Commit 1ca00bc8 authored by Misbah Mubarak's avatar Misbah Mubarak
Adding new line characters in the meta files (required for vis purposes)
parent a642eb0b
...@@ -2017,11 +2017,11 @@ void dragonfly_rsample_fin(router_state * s, ...@@ -2017,11 +2017,11 @@ void dragonfly_rsample_fin(router_state * s,
sprintf(meta_fname, "dragonfly-router-sampling.meta"); sprintf(meta_fname, "dragonfly-router-sampling.meta");
FILE * fp = fopen(meta_fname, "w"); FILE * fp = fopen(meta_fname, "w");
fprintf(fp, "Router sample struct format: \n router_id (tw_lpid) \n busy time for each of the %d links (double) \n" fprintf(fp, "Router sample struct format: \nrouter_id (tw_lpid) \nbusy time for each of the %d links (double) \n"
"link traffic for each of the %d links (int64_t) \n sample end time (double) forward events per sample \n reverse events per sample ", "link traffic for each of the %d links (int64_t) \nsample end time (double) forward events per sample \nreverse events per sample ",
p->radix, p->radix); p->radix, p->radix);
fprintf(fp, "Ordering of links \n %d local (router-router same group) channels \n %d global (router-router remote group)" fprintf(fp, "\n\nOrdering of links \n%d local (router-router same group) channels \n%d global (router-router remote group)"
" channels \n %d terminal channels", p->radix/2, p->radix/4, p->radix/4); " channels \n%d terminal channels", p->radix/2, p->radix/4, p->radix/4);
fclose(fp); fclose(fp);
char rt_fn[MAX_NAME_LENGTH]; char rt_fn[MAX_NAME_LENGTH];
...@@ -2182,9 +2182,9 @@ void dragonfly_sample_fin(terminal_state * s, ...@@ -2182,9 +2182,9 @@ void dragonfly_sample_fin(terminal_state * s,
sprintf(meta_fname, "dragonfly-cn-sampling.meta"); sprintf(meta_fname, "dragonfly-cn-sampling.meta");
fprintf(fp, "Compute node sample format: terminal_id (tw_lpid) \t finished chunks (long) \t" fprintf(fp, "Compute node sample format\nterminal_id (tw_lpid) \nfinished chunks (long)"
"data size per sample (long) \t finished hops (double) \t time to finish chunks (double) \t " "\ndata size per sample (long) \nfinished hops (double) \ntime to finish chunks (double)"
"busy time (double)\t sample end time(double) \t forward events (long) \t reverse events (long)"); "\nbusy time (double)\nsample end time(double) \nforward events (long) \nreverse events (long)");
Markdown is supported
0%
or
Please register or to comment
