Commit ddd6a5c1 authored by Matthieu Dorier's avatar Matthieu Dorier
Browse files
Merge branch 'master' of xgitlab.cels.anl.gov:codes/codes into cortex
parents 6a8d31e6 30c16180
## README for using ROSS instrumentation in CODES
For details about the ROSS instrumentation, see the [ROSS Instrumentation blog post](http://carothersc.github.io/ROSS/feature/instrumentation.html) on the ROSS webpage.
The instrumentation will be merged into the master branch of the ROSS repo very soon.
There are currently 3 types of instrumentation: GVT-based, real time, and event tracing. See the ROSS documentation for more info on
the specific options or use `--help` with your model. The GVT-based and real time sampling do not require any changes to your model code.
The event tracing will run without any changes, but some additions to the model code is needed in order to get specific model event types.
This document describes how to do it.
### Register LP event tracing function
The examples here are based on the server LP for the synthetic workload generation for dragonfly (`src/network-workloads/model-net-synthetic.c`).
As described in the ROSS Vis documentation, we need to first add our function that will save the event type (and any other desired data) to the
buffer location provided by ROSS.
```C
void svr_event_collect(svr_msg *m, tw_lp *lp, char *buffer)
int type = (int) m->svr_event_type;
memcpy(buffer, &type, sizeof(type));
Then we need to create a `st_trace_type` struct with the pointer and size information.
```C
st_trace_type svr_trace_types[] = {
{(rbev_trace_f) svr_event_collect,
sizeof(int),
(ev_trace_f) svr_event_collect,
sizeof(int)},
{0}
And a function to return this struct
```C
static const st_trace_type *svr_get_trace_types(void)
return(&svr_trace_types[0]);
As a reminder, there are two types of event tracing the full event trace (`ev_trace_f`) or only events that trigger rollbacks (`rbev_trace_f`).
It's set up so that you can have different functions for both types of event tracing, or you can use the same function for both.
Immediately after each function pointer is a `size_t` type that takes the amount of data that the function will be placing in the buffer,
so ROSS can appropriately handle things.
If you have multiple LPs, you can do a `st_trace_type` for each LP, or you can reuse. *Note*: You can only reuse `st_trace_type` and the event type collection
function for LPs that use the same type of message struct. For example, the dragonfly terminal and router LPs both use the `terminal_message` struct, so they can
use the same functions for event tracing. However the model net base LP uses the `model_net_wrap_msg` struct, so it gets its own event collection function and
`st_trace_type` struct, in order to read the event type correctly from the model.
`codes_mapping_init()` was changed to register the function pointers when it is setting up the LP types. So for CODES models, you need to add a register function:
```C
void svr_register_trace()
trace_type_register("server", svr_get_trace_types());
`trace_type_register(const char* name, const st_trace_type* type)` is part of the API and lets CODES know the pointers for LP initialization.
Now in the main function, you call the register function *before* calling `codes_mapping_setup()`.
```C
if (g_st_ev_trace)
svr_register_trace();
`g_st_ev_trace` is a ROSS flag for determining if event tracing is turned on.
That's all you need to add for each LP.
### Model Net LPs
In addition to the dragonfly synthetic server LP, I've already added in the necessary changes for both the model net base LP type and dragonfly (both router and terminal LPs),
so no other changes need to be made to those LPs. (Unless you want to collect some additional data.)
For any other network LPs that are based on the model net base LP type, there are a few additional details to know.
There are two fields added to the `model_net_method` struct for pointers to the trace registration functions for each LP.
```C
void (*mn_trace_register)(st_trace_type *base_type);
const st_trace_type* (*mn_get_trace_type)();
For example, right now, both the dragonfly router and terminal LPs use the same `st_trace_type dragonfly_trace_types` struct and the following function to return its pointer:
```C
static const st_trace_type *dragonfly_get_trace_types(void)
return(&dragonfly_trace_types[0]);
They have different register functions:
```C
static void dragonfly_register_trace(st_trace_type *base_type)
trace_type_register(LP_CONFIG_NM_TERM, base_type);
static void router_register_trace(st_trace_type *base_type)
trace_type_register(LP_CONFIG_NM_ROUT, base_type);
And then the following additions to their `model_net_method` structs:
```C
struct model_net_method dragonfly_method =
// the fields already in the struct
// event tracing additions
.mn_trace_register = dragonfly_register_trace,
.mn_get_trace_type = dragonfly_get_trace_types,
struct model_net_method dragonfly_router_method =
.mn_trace_register = router_register_trace,
Any other LPs built off of the model net LP, can be changed in the same way.
