Commit dddbe525 authored by Misbah Mubarak's avatar Misbah Mubarak
Updating dragonfly synthetic test and model to display number of packets generated
parent 50ff1ba2
...@@ -25,5 +25,5 @@ PARAMS ...@@ -25,5 +25,5 @@ PARAMS
global_bandwidth="4.7"; global_bandwidth="4.7";
cn_bandwidth="5.25"; cn_bandwidth="5.25";
message_size="512"; message_size="512";
routing="adaptive"; routing="nonminimal";
...@@ -430,48 +430,6 @@ static terminal_message_list* return_tail( ...@@ -430,48 +430,6 @@ static terminal_message_list* return_tail(
return tail; return tail;
static void copy_terminal_list_entry( terminal_message_list *cur_entry,
terminal_message *msg) {
terminal_message *cur_msg = &cur_entry->msg;
msg->travel_start_time = cur_msg->travel_start_time;
msg->packet_ID = cur_msg->packet_ID;
strcpy(msg->category, cur_msg->category);
msg->final_dest_gid = cur_msg->final_dest_gid;
msg->sender_lp = cur_msg->sender_lp;
msg->dest_terminal_id = cur_msg->dest_terminal_id;
msg->src_terminal_id = cur_msg->src_terminal_id;
msg->local_id = cur_msg->local_id;
msg->origin_router_id = cur_msg->origin_router_id;
msg->my_N_hop = cur_msg->my_N_hop;
msg->my_l_hop = cur_msg->my_l_hop;
msg->my_g_hop = cur_msg->my_g_hop;
msg->intm_lp_id = cur_msg->intm_lp_id;
msg->saved_channel = cur_msg->saved_channel;
msg->saved_vc = cur_msg->saved_vc;
msg->last_hop = cur_msg->last_hop;
msg->path_type = cur_msg->path_type;
msg->vc_index = cur_msg->vc_index;
msg->output_chan = cur_msg->output_chan;
msg->is_pull = cur_msg->is_pull;
msg->pull_size = cur_msg->pull_size;
msg->intm_group_id = cur_msg->intm_group_id;
msg->chunk_id = cur_msg->chunk_id;
msg->sender_mn_lp = cur_msg->sender_mn_lp;
msg->total_size = cur_msg->total_size;
msg->packet_size = cur_msg->packet_size;
msg->message_id = cur_msg->message_id;
msg->local_event_size_bytes = cur_msg->local_event_size_bytes;
msg->remote_event_size_bytes = cur_msg->remote_event_size_bytes;
msg->sender_node = cur_msg->sender_node;
msg->next_stop = cur_msg->next_stop;
msg->magic = cur_msg->magic;
if(msg->local_event_size_bytes + msg->remote_event_size_bytes > 0) {
void *m_data = model_net_method_get_edata(DRAGONFLY, msg);
memcpy(m_data, cur_entry->event_data,
msg->local_event_size_bytes + msg->remote_event_size_bytes);
static void dragonfly_read_config(const char * anno, dragonfly_param *params){ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
// shorthand // shorthand
dragonfly_param *p = params; dragonfly_param *p = params;
...@@ -616,7 +574,7 @@ static void dragonfly_report_stats() ...@@ -616,7 +574,7 @@ static void dragonfly_report_stats()
/* print statistics */ /* print statistics */
if(!g_tw_mynode) if(!g_tw_mynode)
printf(" Average number of hops traversed %f average chunk latency %lf us maximum chunk latency %lf us avg message size %lf bytes finished messages %ld \n", (float)avg_hops/total_finished_chunks, avg_time/(total_finished_chunks*1000), max_time/1000, (float)final_msg_sz/total_finished_msgs, total_finished_msgs); printf(" Average number of hops traversed %f average chunk latency %lf us maximum chunk latency %lf us avg message size %lf bytes finished messages %ld finished chunks %ld \n", (float)avg_hops/total_finished_chunks, avg_time/(total_finished_chunks*1000), max_time/1000, (float)final_msg_sz/total_finished_msgs, total_finished_msgs, total_finished_chunks);
if(routing == ADAPTIVE || routing == PROG_ADAPTIVE) if(routing == ADAPTIVE || routing == PROG_ADAPTIVE)
printf("\n ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally completed packets %lld ", total_minimal_packets, total_nonmin_packets, total_finished_chunks); printf("\n ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally completed packets %lld ", total_minimal_packets, total_nonmin_packets, total_finished_chunks);
