Commit 0cd09451 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Added some simulation progress stats, updated dragonfly out of order packet arrival
parent bf9dbce4
...@@ -14,6 +14,7 @@ ...@@ -14,6 +14,7 @@
#include "codes/rc-stack.h" #include "codes/rc-stack.h"
#define TRACE -1 #define TRACE -1
#define TRACK 0
char workload_type[128]; char workload_type[128];
char workload_file[8192]; char workload_file[8192];
...@@ -95,7 +96,10 @@ struct nw_state ...@@ -95,7 +96,10 @@ struct nw_state
short wrkld_end; short wrkld_end;
struct rc_stack * st; struct rc_stack * st;
/* count of sends, receives, collectives and delays */
uint64_t num_completed;
unsigned long num_sends; unsigned long num_sends;
unsigned long num_recvs; unsigned long num_recvs;
unsigned long num_cols; unsigned long num_cols;
...@@ -1246,6 +1250,12 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l ...@@ -1246,6 +1250,12 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l
struct codes_workload_op * mpi_op = malloc(sizeof(struct codes_workload_op)); struct codes_workload_op * mpi_op = malloc(sizeof(struct codes_workload_op));
codes_workload_get_next(wrkld_id, 0, (int)s->nw_id, mpi_op); codes_workload_get_next(wrkld_id, 0, (int)s->nw_id, mpi_op);
s->num_completed++;
if(s->nw_id == TRACK && s->num_completed % 10000 == 0)
printf("\n Status: LP %ld completed %ld MPI operations ",
s->nw_id, s->num_completed);
m->u.rc.saved_op = mpi_op; m->u.rc.saved_op = mpi_op;
if(mpi_op->op_type == CODES_WK_END) if(mpi_op->op_type == CODES_WK_END)
...@@ -49,7 +49,7 @@ long term_ecount, router_ecount, term_rev_ecount, router_rev_ecount; ...@@ -49,7 +49,7 @@ long term_ecount, router_ecount, term_rev_ecount, router_rev_ecount;
static double maxd(double a, double b) { return a < b ? b : a; } static double maxd(double a, double b) { return a < b ? b : a; }
/* minimal and non-minimal packet counts for adaptive routing*/ /* minimal and non-minimal packet counts for adaptive routing*/
static unsigned int minimal_count=0, nonmin_count=0, completed_packets = 0; static unsigned int minimal_count=0, nonmin_count=0;
typedef struct dragonfly_param dragonfly_param; typedef struct dragonfly_param dragonfly_param;
/* annotation-specific parameters (unannotated entry occurs at the /* annotation-specific parameters (unannotated entry occurs at the
...@@ -275,6 +275,9 @@ static tw_stime max_collective = 0; ...@@ -275,6 +275,9 @@ static tw_stime max_collective = 0;
static long long total_hops = 0; static long long total_hops = 0;
static long long N_finished_packets = 0; static long long N_finished_packets = 0;
static long long total_msg_sz = 0;
static long long N_finished_msgs = 0;
static long long N_finished_chunks = 0;
static int dragonfly_rank_hash_compare( static int dragonfly_rank_hash_compare(
void *key, struct qhash_head *link) void *key, struct qhash_head *link)
...@@ -553,27 +556,30 @@ static void dragonfly_configure(){ ...@@ -553,27 +556,30 @@ static void dragonfly_configure(){
/* report dragonfly statistics like average and maximum packet latency, average number of hops traversed */ /* report dragonfly statistics like average and maximum packet latency, average number of hops traversed */
static void dragonfly_report_stats() static void dragonfly_report_stats()
long long avg_hops, total_finished_packets; long long avg_hops, total_finished_packets, total_finished_chunks;
long long total_finished_msgs, final_msg_sz;
tw_stime avg_time, max_time; tw_stime avg_time, max_time;
int total_minimal_packets, total_nonmin_packets, total_completed_packets; int total_minimal_packets, total_nonmin_packets;
MPI_Reduce( &total_hops, &avg_hops, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD); MPI_Reduce( &total_hops, &avg_hops, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &N_finished_packets, &total_finished_packets, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD); MPI_Reduce( &N_finished_packets, &total_finished_packets, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &N_finished_msgs, &total_finished_msgs, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &N_finished_chunks, &total_finished_chunks, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &total_msg_sz, &final_msg_sz, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &dragonfly_total_time, &avg_time, 1,MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD); MPI_Reduce( &dragonfly_total_time, &avg_time, 1,MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &dragonfly_max_latency, &max_time, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD); MPI_Reduce( &dragonfly_max_latency, &max_time, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
if(routing == ADAPTIVE || routing == PROG_ADAPTIVE) if(routing == ADAPTIVE || routing == PROG_ADAPTIVE)
