Commit d3f773cf authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
adding dumpi and scalatrace nw workloads
note: delays in dumpi are now in nanoseconds rather than seconds
parent e9c89f8d
...@@ -50,6 +50,8 @@ endif ...@@ -50,6 +50,8 @@ endif
if USE_DUMPI if USE_DUMPI
AM_CPPFLAGS += ${DUMPI_CFLAGS} -DUSE_DUMPI=1 AM_CPPFLAGS += ${DUMPI_CFLAGS} -DUSE_DUMPI=1
src_libcodes_base_a_SOURCES += src/network-workload/codes-dumpi-trace-nw-wrkld.c src_libcodes_base_a_SOURCES += src/workload/methods/codes-dumpi-trace-nw-wrkld.c
tests_workload_codes_workload_test_LDADD += ${DUMPI_LIBS}
tests_workload_codes_workload_mpi_replay_LDADD += ${DUMPI_LIBS}
AM_LIBS += ${DUMPI_LIBS} AM_LIBS += ${DUMPI_LIBS}
endif endif
...@@ -20,6 +20,10 @@ typedef struct darshan_params darshan_params; ...@@ -20,6 +20,10 @@ typedef struct darshan_params darshan_params;
typedef struct recorder_params recorder_params; typedef struct recorder_params recorder_params;
typedef struct codes_workload_info codes_workload_info; typedef struct codes_workload_info codes_workload_info;
/* struct to hold the actual data from a single MPI event*/
typedef struct scala_trace_params scala_trace_params;
typedef struct dumpi_trace_params dumpi_trace_params;
struct bgp_params struct bgp_params
/* We have the number of ranks passed in from the bg/p model because /* We have the number of ranks passed in from the bg/p model because
...@@ -56,6 +60,17 @@ struct codes_workload_info ...@@ -56,6 +60,17 @@ struct codes_workload_info
int num_lrank; /* number of ranks participating in the collective operation*/ int num_lrank; /* number of ranks participating in the collective operation*/
struct scala_trace_params {
char offset_file_name[MAX_NAME_LENGTH_WKLD];
char nw_wrkld_file_name[MAX_NAME_LENGTH_WKLD];
struct dumpi_trace_params {
int num_net_traces;
char file_name[MAX_NAME_LENGTH_WKLD];
/* supported I/O operations */ /* supported I/O operations */
enum codes_workload_op_type enum codes_workload_op_type
...@@ -118,13 +118,13 @@ src_libcodes_base_a_SOURCES = \ ...@@ -118,13 +118,13 @@ src_libcodes_base_a_SOURCES = \
src/workload/codes-workload-method.h \ src/workload/codes-workload-method.h \
src/workload/methods/codes-bgp-io-wrkld.c \ src/workload/methods/codes-bgp-io-wrkld.c \
src/workload/methods/test-workload-method.c \ src/workload/methods/test-workload-method.c \
src/workload/methods/codes-scala-trace-nw-wrkld.c \
codes/rc-stack.h \ codes/rc-stack.h \
src/util/rc-stack.c src/util/rc-stack.c
#codes/codes-nw-workload.h #codes/codes-nw-workload.h
#src/network-workload/codes-nw-workload.c #src/network-workload/codes-nw-workload.c
#src/network-workload/codes-nw-workload-method.h #src/network-workload/codes-nw-workload-method.h
#src/network-workload/codes-scala-trace-nw-wrkld.c
# stealth testing of the template code (actual test is not run, just compiled as # stealth testing of the template code (actual test is not run, just compiled as
# a program - Make error signifies test failure) # a program - Make error signifies test failure)
...@@ -141,8 +141,19 @@ bin_PROGRAMS += src/workload/codes-workload-dump ...@@ -141,8 +141,19 @@ bin_PROGRAMS += src/workload/codes-workload-dump
src_workload_codes_workload_dump_SOURCES = \ src_workload_codes_workload_dump_SOURCES = \
src/workload/codes-workload-dump.c src/workload/codes-workload-dump.c
src_workload_codes_workload_dump_LDADD = $(testlib) ${DARSHAN_LIBS} ${ROSS_LIBS} src_workload_codes_workload_dump_LDADD = $(testlib) ${ROSS_LIBS}
src_workload_codes_workload_dump_LDFLAGS = ${DARSHAN_LDFLAGS} ${ROSS_LDFLAGS} src_workload_codes_workload_dump_LDFLAGS = ${ROSS_LDFLAGS}
if USE_DARSHAN
src_workload_codes_workload_dump_LDFLAGS += ${DARSHAN_LDFLAGS}
src_workload_codes_workload_dump_LDADD += ${DARSHAN_LIBS}
endif
# TODO: does recorder need any specific linker flags??
if USE_DUMPI
src_workload_codes_workload_dump_LDADD += ${DUMPI_LIBS}
endif
#bin_PROGRAMS += src/network-workload/codes-nw-test #bin_PROGRAMS += src/network-workload/codes-nw-test
...@@ -15,6 +15,10 @@ ...@@ -15,6 +15,10 @@
extern struct codes_workload_method test_workload_method; extern struct codes_workload_method test_workload_method;
extern struct codes_workload_method bgp_io_workload_method; extern struct codes_workload_method bgp_io_workload_method;
extern struct codes_workload_method scala_trace_workload_method;
#ifdef USE_DUMPI
extern struct codes_workload_method dumpi_trace_workload_method;
#endif
#ifdef USE_DARSHAN #ifdef USE_DARSHAN
extern struct codes_workload_method darshan_io_workload_method; extern struct codes_workload_method darshan_io_workload_method;
#endif #endif
...@@ -26,6 +30,10 @@ static struct codes_workload_method *method_array[] = ...@@ -26,6 +30,10 @@ static struct codes_workload_method *method_array[] =
&test_workload_method, &test_workload_method,
&bgp_io_workload_method, &bgp_io_workload_method,
&scala_trace_workload_method,
#ifdef USE_DUMPI
&dumpi_trace_workload_method,
#endif
&darshan_io_workload_method, &darshan_io_workload_method,
#endif #endif
This diff is collapsed.
