Commit 5574637a authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Merging packet generate and send functions in dragonfly
parent 730a18c7
...@@ -358,10 +358,10 @@ static void dragonfly_report_stats() ...@@ -358,10 +358,10 @@ static void dragonfly_report_stats()
/* print statistics */ /* print statistics */
if(!g_tw_mynode) if(!g_tw_mynode)
printf("\n total finished packets %d ", total_finished_packets); printf("\n total finished packets %d ", total_finished_packets);
printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us \n", (float)avg_hops/total_finished_packets, avg_time/(total_finished_packets*1000), max_time/1000); printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us \n", (float)avg_hops/total_finished_packets, avg_time/(total_finished_packets*1000), max_time/1000);
if(routing == ADAPTIVE || routing == PROG_ADAPTIVE) if(routing == ADAPTIVE || routing == PROG_ADAPTIVE)
printf("\n ADAPTIVE ROUTING STATS: %d percent packets routed minimally %d percent packets routed non-minimally completed packets %d ", total_minimal_packets, total_nonmin_packets, total_completed_packets); printf("\n ADAPTIVE ROUTING STATS: %d packets routed minimally %d packets routed non-minimally completed packets %d ", total_minimal_packets, total_nonmin_packets, total_completed_packets);
return; return;
...@@ -573,37 +573,46 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -573,37 +573,46 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw
return; return;
static void packet_generate_rc(terminal_state * s, static void packet_generate_send_rc(terminal_state * s,
tw_bf * bf, tw_bf * bf,
terminal_message * msg, terminal_message * msg,
tw_lp * lp) tw_lp * lp)
int i; int i;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
if(bf->c1)
mn_stats* stat; s->terminal_available_time = msg->saved_available_time;
int vc = msg->saved_vc;
s->vc_occupancy[vc]--;
s->packet_counter--;
s->output_vc_state[vc] = VC_IDLE;
if (msg->chunk_id == (msg->num_chunks-1)){
codes_local_latency_reverse(lp);
struct mn_stats* stat;
stat = model_net_find_stats(msg->category, s->dragonfly_stats_array); stat = model_net_find_stats(msg->category, s->dragonfly_stats_array);
stat->send_count--; stat->send_count--;
stat->send_bytes -= msg->packet_size; stat->send_bytes -= msg->packet_size;
stat->send_time -= (1/s->params->cn_bandwidth) * msg->packet_size; stat->send_time -= (1/s->params->cn_bandwidth) * msg->packet_size;
/* generates packet at the current dragonfly compute node */ /* generates packet at the current dragonfly compute node */
static void packet_generate(terminal_state * s, static void packet_generate_send(terminal_state * s,
const dragonfly_param *p = s->params; const dragonfly_param *p = s->params;
tw_stime ts; tw_stime ts;
tw_event *e; tw_event *e;
tw_lpid router_id;
terminal_message *m; terminal_message *m;
int i, total_event_size; int i, total_event_size;
int chunk_id = msg->chunk_id;
uint64_t num_chunks = msg->packet_size / p->chunk_size; uint64_t num_chunks = msg->packet_size / p->chunk_size;
if (msg->packet_size % s->params->chunk_size) if (msg->packet_size % s->params->chunk_size)
num_chunks++; num_chunks++;
...@@ -615,8 +624,13 @@ static void packet_generate(terminal_state * s, ...@@ -615,8 +624,13 @@ static void packet_generate(terminal_state * s,
msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter + tw_rand_integer(lp->rng, 0, lp->gid + g_tw_nlp * s->packet_counter); msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter + tw_rand_integer(lp->rng, 0, lp->gid + g_tw_nlp * s->packet_counter);
msg->travel_start_time = tw_now(lp); msg->travel_start_time = tw_now(lp);
ts = codes_local_latency(lp); // Each packet is broken into chunks and then sent over the channel
msg->saved_available_time = s->terminal_available_time;
double head_delay = (1/s->params->cn_bandwidth) * s->params->chunk_size;