...@@ -21,6 +21,8 @@ const tw_lptype* lp_type_lookup(const char* name); ...@@ -21,6 +21,8 @@ const tw_lptype* lp_type_lookup(const char* name);
/* register an LP with CODES/ROSS */ /* register an LP with CODES/ROSS */
void lp_type_register(const char* name, const tw_lptype* type); void lp_type_register(const char* name, const tw_lptype* type);
void trace_type_register(const char* name, const st_trace_type* type);
const st_trace_type* trace_type_lookup(const char* name);
#ifdef __cplusplus #ifdef __cplusplus
#endif #endif
...@@ -63,6 +63,8 @@ struct model_net_method ...@@ -63,6 +63,8 @@ struct model_net_method
revent_f mn_sample_rc_fn; revent_f mn_sample_rc_fn;
init_f mn_sample_init_fn; init_f mn_sample_init_fn;
final_f mn_sample_fini_fn; final_f mn_sample_fini_fn;
extern struct model_net_method * method_array[]; extern struct model_net_method * method_array[];
...@@ -13,6 +13,9 @@ extern "C" { ...@@ -13,6 +13,9 @@ extern "C" {
#include <ross.h> #include <ross.h>
extern void dragonfly_register_evcol();
extern void router_register_evcol();
typedef struct terminal_message terminal_message; typedef struct terminal_message terminal_message;
/* this message is used for both dragonfly compute nodes and routers */ /* this message is used for both dragonfly compute nodes and routers */
...@@ -197,3 +197,5 @@ fi ...@@ -197,3 +197,5 @@ fi
AC_CONFIG_FILES([Makefile]) AC_CONFIG_FILES([Makefile])
AC_OUTPUT([maint/codes.pc]) AC_OUTPUT([maint/codes.pc])
AC_OUTPUT([src/network-workloads/conf/dragonfly-custom/modelnet-test-dragonfly-1728-nodes.conf])
LPGROUPS
MODELNET_GRP
repetitions="864";
# name of this lp changes according to the model
nw-lp="2";
# these lp names will be the same for dragonfly-custom model
modelnet_dragonfly_custom="2";
modelnet_dragonfly_custom_router="1";
PARAMS
# packet size in the network
packet_size="1024";
modelnet_order=( "dragonfly_custom","dragonfly_custom_router" );
# scheduler options
modelnet_scheduler="fcfs";
# chunk size in the network (when chunk size = packet size, packets will not be
# divided into chunks)
chunk_size="1024";
# modelnet_scheduler="round-robin";
# number of routers within each group
# this is dictated by the dragonfly configuration files
num_router_rows="6";
# number of router columns
num_router_cols="16";
# number of groups in the network
num_groups="9";
# buffer size in bytes for local virtual channels
local_vc_size="8192";
#buffer size in bytes for global virtual channels
global_vc_size="16384";
#buffer size in bytes for compute node virtual channels
cn_vc_size="8192";
#bandwidth in GiB/s for local channels
local_bandwidth="5.25";
# bandwidth in GiB/s for global channels
global_bandwidth="18.75";
# bandwidth in GiB/s for compute node-router channels
cn_bandwidth="16.0";
# ROSS message size
message_size="592";
# number of compute nodes connected to router, dictated by dragonfly config
# file
num_cns_per_router="2";
# number of global channels per router
num_global_channels="10";
# network config file for intra-group connections
intra-group-connections="@abs_srcdir@/intra-theta";
# network config file for inter-group connections
inter-group-connections="@abs_srcdir@/inter-theta";
# routing protocol to be used
routing="adaptive";
LPGROUPS
MODELNET_GRP
repetitions="768";
nw-lp="2";
PARAMS
packet_size="1024";
# scheduler options
chunk_size="1024";
# intra-group rows for routers
num_router_rows="16";
# intra-group columns for routers
num_router_cols="6";
num_groups="8";
cn_vc_size="8192";
cn_bandwidth="8.0";
# ROSS message size
message_size="592";
# file
intra-group-connections="@abs_srcdir@/intra-custom-small";
inter-group-connections="@abs_srcdir@/inter-custom-small";
