Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
Elsa Gonsiorowski
codes
Commits
fd5d8ad2
Commit
fd5d8ad2
authored
Nov 29, 2016
by
Matthieu Dorier
Browse files
corrected some issues related to non-matching sizes
parent
2a74260a
Changes
2
Hide whitespace changes
Inline
Side-by-side
src/network-workloads/model-net-mpi-replay.c
View file @
fd5d8ad2
@@ -643,10 +643,12 @@ static int rm_matching_send(nw_state * ns,
int
index
0
int
index
0
qlist_for_each
ent
ns
arrival_queue
qlist_for_each
ent
ns
arrival_queue
qi
qlist_entry
ent
mpi_msgs_queue
ql
qi
qlist_entry
ent
mpi_msgs_queue
ql
if
qi
num_bytes
qitem
num_bytes
if
//(qi->num_bytes == qitem->num_bytes) // it is not a requirement in MPI that the send and receive sizes match
qi
tag
qitem
tag
qitem
tag
1
qi
tag
qitem
tag
qitem
tag
1
qi
source_rank
qitem
source_rank
qitem
source_rank
1
qi
source_rank
qitem
source_rank
qitem
source_rank
1
qitem
num_bytes
qi
num_bytes
matched
1
matched
1
break
break
src/workload/methods/codes-dumpi-trace-nw-wrkld.c
View file @
fd5d8ad2
@@ -699,7 +699,7 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
callbacks
on_recv_init
dumpi_recv_init_call
handleDUMPIIgnore
callbacks
on_recv_init
handleDUMPIIgnore
callbacks
on_start
dumpi_start_call
handleDUMPIIgnore
callbacks
on_start
dumpi_start_call
handleDUMPIIgnore
callbacks
on_startall
dumpi_startall_call
handleDUMPIIgnore
callbacks
on_startall
dumpi_startall_call
handleDUMPIIgnore
callbacks
on_sendrecv
dumpi_sendrecv_call
handleDUMPI
Ignore
callbacks
on_sendrecv
dumpi_sendrecv_call
handleDUMPI
Sendrecv
callbacks
on_sendrecv_replace
dumpi_sendrecv_replace_call
handleDUMPIIgnore
callbacks
on_sendrecv_replace
handleDUMPIIgnore
callbacks
on_type_contiguous
dumpi_type_contiguous_call
handleDUMPIIgnore
callbacks
on_type_contiguous
handleDUMPIIgnore
callbacks
on_barrier
dumpi_barrier_call
handleDUMPIIgnore
callbacks
on_barrier
dumpi_barrier_call
handleDUMPIIgnore
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
