Commit babae02f authored by mubarak's avatar mubarak
Browse files
updates to dragonfly code: some fixes in adaptive routing rollbacks
parent 255704ec
...@@ -53,7 +53,7 @@ static int num_vcs, num_routers, num_cn, num_global_channels, num_groups; ...@@ -53,7 +53,7 @@ static int num_vcs, num_routers, num_cn, num_global_channels, num_groups;
static int total_routers, adaptive_threshold = 10; static int total_routers, adaptive_threshold = 10;
/* minimal and non-minimal packet counts for adaptive routing*/ /* minimal and non-minimal packet counts for adaptive routing*/
int minimal_count, nonmin_count; int minimal_count=0, nonmin_count=0;
/* configurable parameters, global channel, local channel and /* configurable parameters, global channel, local channel and
* compute node bandwidth */ * compute node bandwidth */
...@@ -153,9 +153,9 @@ enum last_hop ...@@ -153,9 +153,9 @@ enum last_hop
* for detecting load on global channels are not very accurate */ * for detecting load on global channels are not very accurate */
enum ROUTING_ALGO enum ROUTING_ALGO
MINIMAL, MINIMAL = 0,
NON_MINIMAL, NON_MINIMAL,
ADAPTIVE ADAPTIVE
struct router_state struct router_state
...@@ -311,6 +311,7 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui ...@@ -311,6 +311,7 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui
terminal_message * msg; terminal_message * msg;
tw_lpid dest_nic_id; tw_lpid dest_nic_id;
char* tmp_ptr; char* tmp_ptr;
// printf("\n g_tw_lookahead default %f", g_tw_lookahead);
#if 0 #if 0
char lp_type_name[MAX_NAME_LENGTH], lp_group_name[MAX_NAME_LENGTH]; char lp_type_name[MAX_NAME_LENGTH], lp_group_name[MAX_NAME_LENGTH];
...@@ -323,7 +324,8 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui ...@@ -323,7 +324,8 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui
codes_mapping_get_lp_id(lp_group_name, LP_CONFIG_NM, mapping_rep_id, mapping_offset, &dest_nic_id); codes_mapping_get_lp_id(lp_group_name, LP_CONFIG_NM, mapping_rep_id, mapping_offset, &dest_nic_id);
xfer_to_nic_time = g_tw_lookahead + codes_local_latency(sender); /* Throws an error of found last KP time > current event time otherwise when LPs of one type are placed together*/ xfer_to_nic_time = g_tw_lookahead + codes_local_latency(sender); /* Throws an error of found last KP time > current event time otherwise when LPs of one type are placed together*/
//e_new = tw_event_new(local_nic_id, xfer_to_nic_time+offset, sender); //printf("\n transfer in time %f %f ", xfer_to_nic_time+offset, tw_now(sender));
//e_new = tw_event_new(sender->gid, xfer_to_nic_time+offset, sender);
//msg = tw_event_data(e_new); //msg = tw_event_data(e_new);
e_new = model_net_method_event_new(sender->gid, xfer_to_nic_time+offset, e_new = model_net_method_event_new(sender->gid, xfer_to_nic_time+offset,
sender, DRAGONFLY, (void**)&msg, (void**)&tmp_ptr); sender, DRAGONFLY, (void**)&msg, (void**)&tmp_ptr);
...@@ -429,7 +431,7 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -429,7 +431,7 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw
int output_port = msg->saved_vc / num_vcs; int output_port = msg->saved_vc / num_vcs;
msg->saved_available_time = s->next_credit_available_time[output_port]; msg->saved_available_time = s->next_credit_available_time[output_port];
s->next_credit_available_time[output_port] = max(tw_now(lp), s->next_credit_available_time[output_port]); s->next_credit_available_time[output_port] = max(tw_now(lp), s->next_credit_available_time[output_port]);
ts = credit_delay + tw_rand_exponential(lp->rng, (double)credit_delay/1000); ts = credit_delay + 0.1 + tw_rand_exponential(lp->rng, (double)credit_delay/1000);
s->next_credit_available_time[output_port]+=ts; s->next_credit_available_time[output_port]+=ts;
if (is_terminal){ if (is_terminal){
...@@ -576,7 +578,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * ...@@ -576,7 +578,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp *
void* local_event = void* local_event =
(char*)model_net_method_get_edata(DRAGONFLY, msg) + (char*)model_net_method_get_edata(DRAGONFLY, msg) +
msg->remote_event_size_bytes; msg->remote_event_size_bytes;
ts = (1/cn_bandwidth) * msg->local_event_size_bytes; ts = g_tw_lookahead + (1/cn_bandwidth) * msg->local_event_size_bytes;
e_new = tw_event_new(msg->sender_lp, ts, lp); e_new = tw_event_new(msg->sender_lp, ts, lp);
m_new = tw_event_data(e_new); m_new = tw_event_data(e_new);
