Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Milestones
Merge Requests
0
Merge Requests
0
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
Elsa Gonsiorowski
codes
Commits
f879c580
Commit
f879c580
authored
Mar 24, 2016
by
Misbah Mubarak
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
minor fixes to the instructions, turning off the debug mode for MPI Sim layer
parent
658dbc6c
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
14 additions
and
21 deletions
+14
-21
src/network-workloads/README_traces.txt
+11
-20
src/network-workloads/model-net-mpi-replay.c
+3
-1
No files found.
View file @
f879c580
@@ -23,21 +23,22 @@
@@ -23,21 +23,22 @@
http://portal.nersc.gov/project/CAL/designforward.htm
----------------- RUNNING CODES MPI SIMULATION LAYER -----------------------
6- Download and untar the DUMPI AMG application trace for
1728
MPI ranks using the following download link:
216
wget http://portal.nersc.gov/project/CAL/doe-miniapps-mpi-traces/AMG/df_AMG_n1728_dumpi.tar.gz
wget
http://portal.nersc.gov/project/CAL/doe-miniapps-mpi-traces/AMG/df_AMG_n216_dumpi.tar.gz
8- Configure model-net config file (For this example config file is available at
src/network-workloads/conf/modelnet-mpi-test-dfly-amg-
1728
.conf)
216
.conf)
9- Run the DUMPI trace replay simulation on top of model-net using:
(/dumpi-2014
-04-05.22.12.17.37
- is the prefix of the DUMPI trace file.
(/dumpi-2014
.03.03.14.55.23
We skip the last 4 digit prefix of the DUMPI trace files).
./src/network-workloads//model-net-mpi-replay --sync=1
--num_net_traces=
1728
--workload_file=/path/to/dumpi/trace/directory/dumpi-2014.03.03.15.09.03-
--num_net_traces=
216
--workload_type="dumpi" --lp-io-dir=amg-
1728
-trace --lp-io-use-suffix=1
216
-- ../src/network-workloads/conf/modelnet-mpi-test-dfly-amg-
1728
.conf
216
.conf
The simulation runs in ROSS serial, conservative and optimistic modes.
@@ -45,19 +46,9 @@ src/network-workloads/conf/modelnet-mpi-test-dfly-amg-1728.conf)
10- Running the simulation in optimistic mode
mpirun -np 4 ./src/network-workloads//model-net-mpi-replay
mpirun -np 4 ./src/network-workloads//model-net-mpi-replay --sync=3
--batch=32 --gvt-interval=128 --sync=3
--num_net_traces=216 --workload_type="dumpi" --lp-io-dir=amg_216-trace
--num_net_traces=13824 --workload_type=dumpi --lp-io-dir=amg_1728-trace
--workload_file=/projects/radix-io/mubarak/df_traces/directory/dumpi-2014.03.03.15.09.03-
-- src/network-workloads//conf/modelnet-mpi-test-dfly-amg-1728.conf
-- src/network-workloads//conf/modelnet-mpi-test-dfly-amg-216.conf
---------------- Running Test Program (needs update) --------------------------
11- Run the test program for codes-nw-workload using.
mpirun -np 4 ./src/models/mpi-trace-replay/model-net-dumpi-traces-dump --sync=3 --workload_type=dumpi --workload_file=/home/mubarm/df_traces/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- -- ../src/models/mpi-trace-replay/conf/modelnet-mpi-test.conf
The program shows the number of sends, receives, collectives and wait operations in the DUMPI trace log.
Note: If using a different DUMPI trace file, make sure to update the modelnet-mpi-test.conf file in the config directory.
View file @
f879c580
@@ -18,6 +18,7 @@
@@ -18,6 +18,7 @@
#define TRACK_LP -1
#define TRACK_LP -1
#define TRACE -1
#define TRACE -1
#define MAX_WAIT_REQS 512
#define DBG_MPI_SIM 0
char
workload_type
128
char
workload_type
128
char
workload_file
8192
char
workload_file
8192
@@ -1183,9 +1184,10 @@ void nw_test_finalize(nw_state* s, tw_lp* lp)
int
count_irecv
qlist_count
s
pending_recvs_queue
int
count_irecv
qlist_count
s
pending_recvs_queue
int
count_isend
qlist_count
s
arrival_queue
int
count_isend
qlist_count
s
arrival_queue
# if DBG_MPI_SIM == 1
printf
\n
LP %llu unmatched irecvs %d unmatched sends %d Total sends %ld receives %ld collectives %ld delays %ld wait alls %ld waits %ld send time %lf wait %lf"
printf
\n
lp
gid
count_irecv
count_isend
s
num_sends
s
num_recvs
s
num_cols
s
num_delays
s
num_waitall
s
num_wait
s
send_time
s
wait_time
lp
gid
count_irecv
count_isend
s
num_sends
s
num_recvs
s
num_cols
s
num_delays
s
num_waitall
s
num_wait
s
send_time
s
wait_time
# endif
written
sprintf
s
output_buf
written
\n
%llu %llu %ld %ld %ld %ld %lf %lf %lf"
lp
gid
s
nw_id
s
num_sends
s
num_recvs
s
num_bytes_sent
written
sprintf
s
output_buf
written
\n
lp
gid
s
nw_id
s
num_sends
s
num_recvs
s
num_bytes_sent
s
num_bytes_recvd
s
send_time
s
elapsed_time
s
compute_time
s
compute_time
s
num_bytes_recvd
s
send_time
s
elapsed_time
s
compute_time
s
compute_time
lp_io_write
lp
gid
"mpi-replay-stats"
written
s
output_buf
lp_io_write
lp
gid
"mpi-replay-stats"
written
s
output_buf
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
