Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Milestones
Merge Requests
0
Merge Requests
0
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
Elsa Gonsiorowski
codes
Commits
81d907e5
Commit
81d907e5
authored
Jul 15, 2015
by
Jonathan Jenkins
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
use ross.pc + some misc cleanups
parent
7e9a5694
Changes
3
Hide whitespace changes
Inline
Side-by-side
Showing
3 changed files
with
17 additions
and
45 deletions
+17
-45
Makefile.am
Makefile.am
+3
-4
configure.ac
configure.ac
+5
-24
tests/Makefile.subdir
+9
-17
No files found.
Makefile.am
View file @
81d907e5
@@ -22,11 +22,11 @@ $(pkgconfig_DATA): config.status
EXTRA_DIST
prepare.sh COPYRIGHT configure.ac reformat.sh uc-codes.cfg
EXTRA_DIST
AM_CPPFLAGS
-I
$(top_srcdir)
/src
${ROSS_C
PP
FLAGS}
AM_CPPFLAGS
-I
$(top_srcdir)
/src
${ROSS_CFLAGS}
AM_CFLAGS
${ROSS_CFLAGS}
AM_CFLAGS
AM_L
IBS
${ROSS_LIB
S}
AM_L
DFLAGS
${ROSS_LDFLAG
S}
AM_CXXFLAGS
$(AM_CFLAGS)
AM_CXXFLAGS
$(AM_CFLAGS)
@@ -54,5 +54,4 @@ AM_CPPFLAGS += ${DUMPI_CFLAGS} -DUSE_DUMPI=1
src_libcodes_base_a_SOURCES
src/workload/methods/codes-dumpi-trace-nw-wrkld.c
tests_workload_codes_workload_test_LDADD
${DUMPI_LIBS}
${DUMPI_LIBS}
tests_workload_codes_workload_mpi_replay_LDADD
${DUMPI_LIBS}
${DUMPI_LIBS}
AM_LIBS
${DUMPI_LIBS}
endif
endif
configure.ac
View file @
81d907e5
@@ -27,6 +27,8 @@ AC_PROG_CXX
AC_PROG_CXXCPP
AC_PROG_CXXCPP
AC_PROG_RANLIB
AC_PROG_RANLIB
PKG_PROG_PKG_CONFIG
# Check for C99
# Check for C99
AC_PROG_CC_C99
AC_PROG_CC_C99
@@ -65,32 +67,11 @@ AC_MSG_CHECKING(whether the mpicc compiler works)
AC_TRY_COMPILE([#include <mpi.h>], [int ret = MPI_Init(0, (void*)0)],
AC_MSG_RESULT(yes),
AC_MSG_RESULT(yes),
AC_MSG_RESULT(no)
AC_MSG_RESULT(no)
AC_MSG_ERROR(CC doesn
t appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line.)
AC_MSG_ERROR(CC doesnt appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line.)
# get ROSS flags
PKG_CHECK_MODULES([ROSS], [ross], [],
AC_ARG_WITH([ross],[AS_HELP_STRING([--with-ross@<:@=DIR@:>@],
[AC_MSG_ERROR([Could not find working ross installation])])
[location of ROSS installation])])
if test "x${with_ross}" != "x" ; then
checkpath="${with_ross}/bin"
ROSS_CONFIG=""
AC_CHECK_PROGS(ROSS_CONFIG, [ross-config], [NOT_FOUND], [$checkpath])
if test "${ROSS_CONFIG}" = "NOT_FOUND" ; then
AC_MSG_ERROR(ROSS not found at: $with_ross)
fi
ROSS_LDFLAGS=`${with_ross}/bin/ross-config --ldflags`
ROSS_CFLAGS=`${with_ross}/bin/ross-config --cflags`
ROSS_CPPFLAGS=`${with_ross}/bin/ross-config --cflags`
ROSS_LIBS=`${with_ross}/bin/ross-config --libs`
AC_SUBST(ROSS_LDFLAGS)
AC_SUBST(ROSS_CFLAGS)
AC_SUBST(ROSS_CPPFLAGS)
AC_SUBST(ROSS_LIBS)
else
AC_MSG_ERROR([Could not find usable ROSS installation, try --with-ross=DIR])
fi
# check for Darshan
# check for Darshan
AC_ARG_WITH([darshan],[AS_HELP_STRING([--with-darshan@<:@=DIR@:>@],
View file @
81d907e5
@@ -28,34 +28,27 @@ EXTRA_DIST += tests/lp-io-test.sh \
tests/conf/mapping_test.conf
tests/expected/mapping_test.out
testlib
src/libcodes-base.a
testlib
src/libcodes-base.a
${ROSS_LIBS}
tests_lp_io_test_LDADD
$(testlib)
${ROSS_LIBS}
$(testlib)
tests_lp_io_test_LDFLAGS
${ROSS_LDFLAGS}
tests_lp_io_test_SOURCES
tests/lp-io-test.c
tests/lp-io-test.c
tests_mapping_test_LDADD
$(testlib)
${ROSS_LIBS}
$(testlib)
tests_mapping_test_LDFLAGS
${ROSS_LDFLAGS}
tests_mapping_test_SOURCES
tests/mapping_test.c
tests_resource_test_LDADD
$(testlib)
${ROSS_LIBS}
$(testlib)
tests_resource_test_LDFLAGS
${ROSS_LDFLAGS}
tests_resource_test_SOURCES
tests/resource-test.c
tests_lsm_test_LDADD
$(testlib)
${ROSS_LIBS}
$(testlib)
tests_lsm_test_LDFLAGS
${ROSS_LDFLAGS}
tests_lsm_test_SOURCES
tests/local-storage-model-test.c
tests_rc_stack_test_LDADD
$(testlib)
${ROSS_LIBS}
$(testlib)
tests_rc_stack_test_LDFLAGS
${ROSS_LDFLAGS}
tests_rc_stack_test_SOURCES
tests/rc-stack-test.c
tests_jobmap_test_LDADD
$(testlib)
${ROSS_LIBS}
$(testlib)
tests_jobmap_test_LDFLAGS
${ROSS_LDFLAGS}
tests_jobmap_test_SOURCES
tests/jobmap-test.c
tests/jobmap-test.c
$(testlib)
${ROSS_LIBS}
$(testlib)
tests_workload_codes_workload_test_LDFLAGS
${ROSS_LDFLAGS}
tests_workload_codes_workload_test_SOURCES
tests/workload/codes-workload-test.c
tests/workload/codes-workload-test-svr-lp.c
@@ -63,6 +56,5 @@ tests_workload_codes_workload_test_SOURCES = \
tests/workload/codes-workload-test-cn-lp.c
tests/workload/codes-workload-test-cn-lp.h
$(testlib)
${ROSS_LIBS}
$(testlib)
tests_workload_codes_workload_mpi_replay_LDFLAGS
${ROSS_LDFLAGS}
tests_workload_codes_workload_mpi_replay_SOURCES
tests/workload/codes-workload-mpi-replay.c
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