memcpy(m_new, local_event, msg->local_event_size_bytes); memcpy(m_new, local_event, msg->local_event_size_bytes);
...@@ -639,7 +641,7 @@ if( msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1) ...@@ -639,7 +641,7 @@ if( msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1)
if(msg->remote_event_size_bytes) if(msg->remote_event_size_bytes)
void * tmp_ptr = model_net_method_get_edata(DRAGONFLY, msg); void * tmp_ptr = model_net_method_get_edata(DRAGONFLY, msg);
ts = (1/cn_bandwidth) * msg->remote_event_size_bytes; ts = g_tw_lookahead + 0.1 + (1/cn_bandwidth) * msg->remote_event_size_bytes;
if (msg->is_pull){ if (msg->is_pull){
int net_id = model_net_get_id(LP_METHOD_NM); int net_id = model_net_get_id(LP_METHOD_NM);
model_net_event(net_id, msg->category, msg->sender_lp, model_net_event(net_id, msg->category, msg->sender_lp,
...@@ -656,7 +658,7 @@ if( msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1) ...@@ -656,7 +658,7 @@ if( msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1)
int credit_delay = (1 / cn_bandwidth) * CREDIT_SIZE; int credit_delay = (1 / cn_bandwidth) * CREDIT_SIZE;
ts = credit_delay + tw_rand_exponential(lp->rng, credit_delay/1000); ts = credit_delay + 0.1 + tw_rand_exponential(lp->rng, credit_delay/1000);
msg->saved_credit_time = s->next_credit_available_time; msg->saved_credit_time = s->next_credit_available_time;
s->next_credit_available_time = max(s->next_credit_available_time, tw_now(lp)); s->next_credit_available_time = max(s->next_credit_available_time, tw_now(lp));
...@@ -1056,13 +1058,14 @@ get_next_stop(router_state * s, ...@@ -1056,13 +1058,14 @@ get_next_stop(router_state * s,
return dest_lp; return dest_lp;
/* Generate inter-mediate destination for non-minimal routing (selecting a random group) */ /* Generate inter-mediate destination for non-minimal routing (selecting a random group) */
if(msg->last_hop == TERMINAL && path == NON_MINIMAL) if(msg->last_hop == TERMINAL && msg->path_type == NON_MINIMAL)
if(dest_router_id / num_routers != s->group_id) if(dest_router_id / num_routers != s->group_id)
bf->c2 = 1; bf->c2 = 1;
int intm_grp_id = tw_rand_integer(lp->rng, 0, num_groups-1); int intm_grp_id = tw_rand_integer(lp->rng, 0, num_groups-1);
msg->intm_group_id = intm_grp_id; //int intm_grp_id = (s->group_id + s->group_id/2) % num_groups;
/* It means that the packet has arrived at the inter-mediate group for non-minimal routing. Reset the group now. */ /* It means that the packet has arrived at the inter-mediate group for non-minimal routing. Reset the group now. */
...@@ -1151,7 +1154,7 @@ router_packet_send( router_state * s, ...@@ -1151,7 +1154,7 @@ router_packet_send( router_state * s,
tw_bf * bf, tw_bf * bf,
terminal_message * msg, tw_lp * lp) terminal_message * msg, tw_lp * lp)
*(int *)bf = (int)0; // *(int *)bf = (int)0;
tw_stime ts; tw_stime ts;
tw_event *e; tw_event *e;
terminal_message *m; terminal_message *m;
...@@ -1160,10 +1163,10 @@ router_packet_send( router_state * s, ...@@ -1160,10 +1163,10 @@ router_packet_send( router_state * s,
float bandwidth = local_bandwidth; float bandwidth = local_bandwidth;
int path = routing; int path = routing;
int minimal_out_port = -1, nonmin_out_port = -1; int minimal_out_port = -1, nonmin_out_port = -1;
bf->c1 = 0; bf->c3 = 0;
bf->c4 = 0;
if(msg->last_hop == TERMINAL && routing == ADAPTIVE) if(msg->last_hop == TERMINAL && routing == ADAPTIVE)
// decide which routing to take // decide which routing to take
int minimal_next_stop=get_next_stop(s, bf, msg, lp, MINIMAL); int minimal_next_stop=get_next_stop(s, bf, msg, lp, MINIMAL);
minimal_out_port = get_output_port(s, bf, msg, lp, minimal_next_stop); minimal_out_port = get_output_port(s, bf, msg, lp, minimal_next_stop);
...@@ -1175,34 +1178,33 @@ router_packet_send( router_state * s, ...@@ -1175,34 +1178,33 @@ router_packet_send( router_state * s,
int min_vc = s->vc_occupancy[minimal_out_port * num_vcs + 1]; int min_vc = s->vc_occupancy[minimal_out_port * num_vcs + 1];
// Adaptive routing condition from the dragonfly paper Page 83 // Adaptive routing condition from the dragonfly paper Page 83
// modified according to booksim adaptive routing condition
if((min_vc <= (nonmin_vc * 2 + adaptive_threshold) && minimal_out_port == nonmin_out_port) if((min_vc <= (nonmin_vc * 2 + adaptive_threshold) && minimal_out_port == nonmin_out_port)
