Commit 2e250049 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Adding updates for recording simulation's forward and reverse events,...
Adding updates for recording simulation's forward and reverse events, documenting adaptive routing congestion sensing conditions for Xu
parent e905b0f9
...@@ -140,8 +140,10 @@ struct dfly_router_sample ...@@ -140,8 +140,10 @@ struct dfly_router_sample
tw_lpid router_id; tw_lpid router_id;
tw_stime* busy_time; tw_stime* busy_time;
int64_t* link_traffic; int64_t* link_traffic_sample;
tw_stime end_time; tw_stime end_time;
long fwd_events;
long rev_events;
struct dfly_cn_sample struct dfly_cn_sample
...@@ -153,6 +155,8 @@ struct dfly_cn_sample ...@@ -153,6 +155,8 @@ struct dfly_cn_sample
tw_stime fin_chunks_time; tw_stime fin_chunks_time;
tw_stime busy_time_sample; tw_stime busy_time_sample;
long fwd_events;
long rev_events;
struct dfly_qhash_entry struct dfly_qhash_entry
...@@ -251,6 +255,10 @@ struct terminal_state ...@@ -251,6 +255,10 @@ struct terminal_state
struct dfly_cn_sample * sample_stat; struct dfly_cn_sample * sample_stat;
int op_arr_size; int op_arr_size;
int max_arr_size; int max_arr_size;
/* for logging forward and reverse events */
long fwd_events;
long rev_events;
/* terminal event type (1-4) */ /* terminal event type (1-4) */
...@@ -333,6 +341,9 @@ struct router_state ...@@ -333,6 +341,9 @@ struct router_state
char output_buf2[4096]; char output_buf2[4096];
struct dfly_router_sample * rsamples; struct dfly_router_sample * rsamples;
long fwd_events;
long rev_events;
static short routing = MINIMAL; static short routing = MINIMAL;
...@@ -552,7 +563,7 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){ ...@@ -552,7 +563,7 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
p->num_cn = p->num_routers/2; p->num_cn = p->num_routers/2;
p->num_global_channels = p->num_routers/2; p->num_global_channels = p->num_routers/2;
p->num_groups = p->num_routers * p->num_cn + 1; p->num_groups = p->num_routers * p->num_cn + 1;
p->radix = (p->num_global_channels + p->num_routers + p->num_cn); p->radix = (p->num_routers + p->num_global_channels + p->num_cn);
p->total_routers = p->num_groups * p->num_routers; p->total_routers = p->num_groups * p->num_routers;
p->total_terminals = p->total_routers * p->num_cn; p->total_terminals = p->total_routers * p->num_cn;
int rank; int rank;
...@@ -729,6 +740,9 @@ terminal_init( terminal_state * s, ...@@ -729,6 +740,9 @@ terminal_init( terminal_state * s,
s->last_buf_full = 0.0; s->last_buf_full = 0.0;
s->busy_time = 0.0; s->busy_time = 0.0;
s->fwd_events = 0;
s->rev_events = 0;
rc_stack_create(&s->st); rc_stack_create(&s->st);
s->num_vcs = 1; s->num_vcs = 1;
s->vc_occupancy = (int*)malloc(s->num_vcs * sizeof(int)); s->vc_occupancy = (int*)malloc(s->num_vcs * sizeof(int));
...@@ -785,6 +799,9 @@ void router_setup(router_state * r, tw_lp * lp) ...@@ -785,6 +799,9 @@ void router_setup(router_state * r, tw_lp * lp)
r->router_id=mapping_rep_id + mapping_offset; r->router_id=mapping_rep_id + mapping_offset;
r->group_id=r->router_id/p->num_routers; r->group_id=r->router_id/p->num_routers;
r->fwd_events = 0;
r->rev_events = 0;
r->global_channel = (int*)malloc(p->num_global_channels * sizeof(int)); r->global_channel = (int*)malloc(p->num_global_channels * sizeof(int));
r->next_output_available_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime)); r->next_output_available_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime));
r->cur_hist_start_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime)); r->cur_hist_start_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime));
...@@ -1048,7 +1065,6 @@ void router_credit_send(router_state * s, terminal_message * msg, ...@@ -1048,7 +1065,6 @@ void router_credit_send(router_state * s, terminal_message * msg,
void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
s->packet_gen--; s->packet_gen--;
