Commit 6738d205 authored by Philip Carns's avatar Philip Carns
stub for p2p bandwidth test model
- just a slightly modified copy of normal modelnet test for now; will
  update to use as the primary test harness for loggp validation
parent 2f527704
check_PROGRAMS += tests/modelnet-test check_PROGRAMS += tests/modelnet-test tests/modelnet-p2p-bw
TESTS += tests/modelnet-test.sh \ TESTS += tests/modelnet-test.sh \
tests/modelnet-test-torus.sh \ tests/modelnet-test-torus.sh \
...@@ -15,3 +15,7 @@ testlib = src/libcodes-net.a ...@@ -15,3 +15,7 @@ testlib = src/libcodes-net.a
tests_modelnet_test_LDADD = $(testlib) ${CODES_BASE_LIBS} tests_modelnet_test_LDADD = $(testlib) ${CODES_BASE_LIBS}
tests_modelnet_test_CFLAGS = ${CODES_BASE_CFLAGS} tests_modelnet_test_CFLAGS = ${CODES_BASE_CFLAGS}
tests_modelnet_test_SOURCES = tests/modelnet-test.c tests_modelnet_test_SOURCES = tests/modelnet-test.c
tests_modelnet_p2p_bw_LDADD = $(testlib) ${CODES_BASE_LIBS}
tests_modelnet_p2p_bw_CFLAGS = ${CODES_BASE_CFLAGS}
tests_modelnet_p2p_bw_SOURCES = tests/modelnet-p2p-bw.c
This diff is collapsed.
Markdown is supported
0%
or
Please register or to comment