ts = head_delay + tw_rand_exponential(lp->rng, (double)head_delay/200);
s->terminal_available_time = maxd(s->terminal_available_time, tw_now(lp));
s->terminal_available_time += ts;
int chan = -1, j; int chan = -1, j;
for(j = 0; j < p->num_vcs; j++) for(j = 0; j < p->num_vcs; j++)
...@@ -626,43 +640,85 @@ static void packet_generate(terminal_state * s, ...@@ -626,43 +640,85 @@ static void packet_generate(terminal_state * s,
break; break;
// this is a terminal event, so use the method-event version
void * m_data; /* for reverse computation */
e = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY, msg->saved_vc = chan;
(void**)&m, &m_data);
memcpy(m, msg, sizeof(terminal_message)); /* simulation should exit */
void * m_data_src = model_net_method_get_edata(DRAGONFLY, msg); if(chan == -1)
if (msg->remote_event_size_bytes){ tw_error(TW_LOC, "\n No terminal buffers available, increase buffer size");
memcpy(m_data, m_data_src, msg->remote_event_size_bytes);
} //TODO: be annotation-aware
if (msg->local_event_size_bytes){ codes_mapping_get_lp_info(lp->gid, lp_group_name, &mapping_grp_id, NULL,
memcpy((char*)m_data + msg->remote_event_size_bytes, &mapping_type_id, NULL, &mapping_rep_id, &mapping_offset);
(char*)m_data_src + msg->remote_event_size_bytes,
msg->local_event_size_bytes); codes_mapping_get_lp_id(lp_group_name, "dragonfly_router", NULL, 1,
} s->router_id/num_routers_per_mgrp,
m->intm_group_id = -1; s->router_id % num_routers_per_mgrp, &router_id);
m->saved_vc=0;
m->chunk_id = msg->chunk_id; e = tw_event_new(router_id, s->terminal_available_time - tw_now(lp), lp);
m->magic = terminal_magic_num; m = tw_event_data(e);
/* if(msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1) memcpy(m, msg, sizeof(terminal_message));
printf("\n packet generated %lld at terminal %d chunk id %d ", msg->packet_ID, (int)lp->gid, i); m->magic = router_magic_num;
*/ m->origin_router_id = s->router_id;
m->output_chan = -1; m->type = R_ARRIVE;
if(chan != -1) // If the input queue is available m->src_terminal_id = lp->gid;
m->saved_vc = chan;
m->last_hop = TERMINAL;
m->path_type = -1;
m->local_event_size_bytes = 0;
m->local_id = s->terminal_id;
memcpy(m+1, model_net_method_get_edata(DRAGONFLY, msg),
tw_event_send(e);
if(msg->chunk_id == msg->num_chunks - 1)
// Send the packet out // now that message is sent, issue an "idle" event to tell the scheduler
m->type = T_SEND; // when I'm next available
tw_event_send(e); model_net_method_idle_event(codes_local_latency(lp) +
s->terminal_available_time - tw_now(lp), 0, lp);
/* local completion message */
if(msg->local_event_size_bytes > 0)
tw_event* e_new;
terminal_message* m_new;
void* local_event =
(char*)model_net_method_get_edata(DRAGONFLY, msg) +
msg->remote_event_size_bytes;
ts = g_tw_lookahead + (1/s->params->cn_bandwidth) * msg->local_event_size_bytes;
e_new = tw_event_new(msg->sender_lp, ts, lp);
m_new = tw_event_data(e_new);
memcpy(m_new, local_event, msg->local_event_size_bytes);
tw_event_send(e_new);
else s->packet_counter++;
{ s->vc_occupancy[chan]++;
printf("\n Exceeded queue size, exitting %d", s->vc_occupancy[0]);
MPI_Finalize(); if(s->vc_occupancy[chan] >= s->params->cn_vc_size)
exit(-1); s->output_vc_state[chan] = VC_CREDIT;
} //else
/* calculate statistics */
total_event_size = model_net_get_msg_sz(DRAGONFLY) +
msg->remote_event_size_bytes + msg->local_event_size_bytes;
stat->send_count++;
stat->send_bytes += msg->packet_size;
stat->send_time += (1/p->cn_bandwidth) * msg->packet_size;
if(stat->max_event_size < total_event_size)
stat->max_event_size = total_event_size;
/* Now schedule another packet generate event */ /* Now schedule another packet generate event */
if(chunk_id < num_chunks - 1) if(msg->chunk_id < num_chunks - 1)
bf->c1 = 1; bf->c1 = 1;
/* Issue another packet generate event */ /* Issue another packet generate event */