packet_gen--; packet_gen--;
...@@ -1898,7 +1914,7 @@ void dragonfly_rsample_init(router_state * s, ...@@ -1898,7 +1914,7 @@ void dragonfly_rsample_init(router_state * s,
for(; i < s->max_arr_size; i++) for(; i < s->max_arr_size; i++)
s->rsamples[i].busy_time = malloc(sizeof(tw_stime) * p->radix); s->rsamples[i].busy_time = malloc(sizeof(tw_stime) * p->radix);
s->rsamples[i].link_traffic = malloc(sizeof(int64_t) * p->radix); s->rsamples[i].link_traffic_sample = malloc(sizeof(int64_t) * p->radix);
void dragonfly_rsample_rc_fn(router_state * s, void dragonfly_rsample_rc_fn(router_state * s,
...@@ -1920,14 +1936,16 @@ void dragonfly_rsample_rc_fn(router_state * s, ...@@ -1920,14 +1936,16 @@ void dragonfly_rsample_rc_fn(router_state * s,
for(; i < p->radix; i++) for(; i < p->radix; i++)
s->busy_time_sample[i] = stat.busy_time[i]; s->busy_time_sample[i] = stat.busy_time[i];
s->link_traffic_sample[i] = stat.link_traffic[i]; s->link_traffic_sample[i] = stat.link_traffic_sample[i];
for( i = 0; i < p->radix; i++) for( i = 0; i < p->radix; i++)
stat.busy_time[i] = 0; stat.busy_time[i] = 0;
stat.link_traffic[i] = 0; stat.link_traffic_sample[i] = 0;
s->fwd_events = stat.fwd_events;
s->rev_events = stat.rev_events;
void dragonfly_rsample_fn(router_state * s, void dragonfly_rsample_fn(router_state * s,
...@@ -1955,16 +1973,20 @@ void dragonfly_rsample_fn(router_state * s, ...@@ -1955,16 +1973,20 @@ void dragonfly_rsample_fn(router_state * s,
s->rsamples[cur_indx].router_id = s->router_id; s->rsamples[cur_indx].router_id = s->router_id;
s->rsamples[cur_indx].end_time = tw_now(lp); s->rsamples[cur_indx].end_time = tw_now(lp);
s->rsamples[cur_indx].fwd_events = s->fwd_events;
s->rsamples[cur_indx].rev_events = s->rev_events;
s->rsamples[cur_indx].busy_time[i] = s->busy_time_sample[i]; s->rsamples[cur_indx].busy_time[i] = s->busy_time_sample[i];
s->rsamples[cur_indx].link_traffic[i] = s->link_traffic_sample[i]; s->rsamples[cur_indx].link_traffic_sample[i] = s->link_traffic_sample[i];
s->op_arr_size++; s->op_arr_size++;
/* clear up the current router stats */ /* clear up the current router stats */
s->fwd_events = 0;
s->rev_events = 0;
...@@ -1987,8 +2009,10 @@ void dragonfly_rsample_fin(router_state * s, ...@@ -1987,8 +2009,10 @@ void dragonfly_rsample_fin(router_state * s,
FILE * fp = fopen(meta_fname, "w"); FILE * fp = fopen(meta_fname, "w");
fprintf(fp, "Router sample struct format: router_id (tw_lpid) \t busy time for each of the %d links (double) \t" fprintf(fp, "Router sample struct format: router_id (tw_lpid) \t busy time for each of the %d links (double) \t"
"link traffic for each of the %d links (int64_t) \t sample end time (double)", "link traffic for each of the %d links (int64_t) \t sample end time (double) forward events per sample \t reverse events per sample ",
p->radix, p->radix); p->radix, p->radix);
fprintf(fp, "Ordering of links %d local (router-router same group) channels, %d global (router-router remote group)"
" channels and %d terminal channels", p->radix/2, p->radix/4, p->radix/4);
fclose(fp); fclose(fp);
char rt_fn[MAX_NAME_LENGTH]; char rt_fn[MAX_NAME_LENGTH];
...@@ -2000,7 +2024,7 @@ void dragonfly_rsample_fin(router_state * s, ...@@ -2000,7 +2024,7 @@ void dragonfly_rsample_fin(router_state * s,
int i = 0; int i = 0;
int j = 0; int j = 0;
int size_sample = sizeof(tw_lpid) + p->radix * (sizeof(int64_t) + sizeof(tw_stime)) + sizeof(tw_stime); int size_sample = sizeof(tw_lpid) + p->radix * (sizeof(int64_t) + sizeof(tw_stime)) + sizeof(tw_stime) + 2 * sizeof(long);
FILE * fp = fopen(rt_fn, "a"); FILE * fp = fopen(rt_fn, "a");
fseek(fp, sample_rtr_bytes_written, SEEK_SET); fseek(fp, sample_rtr_bytes_written, SEEK_SET);
...@@ -2008,12 +2032,13 @@ void dragonfly_rsample_fin(router_state * s, ...@@ -2008,12 +2032,13 @@ void dragonfly_rsample_fin(router_state * s,