routing="prog-adaptive";
LPGROUPS
MODELNET_GRP
repetitions="32"; # repetitions = Ne = total # of edge switches. For type0 Ne = Np*Ns = ceil(N/Ns*(k/2))*(k/2) = ceil(N/(k/2)^2)*(k/2)
nw-lp="4";
modelnet_fattree="4";
fattree_switch="3";
PARAMS
ft_type="0";
packet_size="512";
message_size="592";
chunk_size="512";
#modelnet_scheduler="round-robin";
modelnet_order=( "fattree" );
num_levels="3";
switch_count="32"; # = repititions
switch_radix="8";
router_delay="90";
terminal_radix="1";
soft_delay="1000";
vc_size="65536";
cn_vc_size="65536";
link_bandwidth="12.5";
cn_bandwidth="12.5";
routing="adaptive";
rail_routing="adaptive";
LPGROUPS
MODELNET_GRP
repetitions="50";
nw-lp="3";
modelnet_slimfly="3";
slimfly_router="1";
PARAMS
packet_size="256";
modelnet_order=( "slimfly" );
# scheduler options
chunk_size="256";
num_vcs="4";
num_routers="5";
num_terminals="3";
global_channels="5";
local_channels="2";
generator_set_X=("1","4"); # : Subgraph 0 generator set
generator_set_X_prime=("2","3"); # : Subgraph 1 generator set
local_vc_size="25600";
global_vc_size="25600";
cn_vc_size="25600";
local_bandwidth="9.0";
global_bandwidth="9.0";
cn_bandwidth="9.0";
router_delay="0";
link_delay="0";
message_size="592";
routing="minimal";
...@@ -10,7 +10,7 @@ LPGROUPS ...@@ -10,7 +10,7 @@ LPGROUPS
PARAMS PARAMS
packet_size="512"; packet_size="512";
message_size="560"; message_size="592";
modelnet_order=( "torus" ); modelnet_order=( "torus" );
# scheduler options # scheduler options
modelnet_scheduler="fcfs"; modelnet_scheduler="fcfs";
...@@ -604,8 +604,9 @@ static int rm_matching_rcv(nw_state * ns, ...@@ -604,8 +604,9 @@ static int rm_matching_rcv(nw_state * ns,
qlist_for_each(ent, &ns->pending_recvs_queue){ qlist_for_each(ent, &ns->pending_recvs_queue){
qi = qlist_entry(ent, mpi_msgs_queue, ql); qi = qlist_entry(ent, mpi_msgs_queue, ql);
if((qi->num_bytes == qitem->num_bytes) if(//(qi->num_bytes == qitem->num_bytes)
&& ((qi->tag == qitem->tag) || qi->tag == -1) //&&
&& ((qi->source_rank == qitem->source_rank) || qi->source_rank == -1)) && ((qi->source_rank == qitem->source_rank) || qi->source_rank == -1))
matched = 1; matched = 1;
...@@ -1443,9 +1444,11 @@ void nw_test_finalize(nw_state* s, tw_lp* lp) ...@@ -1443,9 +1444,11 @@ void nw_test_finalize(nw_state* s, tw_lp* lp)
int count_irecv = qlist_count(&s->pending_recvs_queue); int count_irecv = qlist_count(&s->pending_recvs_queue);
int count_isend = qlist_count(&s->arrival_queue); int count_isend = qlist_count(&s->arrival_queue);
if(count_irecv || count_isend) if(count_irecv || count_isend)
printf("\n LP %llu unmatched irecvs %d unmatched sends %d Total sends %ld receives %ld collectives %ld delays %ld wait alls %ld waits %ld send time %lf wait %lf", {
lp->gid, count_irecv, count_isend, s->num_sends, s->num_recvs, s->num_cols, s->num_delays, s->num_waitall, s->num_wait, s->send_time, s->wait_time); printf("\n LP %llu unmatched irecvs %d unmatched sends %d Total sends %ld receives %ld collectives %ld delays %ld wait alls %ld waits %ld send time %lf wait %lf",
tw_error(TW_LOC, "\n Unmatched send and receive, terminating simulation");
written += sprintf(s->output_buf + written, "\n %llu %llu %ld %ld %ld %ld %lf %lf %lf", lp->gid, s->nw_id, s->num_sends, s->num_recvs, s->num_bytes_sent, written += sprintf(s->output_buf + written, "\n %llu %llu %ld %ld %ld %ld %lf %lf %lf", lp->gid, s->nw_id, s->num_sends, s->num_recvs, s->num_bytes_sent,
s->num_bytes_recvd, s->send_time, s->elapsed_time - s->compute_time, s->compute_time); s->num_bytes_recvd, s->send_time, s->elapsed_time - s->compute_time, s->compute_time);
lp_io_write(lp->gid, "mpi-replay-stats", written, s->output_buf); lp_io_write(lp->gid, "mpi-replay-stats", written, s->output_buf);