* Copyright (C) 2013 University of Chicago.
* See COPYRIGHT notice in top-level directory.
#include <assert.h>
#include "ross.h"
#include "codes/codes-workload.h"
#include "src/workload/codes-workload-method.h"
int scala_trace_nw_workload_load(const char* params, int rank);
void scala_trace_nw_workload_get_next(int rank, struct codes_workload_op *op);
/* implements the codes workload method */
struct codes_workload_method scala_trace_workload_method =
.method_name = "scala-trace-workload",
.codes_workload_load = scala_trace_nw_workload_load,
.codes_workload_get_next = scala_trace_nw_workload_get_next,
struct st_write_data
char mpi_type[128];
int source_rank;
int dest_rank;
int data_type;
int count;
long time_stamp;
struct mpi_event_info
long offset;
long events_per_rank;
static struct st_write_data * event_array;
static struct mpi_event_info mpi_info;
static int current_counter = 0;
MPI_Datatype MPI_EVENTS_INFO;
MPI_Datatype MPI_WRITE_INFO;
MPI_Type_contiguous(2, MPI_LONG, &MPI_EVENTS_INFO);
MPI_Type_commit(&MPI_EVENTS_INFO);
MPI_Datatype data_type[6] = {MPI_CHAR, MPI_INT, MPI_INT, MPI_INT, MPI_INT, MPI_LONG};
int blocklen[6] = {128, 1, 1, 1, 1, 1};
MPI_Aint disp[6];
disp[0] = 0;
disp[1] = sizeof(char) * 128;
disp[2] = disp[1] + sizeof(int);
disp[3] = disp[2] + sizeof(int);
disp[4] = disp[3] + sizeof(int);
disp[5] = disp[4] + sizeof(int);
MPI_Type_create_struct(6, blocklen, disp, data_type, &MPI_WRITE_INFO);
MPI_Type_commit(&MPI_WRITE_INFO);
scala_trace_params* st_params = (scala_trace_params*)params;
char offset_file[MAX_NAME_LENGTH_WKLD];
char wrkld_file[MAX_NAME_LENGTH_WKLD];
strcpy(offset_file, st_params->offset_file_name);
strcpy(wrkld_file, st_params->nw_wrkld_file_name);
MPI_File fh;
MPI_File_open(MPI_COMM_WORLD, offset_file, MPI_MODE_RDONLY, MPI_INFO_NULL, &fh);
MPI_File_seek(fh, rank * sizeof(struct mpi_event_info), MPI_SEEK_SET);
MPI_File_read(fh, &mpi_info, 1, MPI_EVENTS_INFO, MPI_STATUS_IGNORE);
MPI_File_close(&fh);
event_array = (struct st_write_data*) malloc(sizeof(struct st_write_data) * mpi_info.events_per_rank);
//printf("\n rank %d allocated array of size %d ", rank, mpi_info.events_per_rank);
MPI_File_open(MPI_COMM_WORLD, wrkld_file, MPI_MODE_RDONLY, MPI_INFO_NULL, &fh);
MPI_File_set_view(fh, mpi_info.offset * sizeof(struct st_write_data), MPI_WRITE_INFO, MPI_WRITE_INFO, "derived", MPI_INFO_NULL);
MPI_File_read(fh, event_array, mpi_info.events_per_rank, MPI_WRITE_INFO, MPI_STATUS_IGNORE);
return 0;
assert(current_counter <= mpi_info.events_per_rank);
if(current_counter == mpi_info.events_per_rank)
op->op_type = CODES_WK_END;
return;
struct st_write_data temp_data = event_array[current_counter];
if(strcmp( temp_data.mpi_type, "Delay") == 0)
op->op_type = CODES_WK_DELAY;
op->u.delay.seconds = temp_data.time_stamp;
else if (strcmp( temp_data.mpi_type, "MPI_Isend") == 0)
op->op_type = CODES_WK_SEND;
op->u.send.source_rank = temp_data.source_rank;
op->u.send.dest_rank = temp_data.dest_rank;
//op->u.send.blocking = 0; /* non-blocking operation */
else if(strcmp( temp_data.mpi_type, "MPI_Irecv") == 0)
op->op_type = CODES_WK_RECV;
op->u.recv.source_rank = temp_data.source_rank;
op->u.recv.dest_rank = temp_data.dest_rank;
//op->u.recv.blocking = 0; /* non-blocking recv operation */
else if(strcmp( temp_data.mpi_type, "MPI_Send") == 0)
//op->u.send.blocking = 1; /* blocking send operation */
else if(strcmp( temp_data.mpi_type, "MPI_Recv") == 0)
//op->u.recv.blocking = 1; /* blocking recv operation */
/* increment current counter */
current_counter++;
Markdown is supported
0% or .
Please register or to comment