fwrite((void*)&(s->rsamples[i].router_id), sizeof(tw_lpid), 1, fp); fwrite((void*)&(s->rsamples[i].router_id), sizeof(tw_lpid), 1, fp);
fwrite(s->rsamples[i].busy_time, sizeof(tw_stime), p->radix, fp); fwrite(s->rsamples[i].busy_time, sizeof(tw_stime), p->radix, fp);
fwrite(s->rsamples[i].link_traffic, sizeof(int64_t), p->radix, fp); fwrite(s->rsamples[i].link_traffic_sample, sizeof(int64_t), p->radix, fp);
fwrite((void*)&(s->rsamples[i].end_time), sizeof(tw_stime), 1, fp); fwrite((void*)&(s->rsamples[i].end_time), sizeof(tw_stime), 1, fp);
fwrite((void*)&(s->rsamples[i].fwd_events), sizeof(long), 1, fp);
fwrite((void*)&(s->rsamples[i].rev_events), sizeof(long), 1, fp);
sample_rtr_bytes_written += (s->op_arr_size * size_sample); sample_rtr_bytes_written += (s->op_arr_size * size_sample);
void dragonfly_sample_init(terminal_state * s, void dragonfly_sample_init(terminal_state * s,
tw_lp * lp) tw_lp * lp)
...@@ -2055,6 +2080,8 @@ void dragonfly_sample_rc_fn(terminal_state * s, ...@@ -2055,6 +2080,8 @@ void dragonfly_sample_rc_fn(terminal_state * s,
s->fin_hops_sample = stat.fin_hops_sample; s->fin_hops_sample = stat.fin_hops_sample;
s->data_size_sample = stat.data_size_sample; s->data_size_sample = stat.data_size_sample;
s->fin_chunks_sample = stat.fin_chunks_sample; s->fin_chunks_sample = stat.fin_chunks_sample;
stat.busy_time_sample = 0; stat.busy_time_sample = 0;
stat.fin_chunks_time = 0; stat.fin_chunks_time = 0;
...@@ -2063,6 +2090,8 @@ void dragonfly_sample_rc_fn(terminal_state * s, ...@@ -2063,6 +2090,8 @@ void dragonfly_sample_rc_fn(terminal_state * s,
stat.fin_chunks_sample = 0; stat.fin_chunks_sample = 0;
stat.end_time = 0; stat.end_time = 0;
stat.terminal_id = 0; stat.terminal_id = 0;
stat.fwd_events = 0;
stat.rev_events = 0;
void dragonfly_sample_fn(terminal_state * s, void dragonfly_sample_fn(terminal_state * s,
...@@ -2111,11 +2140,15 @@ void dragonfly_sample_fn(terminal_state * s, ...@@ -2111,11 +2140,15 @@ void dragonfly_sample_fn(terminal_state * s,
s->sample_stat[cur_indx].fin_chunks_time = s->fin_chunks_time; s->sample_stat[cur_indx].fin_chunks_time = s->fin_chunks_time;
s->sample_stat[cur_indx].busy_time_sample = s->busy_time_sample; s->sample_stat[cur_indx].busy_time_sample = s->busy_time_sample;
s->sample_stat[cur_indx].end_time = tw_now(lp); s->sample_stat[cur_indx].end_time = tw_now(lp);
s->sample_stat[cur_indx].fwd_events = s->fwd_events;
s->sample_stat[cur_indx].rev_events = s->rev_events;
s->fin_chunks_sample = 0; s->fin_chunks_sample = 0;
s->data_size_sample = 0; s->data_size_sample = 0;
s->fin_hops_sample = 0; s->fin_hops_sample = 0;
s->fwd_events = 0;
s->rev_events = 0;
s->fin_chunks_time = 0; s->fin_chunks_time = 0;
s->busy_time_sample = 0; s->busy_time_sample = 0;
...@@ -2142,7 +2175,7 @@ void dragonfly_sample_fin(terminal_state * s, ...@@ -2142,7 +2175,7 @@ void dragonfly_sample_fin(terminal_state * s,
fprintf(fp, "Compute node sample format: terminal_id (tw_lpid) \t finished chunks (long) \t" fprintf(fp, "Compute node sample format: terminal_id (tw_lpid) \t finished chunks (long) \t"
"data size per sample (long) \t finished hops (double) \t time to finish chunks (double) \t " "data size per sample (long) \t finished hops (double) \t time to finish chunks (double) \t "
"busy time (double)\t sample end time(double)"); "busy time (double)\t sample end time(double) \t forward events (long) \t reverse events (long)");
...@@ -2229,6 +2262,7 @@ terminal_event( terminal_state * s, ...@@ -2229,6 +2262,7 @@ terminal_event( terminal_state * s,
terminal_message * msg, terminal_message * msg,
tw_lp * lp ) tw_lp * lp )
s->fwd_events++;
//*(int *)bf = (int)0; //*(int *)bf = (int)0;
assert(msg->magic == terminal_magic_num); assert(msg->magic == terminal_magic_num);
...@@ -2596,7 +2630,10 @@ TODO: do we need this code? nomin_vc and min_vc not used anywhere... ...@@ -2596,7 +2630,10 @@ TODO: do we need this code? nomin_vc and min_vc not used anywhere...