...@@ -678,7 +734,7 @@ static void packet_generate(terminal_state * s, ...@@ -678,7 +734,7 @@ static void packet_generate(terminal_state * s,
void *m_gen_data_src = model_net_method_get_edata(DRAGONFLY, msg); void *m_gen_data_src = model_net_method_get_edata(DRAGONFLY, msg);
memcpy(m_gen, msg, sizeof(terminal_message)); memcpy(m_gen, msg, sizeof(terminal_message));
m_gen->chunk_id = ++chunk_id; m_gen->chunk_id = ++(msg->chunk_id);
m_gen->type = T_GENERATE; m_gen->type = T_GENERATE;
if (msg->remote_event_size_bytes){ if (msg->remote_event_size_bytes){
...@@ -692,17 +748,7 @@ static void packet_generate(terminal_state * s, ...@@ -692,17 +748,7 @@ static void packet_generate(terminal_state * s,
tw_event_send(e_gen); tw_event_send(e_gen);
mn_stats* stat;
stat->send_count++;
return; return;
...@@ -711,112 +757,25 @@ static void packet_send_rc(terminal_state * s, ...@@ -711,112 +757,25 @@ static void packet_send_rc(terminal_state * s,
if (msg->chunk_id == (msg->num_chunks)-1){
/* sends the packet from the current dragonfly compute node to the attached router */
static void packet_send(terminal_state * s,
tw_bf * bf,
tw_lp * lp)
tw_stime ts;
tw_event *e;
tw_lpid router_id;
/* Route the packet to its source router */
int vc=msg->saved_vc;
s->router_id/num_routers_per_mgrp, s->router_id % num_routers_per_mgrp, &router_id);
// we are sending an event to the router, so no method_event here
//if(msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1)
// printf("\n terminal %d packet %lld chunk %d being sent to router %d router id %d ", (int)lp->gid, (long long)msg->packet_ID, msg->chunk_id, (int)router_id, s->router_id);
m->type = R_ARRIVE;
m->saved_vc = vc;
m->path_type = -1;
tw_event_send(e);
tw_event* e_new;
void* local_event =
s->vc_occupancy[vc]++;
if(s->vc_occupancy[vc] >= s->params->cn_vc_size)
s->output_vc_state[vc] = VC_CREDIT;
return;
static void packet_arrive_rc(terminal_state * s, static void packet_arrive_rc(terminal_state * s,
completed_packets--; uint64_t num_chunks = msg->packet_size / s->params->chunk_size;
num_chunks++;
if(msg->chunk_id == num_chunks - 1)
if(msg->path_type == MINIMAL) if(msg->path_type == MINIMAL && msg->chunk_id == num_chunks - 1)
minimal_count--; minimal_count--;
if(msg->path_type == NON_MINIMAL) if(msg->path_type == NON_MINIMAL && msg->chunk_id == num_chunks - 1)
nonmin_count--; nonmin_count--;
...@@ -855,12 +814,13 @@ static void packet_arrive(terminal_state * s, ...@@ -855,12 +814,13 @@ static void packet_arrive(terminal_state * s,
completed_packets++; if(msg->chunk_id == num_chunks - 1)
minimal_count++; minimal_count++;
nonmin_count++; nonmin_count++;
if(msg->path_type != MINIMAL && msg->path_type != NON_MINIMAL) if(msg->path_type != MINIMAL && msg->path_type != NON_MINIMAL)
...@@ -1305,17 +1265,13 @@ terminal_event( terminal_state * s, ...@@ -1305,17 +1265,13 @@ terminal_event( terminal_state * s,
switch(msg->type) switch(msg->type)
case T_GENERATE: case T_GENERATE:
packet_generate(s,bf,msg,lp); packet_generate_send(s,bf,msg,lp);
break; break;
case T_ARRIVE: case T_ARRIVE:
packet_arrive(s,bf,msg,lp); packet_arrive(s,bf,msg,lp);
break; break;
case T_SEND:
packet_send(s,bf,msg,lp);
break;
case T_BUFFER: case T_BUFFER:
terminal_buf_update(s, bf, msg, lp); terminal_buf_update(s, bf, msg, lp);
break; break;
...@@ -1995,13 +1951,9 @@ void terminal_rc_event_handler(terminal_state * s, tw_bf * bf, terminal_message ...@@ -1995,13 +1951,9 @@ void terminal_rc_event_handler(terminal_state * s, tw_bf * bf, terminal_message
packet_generate_rc(s, bf, msg, lp); packet_generate_send_rc(s, bf, msg, lp);
break; break;
case T_SEND:
packet_send_rc(s, bf, msg, lp);
break;
packet_arrive_rc(s, bf, msg, lp); packet_arrive_rc(s, bf, msg, lp);
break; break;
Markdown is supported
0% or .
Please register or to comment
