth); p->global_delay = bytes_to_ns(p->chunk_size, p->global_bandwidth);
p->credit_delay = bytes_to_ns(8.0, p->local_bandwidth); //assume 8 bytes packet p->credit_delay = bytes_to_ns(8.0, p->local_bandwidth); //assume 8 bytes packet
static void dragonfly_configure(){ static void dragonfly_configure(){
...@@ -772,7 +771,6 @@ terminal_init( terminal_state * s, ...@@ -772,7 +771,6 @@ terminal_init( terminal_state * s,
return; return;
/* sets up the router virtual channels, global channels, /* sets up the router virtual channels, global channels,
* local channels, compute node channels */ * local channels, compute node channels */
void router_setup(router_state * r, tw_lp * lp) void router_setup(router_state * r, tw_lp * lp)
...@@ -4,6 +4,7 @@ n is the number of input bgp-log files */ ...@@ -4,6 +4,7 @@ n is the number of input bgp-log files */
#include <stdlib.h> #include <stdlib.h>
#include <sys/stat.h> #include <sys/stat.h>
#include <mpi.h> #include <mpi.h>
#include <assert.h>
#define RADIX 16 #define RADIX 16
struct dfly_samples struct dfly_samples
...@@ -29,8 +30,17 @@ struct dfly_rtr_sample ...@@ -29,8 +30,17 @@ struct dfly_rtr_sample
long rev_events; long rev_events;
struct mpi_workload_sample
int nw_id;
unsigned long num_sends_sample;
unsigned long num_bytes_sample;
unsigned long num_waits_sample;
double sample_end_time;
static struct dfly_samples * event_array = NULL; static struct dfly_samples * event_array = NULL;
static struct dfly_rtr_sample * r_event_array = NULL; static struct dfly_rtr_sample * r_event_array = NULL;
static struct mpi_workload_sample * mpi_event_array = NULL;
int main( int argc, char** argv ) int main( int argc, char** argv )
...@@ -141,5 +151,31 @@ int main( int argc, char** argv ) ...@@ -141,5 +151,31 @@ int main( int argc, char** argv )
fclose(pFile); fclose(pFile);
fclose(writeRouterFile); fclose(writeRouterFile);
sprintf(buffer_rtr_read, "mpi-aggregate-logs-%d.bin", my_rank);
pFile = fopen(buffer_rtr_read, "r+");
assert(pFile);
struct stat st3;
stat(buffer_rtr_read, &st3);
long in_sz_mpi = st3.st_size;
mpi_event_array = malloc(in_sz_mpi);
int mpi_sample_sz = sizeof(struct mpi_workload_sample);
sprintf(buffer_rtr_write, "dragonfly-mpi-write-logs-%d", my_rank);
writeFile = fopen(buffer_rtr_write, "w+");
assert(writeFile);
fread(mpi_event_array, mpi_sample_sz, in_sz_mpi / mpi_sample_sz, pFile);
for(i = 0; i < in_sz_mpi / mpi_sample_sz; i++)
fprintf(writeFile, "\n %ld %ld %ld %lf ", mpi_event_array[i].num_sends_sample,
mpi_event_array[i].num_bytes_sample,
mpi_event_array[i].num_waits_sample,
mpi_event_array[i].sample_end_time);
fclose(pFile);
fclose(writeFile);
MPI_Finalize(); MPI_Finalize();
Markdown is supported
0%
or
Please register or to comment