int nonmin_port_count = s->vc_occupancy[nonmin_out_port][0] + int nonmin_port_count = s->vc_occupancy[nonmin_out_port][0] +
s->vc_occupancy[nonmin_out_port][1] + s->vc_occupancy[nonmin_out_port][2] s->vc_occupancy[nonmin_out_port][1] + s->vc_occupancy[nonmin_out_port][2]
+ s->queued_count[nonmin_out_port]; + s->queued_count[nonmin_out_port];
//if(num_min_hops * (min_port_count - min_hist_count) <= (num_nonmin_hops * ((q_avg + 1) - nonmin_hist_count))) { // VARIATION 1:
// if(num_min_hops * min_port_count <= num_nonmin_hops * nonmin_port_count) {
// VARIATION 2:
//if(num_min_hops * min_port_count <= (num_nonmin_hops * (q_avg + 1))) {
if(min_port_count <= nonmin_port_count) { if(min_port_count <= nonmin_port_count) {
msg->path_type = MINIMAL; msg->path_type = MINIMAL;
next_stop = minimal_next_stop; next_stop = minimal_next_stop;
...@@ -2793,8 +2830,6 @@ void router_packet_send_rc(router_state * s, ...@@ -2793,8 +2830,6 @@ void router_packet_send_rc(router_state * s,
terminal_message_list * cur_entry = rc_stack_pop(s->st); terminal_message_list * cur_entry = rc_stack_pop(s->st);
assert(cur_entry); assert(cur_entry);
// create_prepend_to_terminal_message_list(s->pending_msgs[output_port],
// s->pending_msgs_tail[output_port], output_chan, msg);
prepend_to_terminal_message_list(s->pending_msgs[output_port], prepend_to_terminal_message_list(s->pending_msgs[output_port],
s->pending_msgs_tail[output_port], output_chan, cur_entry); s->pending_msgs_tail[output_port], output_chan, cur_entry);
...@@ -3044,7 +3079,10 @@ void router_buf_update(router_state * s, tw_bf * bf, terminal_message * msg, tw_ ...@@ -3044,7 +3079,10 @@ void router_buf_update(router_state * s, tw_bf * bf, terminal_message * msg, tw_
void router_event(router_state * s, tw_bf * bf, terminal_message * msg, void router_event(router_state * s, tw_bf * bf, terminal_message * msg,
tw_lp * lp) { tw_lp * lp) {
s->fwd_events++;
rc_stack_gc(lp, s->st); rc_stack_gc(lp, s->st);
assert(msg->magic == router_magic_num); assert(msg->magic == router_magic_num);
switch(msg->type) switch(msg->type)
...@@ -3073,6 +3111,7 @@ void router_event(router_state * s, tw_bf * bf, terminal_message * msg, ...@@ -3073,6 +3111,7 @@ void router_event(router_state * s, tw_bf * bf, terminal_message * msg,
void terminal_rc_event_handler(terminal_state * s, tw_bf * bf, void terminal_rc_event_handler(terminal_state * s, tw_bf * bf,
terminal_message * msg, tw_lp * lp) { terminal_message * msg, tw_lp * lp) {
s->rev_events++;
case T_GENERATE: case T_GENERATE:
...@@ -3126,7 +3165,9 @@ void terminal_rc_event_handler(terminal_state * s, tw_bf * bf, ...@@ -3126,7 +3165,9 @@ void terminal_rc_event_handler(terminal_state * s, tw_bf * bf,
/* Reverse computation handler for a router event */ /* Reverse computation handler for a router event */
void router_rc_event_handler(router_state * s, tw_bf * bf, void router_rc_event_handler(router_state * s, tw_bf * bf,
switch(msg->type) { s->rev_events++;
switch(msg->type) {
case R_SEND: case R_SEND:
router_packet_send_rc(s, bf, msg, lp); router_packet_send_rc(s, bf, msg, lp);
break; break;
Markdown is supported
0% or .
Please register or to comment
