Commit 27e1342c authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Breaking down synthetic and trace test scripts
parent da5879aa
...@@ -28,13 +28,17 @@ TESTS += tests/lp-io-test.sh \ ...@@ -28,13 +28,17 @@ TESTS += tests/lp-io-test.sh \
tests/map-ctx-test.sh \ tests/map-ctx-test.sh \
tests/modelnet-test.sh \ tests/modelnet-test.sh \
tests/modelnet-test-torus.sh \ tests/modelnet-test-torus.sh \
tests/modelnet-test-torus-traces.sh \
tests/modelnet-test-loggp.sh \ tests/modelnet-test-loggp.sh \
tests/modelnet-test-dragonfly.sh \ tests/modelnet-test-dragonfly.sh \
tests/modelnet-test-slimfly.sh \ tests/modelnet-test-slimfly.sh \
tests/modelnet-test-dragonfly-synthetic.sh \ tests/modelnet-test-dragonfly-synthetic.sh \
tests/modelnet-test-dragonfly-traces.sh \
tests/modelnet-test-dragonfly-custom-synthetic.sh \ tests/modelnet-test-dragonfly-custom-synthetic.sh \
tests/modelnet-test-dragonfly-custom-traces.sh \
tests/modelnet-test-fattree-synthetic.sh \ tests/modelnet-test-fattree-synthetic.sh \
tests/modelnet-test-slimfly-synthetic.sh \ tests/modelnet-test-slimfly-synthetic.sh \
tests/modelnet-test-slimfly-traces.sh \
tests/modelnet-p2p-bw-loggp.sh \ tests/modelnet-p2p-bw-loggp.sh \
tests/modelnet-prio-sched-test.sh tests/modelnet-prio-sched-test.sh
...@@ -57,9 +61,15 @@ EXTRA_DIST += tests/lp-io-test.sh \ ...@@ -57,9 +61,15 @@ EXTRA_DIST += tests/lp-io-test.sh \
tests/expected/mapping_test.out \ tests/expected/mapping_test.out \
tests/modelnet-prio-sched-test.sh \ tests/modelnet-prio-sched-test.sh \
tests/conf/concurrent_msg_recv.conf \ tests/conf/concurrent_msg_recv.conf \
#!/bin/bash #!/bin/bash
if [ -z $srcdir ]; then
echo srcdir variable not set.
exit 1
fi
src/network-workloads/model-net-synthetic-custom-dfly --sync=1 --num_messages=1 -- src/network-workloads/conf/dragonfly-custom/modelnet-test-dragonfly-1728-nodes.conf src/network-workloads/model-net-synthetic-custom-dfly --sync=1 --num_messages=1 -- src/network-workloads/conf/dragonfly-custom/modelnet-test-dragonfly-1728-nodes.conf
mpirun -np 2 src/network-workloads/model-net-mpi-replay --sync=3 --num_net_traces=27 --disable_compute=1 --workload_file=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- --workload_type="dumpi" -- src/network-workloads/conf/dragonfly-custom/modelnet-test-dragonfly-1728-nodes.conf
#!/bin/bash
exit 1
fi
exit 1
fi
source $srcdir/tests/download-traces.sh
src/network-workloads/model-net-synthetic --sync=1 --num_messages=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-dragonfly.conf src/network-workloads/model-net-synthetic --sync=1 --num_messages=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-dragonfly.conf
mpirun -np 2 src/network-workloads/model-net-mpi-replay --disable_compute=1 --sync=3 --num_net_traces=27 --workload_file=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- --workload_type="dumpi" -- $srcdir/src/network-workloads/conf/modelnet-mpi-test-dfly-amg-216.conf
#!/bin/bash
exit 1
fi
exit 1
fi
src/network-workloads/model-net-synthetic-slimfly --sync=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf src/network-workloads/model-net-synthetic-slimfly --sync=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf
mpirun -np 2 src/network-workloads/model-net-mpi-replay --disable_compute=1 --sync=3 --num_net_traces=27 --workload_file=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- --workload_type="dumpi" -- $srcdir/src/network-workloads/conf/modelnet-mpi-test-slimfly-min.conf
#!/bin/bash
exit 1
fi
#!/bin/bash
exit 1
fi
mpirun -np 2 src/network-workloads/model-net-mpi-replay --sync=3 --disable_compute=1 --num_net_traces=27 --workload_file=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- --workload_type="dumpi" -- $srcdir/src/network-workloads/conf/modelnet-mpi-test-torus.conf
exit 1
fi
tests/modelnet-test --sync=1 -- tests/conf/modelnet-test-torus.conf tests/modelnet-test --sync=1 -- tests/conf/modelnet-test-torus.conf
Markdown is supported
0% or .
Please register or to comment