...@@ -1042,8 +1000,6 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1042,8 +1000,6 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg,
void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
s->packet_gen--;
packet_gen--;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
int num_chunks = msg->packet_size/s->params->chunk_size; int num_chunks = msg->packet_size/s->params->chunk_size;
...@@ -1055,6 +1011,8 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1055,6 +1011,8 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
int i; int i;
for(i = 0; i < num_chunks; i++) { for(i = 0; i < num_chunks; i++) {
s->packet_gen--;
packet_gen--;
delete_terminal_message_list(return_tail(s->terminal_msgs, delete_terminal_message_list(return_tail(s->terminal_msgs,
s->terminal_msgs_tail, 0)); s->terminal_msgs_tail, 0));
s->terminal_length -= s->params->chunk_size; s->terminal_length -= s->params->chunk_size;
...@@ -1078,9 +1036,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1078,9 +1036,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg, void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg,
tw_lp * lp) { tw_lp * lp) {
s->packet_gen++;
packet_gen++;
tw_stime ts, nic_ts; tw_stime ts, nic_ts;
assert(lp->gid != msg->dest_terminal_id); assert(lp->gid != msg->dest_terminal_id);
...@@ -1111,6 +1067,8 @@ void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1111,6 +1067,8 @@ void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg,
for(i = 0; i < num_chunks; i++) for(i = 0; i < num_chunks; i++)
packet_gen++;
s->packet_gen++;
terminal_message_list *cur_chunk = (terminal_message_list*)malloc( terminal_message_list *cur_chunk = (terminal_message_list*)malloc(
sizeof(terminal_message_list)); sizeof(terminal_message_list));
msg->origin_router_id = s->router_id; msg->origin_router_id = s->router_id;
...@@ -1179,7 +1137,6 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1179,7 +1137,6 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(bf->c1) { if(bf->c1) {
s->in_send_loop = 1; s->in_send_loop = 1;
s->last_buf_full = msg->saved_busy_time; s->last_buf_full = msg->saved_busy_time;
return; return;
...@@ -1260,7 +1217,6 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1260,7 +1217,6 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
m->magic = router_magic_num; m->magic = router_magic_num;
m->path_type = -1; m->path_type = -1;
m->local_event_size_bytes = 0; m->local_event_size_bytes = 0;
m->local_id = s->terminal_id;
tw_event_send(e); tw_event_send(e);
int num_chunks = cur_entry->msg.packet_size/s->params->chunk_size; int num_chunks = cur_entry->msg.packet_size/s->params->chunk_size;
...@@ -1285,9 +1241,6 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1285,9 +1241,6 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
s->vc_occupancy[0] += s->params->chunk_size; s->vc_occupancy[0] += s->params->chunk_size;
cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0); cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0);
rc_stack_push(lp, cur_entry, free, s->st); rc_stack_push(lp, cur_entry, free, s->st);
//copy_terminal_list_entry(cur_entry, msg);
//delete_terminal_message_list(cur_entry);
cur_entry = s->terminal_msgs[0]; cur_entry = s->terminal_msgs[0];
...@@ -2369,7 +2322,6 @@ router_packet_receive( router_state * s, ...@@ -2369,7 +2322,6 @@ router_packet_receive( router_state * s,
next_stop = get_next_stop(s, bf, &(cur_chunk->msg), lp, cur_chunk->msg.path_type, dest_router_id, intm_id); next_stop = get_next_stop(s, bf, &(cur_chunk->msg), lp, cur_chunk->msg.path_type, dest_router_id, intm_id);
if(msg->remote_event_size_bytes > 0) { if(msg->remote_event_size_bytes > 0) {
void *m_data_src = model_net_method_get_edata(DRAGONFLY, msg); void *m_data_src = model_net_method_get_edata(DRAGONFLY, msg);