|| (min_port_count <= (nonmin_port_count * 2 + adaptive_threshold) && minimal_out_port != nonmin_out_port)) || (min_port_count <= (nonmin_port_count * 2 + adaptive_threshold) && minimal_out_port != nonmin_out_port))
msg->path_type = MINIMAL;
next_stop = minimal_next_stop; next_stop = minimal_next_stop;
output_port = minimal_out_port; output_port = minimal_out_port;
minimal_count++; minimal_count++;
msg->intm_group_id = -1; msg->intm_group_id = -1;
path = MINIMAL;
bf->c1 = 1;
if(msg->packet_ID == TRACK) if(msg->packet_ID == TRACK)
printf("\n (%lf) [Router %d] Packet %d routing minimally ", tw_now(lp), (int)lp->gid, (int)msg->packet_ID); printf("\n (%lf) [Router %d] Packet %d routing minimally ", tw_now(lp), (int)lp->gid, (int)msg->packet_ID);
else else
msg->path_type = NON_MINIMAL;
next_stop = nonmin_next_stop; next_stop = nonmin_next_stop;
output_port = nonmin_out_port; output_port = nonmin_out_port;
nonmin_count++; nonmin_count++;
path=NON_MINIMAL;
printf("\n (%lf) [Router %d] Packet %d routing non-minimally ", tw_now(lp), (int)lp->gid, (int)msg->packet_ID); printf("\n (%lf) [Router %d] Packet %d routing non-minimally ", tw_now(lp), (int)lp->gid, (int)msg->packet_ID);
bf->c4 = 1;
else else
msg->path_type = routing; /*defaults to the routing algorithm if we don't have adaptive routing here*/
next_stop = get_next_stop(s, bf, msg, lp, path); next_stop = get_next_stop(s, bf, msg, lp, path);
output_port = get_output_port(s, bf, msg, lp, next_stop); output_port = get_output_port(s, bf, msg, lp, next_stop);
...@@ -1256,7 +1258,7 @@ if( msg->packet_ID == TRACK && next_stop != msg->dest_terminal_id && msg->chunk_ ...@@ -1256,7 +1258,7 @@ if( msg->packet_ID == TRACK && next_stop != msg->dest_terminal_id && msg->chunk_
#endif #endif
// If source router doesn't have global channel and buffer space is available, then assign to appropriate intra-group virtual channel // If source router doesn't have global channel and buffer space is available, then assign to appropriate intra-group virtual channel
msg->saved_available_time = s->next_output_available_time[output_port]; msg->saved_available_time = s->next_output_available_time[output_port];
ts = g_tw_lookahead + ((1/bandwidth) * CHUNK_SIZE) + tw_rand_exponential(lp->rng, (double)CHUNK_SIZE/200); ts = g_tw_lookahead + 0.1 + ((1/bandwidth) * CHUNK_SIZE) + tw_rand_exponential(lp->rng, (double)CHUNK_SIZE/200);
s->next_output_available_time[output_port] = max(s->next_output_available_time[output_port], tw_now(lp)); s->next_output_available_time[output_port] = max(s->next_output_available_time[output_port], tw_now(lp));
s->next_output_available_time[output_port] += ts; s->next_output_available_time[output_port] += ts;
...@@ -1330,7 +1332,7 @@ router_packet_receive( router_state * s, ...@@ -1330,7 +1332,7 @@ router_packet_receive( router_state * s,
msg->my_N_hop++; msg->my_N_hop++;
ts = g_tw_lookahead + tw_rand_exponential(lp->rng, (double)MEAN_INTERVAL/200); ts = g_tw_lookahead + 0.1 + tw_rand_exponential(lp->rng, (double)MEAN_INTERVAL/200);
num_chunks = msg->packet_size/CHUNK_SIZE; num_chunks = msg->packet_size/CHUNK_SIZE;
if(msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1) if(msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1)
...@@ -1528,11 +1530,12 @@ void router_rc_event_handler(router_state * s, tw_bf * bf, terminal_message * ms ...@@ -1528,11 +1530,12 @@ void router_rc_event_handler(router_state * s, tw_bf * bf, terminal_message * ms
case R_SEND: case R_SEND:
if(bf->c2) if(msg->path_type == NON_MINIMAL && bf->c2)
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
if(bf->c1)
if(routing == ADAPTIVE && msg->path_type == MINIMAL)
minimal_count--; minimal_count--;
if(bf->c4) if(routing == ADAPTIVE && msg->path_type == NON_MINIMAL)
nonmin_count--; nonmin_count--;
if(bf->c3) if(bf->c3)
...@@ -1545,7 +1548,6 @@ void router_rc_event_handler(router_state * s, tw_bf * bf, terminal_message * ms ...@@ -1545,7 +1548,6 @@ void router_rc_event_handler(router_state * s, tw_bf * bf, terminal_message * ms
s->next_output_available_time[output_port] = msg->saved_available_time; s->next_output_available_time[output_port] = msg->saved_available_time;
s->vc_occupancy[output_chan]--; s->vc_occupancy[output_chan]--;
s->output_vc_state[output_chan]=VC_IDLE; s->output_vc_state[output_chan]=VC_IDLE;
break; break;
Markdown is supported
0% or .
Please register or to comment