...@@ -15,6 +15,7 @@ ...@@ -15,6 +15,7 @@
#include "codes/codes_mapping.h" #include "codes/codes_mapping.h"
#include "codes/configuration.h" #include "codes/configuration.h"
#include "codes/lp-type-lookup.h" #include "codes/lp-type-lookup.h"
#include "codes/net/dragonfly.h"
#define PAYLOAD_SZ 2048 #define PAYLOAD_SZ 2048
...@@ -105,6 +106,34 @@ tw_lptype svr_lp = { ...@@ -105,6 +106,34 @@ tw_lptype svr_lp = {
sizeof(svr_state), sizeof(svr_state),
/* setup for the ROSS event tracing
* can have a different function for rbev_trace_f and ev_trace_f
* but right now it is set to the same function for both
sizeof(int),
sizeof(int)},
{0}
const tw_optdef app_opt [] = const tw_optdef app_opt [] =
TWOPT_GROUP("Model net synthetic traffic " ), TWOPT_GROUP("Model net synthetic traffic " ),
...@@ -364,6 +393,9 @@ int main( ...@@ -364,6 +393,9 @@ int main(
model_net_register(); model_net_register();
svr_add_lp_type(); svr_add_lp_type();
if (g_st_ev_trace)
codes_mapping_setup(); codes_mapping_setup();
net_ids = model_net_configure(&num_nets); net_ids = model_net_configure(&num_nets);
...@@ -22,7 +22,7 @@ ...@@ -22,7 +22,7 @@
#define DUMP_CONNECTIONS 0 #define DUMP_CONNECTIONS 0
#define CREDIT_SIZE 8 #define CREDIT_SIZE 8
#define DFLY_HASH_TABLE_SIZE 5000 #define DFLY_HASH_TABLE_SIZE 4999
// debugging parameters // debugging parameters
#define TRACK -1 #define TRACK -1
...@@ -33,7 +33,7 @@ ...@@ -33,7 +33,7 @@
#define COLLECTIVE_COMPUTATION_DELAY 5700 #define COLLECTIVE_COMPUTATION_DELAY 5700
#define DRAGONFLY_FAN_OUT_DELAY 20.0 #define DRAGONFLY_FAN_OUT_DELAY 20.0
#define WINDOW_LENGTH 0 #define WINDOW_LENGTH 0
...@@ -3264,6 +3264,37 @@ tw_lptype dragonfly_lps[] = ...@@ -3264,6 +3264,37 @@ tw_lptype dragonfly_lps[] =
{NULL, NULL, NULL, NULL, NULL, NULL, NULL, 0}, {NULL, NULL, NULL, NULL, NULL, NULL, NULL, 0},
/* For ROSS event tracing */
void dragonfly_event_collect(terminal_message *m, tw_lp *lp, char *buffer)
int type = (int) m->type;
st_trace_type dragonfly_trace_types[] = {
{(rbev_trace_f) dragonfly_event_collect,
sizeof(int),
(ev_trace_f) dragonfly_event_collect,
sizeof(int)},
{0}
/*** END of ROSS event tracing additions */
/* returns the dragonfly lp type for lp registration */ /* returns the dragonfly lp type for lp registration */
static const tw_lptype* dragonfly_get_cn_lp_type(void) static const tw_lptype* dragonfly_get_cn_lp_type(void)
...@@ -3299,7 +3330,9 @@ struct model_net_method dragonfly_method = ...@@ -3299,7 +3330,9 @@ struct model_net_method dragonfly_method =
.mn_sample_fn = (void*)dragonfly_sample_fn, .mn_sample_fn = (void*)dragonfly_sample_fn,
.mn_sample_rc_fn = (void*)dragonfly_sample_rc_fn, .mn_sample_rc_fn = (void*)dragonfly_sample_rc_fn,
.mn_sample_init_fn = (void*)dragonfly_sample_init, .mn_sample_init_fn = (void*)dragonfly_sample_init,
.mn_sample_fini_fn = (void*)dragonfly_sample_fin .mn_sample_fini_fn = (void*)dragonfly_sample_fin,
struct model_net_method dragonfly_router_method = struct model_net_method dragonfly_router_method =
...@@ -3318,5 +3351,7 @@ struct model_net_method dragonfly_router_method = ...@@ -3318,5 +3351,7 @@ struct model_net_method dragonfly_router_method =
.mn_sample_fn = (void*)dragonfly_rsample_fn, .mn_sample_fn = (void*)dragonfly_rsample_fn,
.mn_sample_rc_fn = (void*)dragonfly_rsample_rc_fn, .mn_sample_rc_fn = (void*)dragonfly_rsample_rc_fn,
.mn_sample_init_fn = (void*)dragonfly_rsample_init, .mn_sample_init_fn = (void*)dragonfly_rsample_init,
.mn_sample_fini_fn = (void*)dragonfly_rsample_fin .mn_sample_fini_fn = (void*)dragonfly_rsample_fin,
Markdown is supported
0% or .
Please register or to comment