cur_chunk->event_data = (char*)malloc(msg->remote_event_size_bytes); cur_chunk->event_data = (char*)malloc(msg->remote_event_size_bytes);
...@@ -2517,13 +2469,9 @@ router_packet_send( router_state * s, ...@@ -2517,13 +2469,9 @@ router_packet_send( router_state * s,
if(cur_entry == NULL) { if(cur_entry == NULL) {
bf->c1 = 1; bf->c1 = 1;
s->in_send_loop[output_port] = 0; s->in_send_loop[output_port] = 0;
//printf("[%d] Router skipping send at begin %d \n", lp->gid, output_port);
return; return;
//if(msg->packet_ID == TRACK && msg->message_id == TRACK_MSG)
// printf("\n packet sending origin %ld to router %ld at output port %d ", cur_entry->msg.src_terminal_id, cur_entry->msg.next_stop, output_port);
int to_terminal = 1, global = 0; int to_terminal = 1, global = 0;
double delay = s->params->cn_delay; double delay = s->params->cn_delay;
...@@ -2540,6 +2488,8 @@ router_packet_send( router_state * s, ...@@ -2540,6 +2488,8 @@ router_packet_send( router_state * s,
int num_chunks = cur_entry->msg.packet_size / s->params->chunk_size; int num_chunks = cur_entry->msg.packet_size / s->params->chunk_size;
if(msg->packet_size % s->params->chunk_size) if(msg->packet_size % s->params->chunk_size)
num_chunks++; num_chunks++;
if(!num_chunks)
num_chunks = 1;
double bytetime; double bytetime;
if((cur_entry->msg.packet_size % s->params->chunk_size) && (cur_entry->msg.chunk_id == num_chunks - 1)) { if((cur_entry->msg.packet_size % s->params->chunk_size) && (cur_entry->msg.chunk_id == num_chunks - 1)) {
...@@ -2578,7 +2528,6 @@ router_packet_send( router_state * s, ...@@ -2578,7 +2528,6 @@ router_packet_send( router_state * s,
else else
m->last_hop = LOCAL; m->last_hop = LOCAL;
m->local_id = s->router_id;
m->intm_lp_id = lp->gid; m->intm_lp_id = lp->gid;
...@@ -2595,8 +2544,10 @@ router_packet_send( router_state * s, ...@@ -2595,8 +2544,10 @@ router_packet_send( router_state * s,
if(tw_now(lp) - s->cur_hist_start_time[output_port] >= WINDOW_LENGTH) { if(tw_now(lp) - s->cur_hist_start_time[output_port] >= WINDOW_LENGTH) {
bf->c2 = 1; bf->c2 = 1;
msg->saved_hist_start_time = s->cur_hist_start_time[output_port];
s->prev_hist_num[output_port] = s->cur_hist_num[output_port]; s->prev_hist_num[output_port] = s->cur_hist_num[output_port];
s->cur_hist_start_time[output_port] = tw_now(lp); s->cur_hist_start_time[output_port] = tw_now(lp);
msg->saved_hist_num = s->cur_hist_num[output_port];
s->cur_hist_num[output_port] = 1; s->cur_hist_num[output_port] = 1;
} else { } else {
s->cur_hist_num[output_port]++; s->cur_hist_num[output_port]++;
...@@ -2618,8 +2569,6 @@ router_packet_send( router_state * s, ...@@ -2618,8 +2569,6 @@ router_packet_send( router_state * s,
cur_entry = return_head(s->pending_msgs[output_port], cur_entry = return_head(s->pending_msgs[output_port],
s->pending_msgs_tail[output_port], output_chan); s->pending_msgs_tail[output_port], output_chan);
msg->saved_vc = output_port; msg->saved_vc = output_port;
msg->saved_channel = output_chan; msg->saved_channel = output_chan;
...@@ -31,14 +31,10 @@ ...@@ -31,14 +31,10 @@
#define LP_CONFIG_NM (model_net_lp_config_names[TORUS]) #define LP_CONFIG_NM (model_net_lp_config_names[TORUS])
#define LP_METHOD_NM (model_net_method_names[TORUS]) #define LP_METHOD_NM (model_net_method_names[TORUS])
#define STATIC 0
static double maxd(double a, double b) { return a < b ? b : a; } static double maxd(double a, double b) { return a < b ? b : a; }
enum routing_algo
STATIC=0,
ADAPTIVE
/* Torus network model implementation of codes, implements the modelnet API */ /* Torus network model implementation of codes, implements the modelnet API */
typedef struct nodes_message_list nodes_message_list; typedef struct nodes_message_list nodes_message_list;
Markdown is supported
0%
or
Please register or to comment
