Commit 7307d543 authored by Misbah Mubarak's avatar Misbah Mubarak
Few minor fixes to dragonfly
parent 251952eb
...@@ -25,5 +25,5 @@ PARAMS ...@@ -25,5 +25,5 @@ PARAMS
global_bandwidth="4.7"; global_bandwidth="4.7";
cn_bandwidth="5.25"; cn_bandwidth="5.25";
message_size="552"; message_size="552";
routing="minimal"; routing="adaptive";
...@@ -975,6 +975,8 @@ void nw_test_init(nw_state* s, tw_lp* lp) ...@@ -975,6 +975,8 @@ void nw_test_init(nw_state* s, tw_lp* lp)
codes_issue_next_event(lp); codes_issue_next_event(lp);
s->num_bytes_sent = 0; s->num_bytes_sent = 0;
s->num_bytes_recvd = 0; s->num_bytes_recvd = 0;
s->compute_time = 0;
s->elapsed_time = 0;
return; return;
...@@ -1318,9 +1318,9 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1318,9 +1318,9 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
if(hash_link) if(hash_link)
printf("\n Num chunks %d ", tmp->num_chunks); printf("\n Num chunks %d ", tmp->num_chunks);
//assert(!hash_link); //assert(!hash_link);
N_finished_msgs--;
s->finished_msgs--; s->finished_msgs--;
total_msg_sz -= msg->total_size; total_msg_sz -= msg->total_size;
N_finished_msgs--;
s->total_msg_size -= msg->total_size; s->total_msg_size -= msg->total_size;
struct dfly_qhash_entry * d_entry_pop = rc_stack_pop(s->st); struct dfly_qhash_entry * d_entry_pop = rc_stack_pop(s->st);
...@@ -1373,9 +1373,37 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1373,9 +1373,37 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
// NIC aggregation - should this be a separate function? // NIC aggregation - should this be a separate function?
// Trigger an event on receiving server // Trigger an event on receiving server
struct dfly_hash_key key;
key.message_id = msg->message_id;
key.sender_id = msg->sender_lp;
struct qhash_head *hash_link = NULL;
struct dfly_qhash_entry * tmp = NULL;
hash_link = qhash_search(s->rank_tbl, &key);
if(hash_link)
tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link);
int total_chunks = msg->total_size / s->params->chunk_size;
if(msg->total_size % s->params->chunk_size)
total_chunks++;
if(!total_chunks)
total_chunks = 1;
if(tmp)
if(tmp->num_chunks >= total_chunks)
tw_output(lp, "\n invalid number of chunks %d for LP %ld ", tmp->num_chunks, lp->gid);
tw_lp_suspend(lp, 0, 0);
return;
assert(lp->gid == msg->dest_terminal_id); assert(lp->gid == msg->dest_terminal_id);
// if(lp->gid == TRACK)
if(msg->packet_ID == TRACK_PKT) if(msg->packet_ID == TRACK_PKT)
printf("\n Packet %ld arrived at lp %ld hops %d", msg->packet_ID, lp->gid, msg->my_N_hop); printf("\n Packet %ld arrived at lp %ld hops %d", msg->packet_ID, lp->gid, msg->my_N_hop);
...@@ -1404,14 +1432,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1404,14 +1432,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
assert(lp->gid != msg->src_terminal_id); assert(lp->gid != msg->src_terminal_id);
int num_chunks = msg->packet_size / s->params->chunk_size; int num_chunks = msg->packet_size / s->params->chunk_size;
total_chunks++;
if(!total_chunks)
total_chunks = 1;
if (msg->packet_size % s->params->chunk_size) if (msg->packet_size % s->params->chunk_size)
num_chunks++; num_chunks++;
...@@ -1463,17 +1483,9 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1463,17 +1483,9 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
/* Now retreieve the number of chunks completed from the hash and update /* Now retreieve the number of chunks completed from the hash and update
* them */ * them */
void *m_data_src = model_net_method_get_edata(DRAGONFLY, msg); void *m_data_src = model_net_method_get_edata(DRAGONFLY, msg);
/* If an entry does not exist then create one */ /* If an entry does not exist then create one */
if(!hash_link) if(!tmp)
bf->c5 = 1; bf->c5 = 1;
struct dfly_qhash_entry * d_entry = malloc(sizeof (struct dfly_qhash_entry)); struct dfly_qhash_entry * d_entry = malloc(sizeof (struct dfly_qhash_entry));
...@@ -1484,8 +1496,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1484,8 +1496,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
qhash_add(s->rank_tbl, &key, &(d_entry->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry->hash_link));
s->rank_tbl_pop++; s->rank_tbl_pop++;
hash_link = qhash_search(s->rank_tbl, &key); hash_link = &(d_entry->hash_link);
tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link); tmp = d_entry;
assert(tmp); assert(tmp);
...@@ -1529,7 +1541,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1529,7 +1541,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
s->total_msg_size += msg->total_size; s->total_msg_size += msg->total_size;
s->finished_msgs++; s->finished_msgs++;
assert(tmp->remote_event_data && tmp->remote_event_size); assert(tmp->remote_event_data && tmp->remote_event_size > 0);
send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size); send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size);
/* Remove the hash entry */ /* Remove the hash entry */
qhash_del(hash_link); qhash_del(hash_link);
...@@ -2213,8 +2225,8 @@ static int do_adaptive_routing( router_state * s, ...@@ -2213,8 +2225,8 @@ static int do_adaptive_routing( router_state * s,
+ s->queued_count[minimal_out_port]; + s->queued_count[minimal_out_port];
// Now get the expected number of hops to be traversed for both routes // Now get the expected number of hops to be traversed for both routes
int num_min_hops = get_num_hops(s->router_id, dest_router_id, //int num_min_hops = get_num_hops(s->router_id, dest_router_id,
s->params->num_routers, 0, s->params->num_groups); // s->params->num_routers, 0, s->params->num_groups);
int intm_router_id = getRouterFromGroupID(msg->intm_group_id, int intm_router_id = getRouterFromGroupID(msg->intm_group_id,
s->router_id / s->params->num_routers, s->params->num_routers, s->router_id / s->params->num_routers, s->params->num_routers,
Markdown is supported
0%
or
Please register or to comment
