Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
Elsa Gonsiorowski
codes
Commits
9ef6da21
Commit
9ef6da21
authored
Jul 23, 2015
by
Jonathan Jenkins
Browse files
ugh, forgot to put in header...
parent
100a45c3
Changes
1
Show whitespace changes
Inline
Side-by-side
codes/codes-callback.h
0 → 100644
View file @
9ef6da21
* Copyright (C) 2015 University of Chicago.
* See COPYRIGHT notice in top-level directory.
#ifndef CODES_CALLBACK_H
#define CODES_CALLBACK_H
#include <assert.h>
#include "codes/lp-msg.h"
/* This header defines the following conventions for callback-based event
* processing (i.e., RPC-like event flow where the callee sends a "return
* event" to the caller)
* callers:
* - give the caller event size (for sanity checking)
* - use the msg_header convention (lp-msg.h)
* - specify an integer tag to identify which call the callee return event
* corresponds to, in the case of multiple pending callbacks
* - specify an offset to the return structure, which is defined by the callees
* callees:
* - use the resulting set of offsets to write and issue the callback
* The recommended calling convention for these types of event flows is:
* void event_func(<params...>, int tag, struct codes_cb_info const * cb);
struct
codes_cb_info
int
event_size
int
header_offset
int
tag_offset
int
cb_ret_offset
/* helper struct for callees - wrap up the typical inputs */
struct
codes_cb_params
struct
codes_cb_info
info
msg_header
h
int
tag
/* function-like sugar for initializing a codes_cb_info */
#define INIT_CODES_CB_INFO(_cb_info_ptr, _event_type, _header_field, _tag_field, _cb_ret_field) \
do { \
(_cb_info_ptr)->event_size = sizeof(_event_type); \
(_cb_info_ptr)->header_offset = offsetof(_event_type, _header_field); \
(_cb_info_ptr)->tag_offset = offsetof(_event_type, _tag_field); \
(_cb_info_ptr)->cb_ret_offset = offsetof(_event_type, _cb_ret_field); \
} while (0)
#define SANITY_CHECK_CB(_cb_info_ptr, _ret_type) \
do { \
int _total_size = sizeof(_ret_type) + sizeof(int) + sizeof(msg_header);\
int _esize = (_cb_info_ptr)->event_size; \
assert(_esize >= _total_size); \
assert(_esize >= (_cb_info_ptr)->header_offset + sizeof(msg_header)); \
assert(_esize >= (_cb_info_ptr)->tag_offset + sizeof(int)); \
assert(_esize >= (_cb_info_ptr)->cb_ret_offset + sizeof(_ret_type)); \
} while (0)
#endif
/* end of include guard: CODES_CALLBACK_H */
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* indent-tabs-mode: nil
* End:
* vim: ft=c ts=8 sts=4 sw=4 expandtab
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