MPI_Reduce(&minimal_count, &total_minimal_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD); MPI_Reduce(&minimal_count, &total_minimal_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce(&nonmin_count, &total_nonmin_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD); MPI_Reduce(&nonmin_count, &total_nonmin_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce(&completed_packets, &total_completed_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD);
/* print statistics */ /* print statistics */
if(!g_tw_mynode) if(!g_tw_mynode)
printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us avg time %lf \n", (float)avg_hops/total_finished_packets, avg_time/(total_finished_packets*1000), max_time/1000, avg_time); printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us avg message size %lf bytes \n", (float)avg_hops/total_finished_chunks, avg_time/(total_finished_packets*1000), max_time/1000, (float)total_msg_sz/N_finished_msgs);
printf("\n ADAPTIVE ROUTING STATS: %d percent packets routed minimally %d percent packets routed non-minimally completed packets %d ", total_minimal_packets, total_nonmin_packets, total_completed_packets); printf("\n ADAPTIVE ROUTING STATS: %d percent chunks routed minimally %d percent chunks routed non-minimally completed packets %d ", total_minimal_packets, total_nonmin_packets, total_finished_chunks);
return; return;
...@@ -1245,7 +1251,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1245,7 +1251,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
term_rev_ecount++; term_rev_ecount++;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
completed_packets--;
if(msg->path_type == MINIMAL) if(msg->path_type == MINIMAL)
minimal_count--; minimal_count--;
if(msg->path_type == NON_MINIMAL) if(msg->path_type == NON_MINIMAL)
...@@ -1254,7 +1259,11 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1254,7 +1259,11 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
s->next_credit_available_time = msg->saved_credit_time; s->next_credit_available_time = msg->saved_credit_time;
uint64_t num_chunks = msg->packet_size / s->params->chunk_size; uint64_t num_chunks = msg->packet_size / s->params->chunk_size;
if(msg->chunk_id == num_chunks - 1) N_finished_chunks--;
total_hops -= msg->my_N_hop;
/*if(msg->chunk_id == num_chunks - 1)
mn_stats* stat; mn_stats* stat;
stat = model_net_find_stats(msg->category, s->dragonfly_stats_array); stat = model_net_find_stats(msg->category, s->dragonfly_stats_array);
...@@ -1262,7 +1271,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1262,7 +1271,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
stat->recv_bytes -= msg->packet_size; stat->recv_bytes -= msg->packet_size;
stat->recv_time -= tw_now(lp) - msg->travel_start_time; stat->recv_time -= tw_now(lp) - msg->travel_start_time;
N_finished_packets--; N_finished_packets--;
...@@ -1277,8 +1285,8 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1277,8 +1285,8 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
int net_id = model_net_get_id(LP_METHOD_NM); int net_id = model_net_get_id(LP_METHOD_NM);
model_net_event_rc(net_id, lp, msg->pull_size); model_net_event_rc(net_id, lp, msg->pull_size);
/*struct qhash_head * hash_link = NULL; struct qhash_head * hash_link = NULL;
struct dfly_qhash_entry * tmp = NULL; struct dfly_qhash_entry * tmp = NULL;
struct dfly_hash_key key; struct dfly_hash_key key;
...@@ -1288,17 +1296,16 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1288,17 +1296,16 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
hash_link = qhash_search(s->rank_tbl, &key); hash_link = qhash_search(s->rank_tbl, &key);
tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link); tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link);
mn_stats* stat;
if(bf->c1) if(bf->c1)
mn_stats* stat;
stat->recv_count--; stat->recv_count--;
s->finished_packets--; s->finished_packets--;
dragonfly_total_time -= (tw_now(lp) - msg->travel_start_time);
if(bf->c3) if(bf->c3)
...@@ -1308,8 +1315,13 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1308,8 +1315,13 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
if(bf->c7) if(bf->c7)
s->finished_msgs--; s->finished_msgs--;
total_msg_sz -= msg->total_size;
N_finished_msgs--;
s->total_msg_time -= (tw_now(lp) - msg->msg_start_time); s->total_msg_time -= (tw_now(lp) - msg->msg_start_time);
s->total_msg_size -= msg->total_size; s->total_msg_size -= msg->total_size;
struct dfly_qhash_entry * d_entry_pop = (struct dfly_qhash_entry*)rc_stack_pop(s->st); struct dfly_qhash_entry * d_entry_pop = (struct dfly_qhash_entry*)rc_stack_pop(s->st);
qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link));
...@@ -1318,15 +1330,13 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1318,15 +1330,13 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
hash_link = &(d_entry_pop->hash_link); hash_link = &(d_entry_pop->hash_link);
tmp = d_entry_pop; tmp = d_entry_pop;
if(bf->c4) if(bf->c4)
model_net_event_rc2(lp, &msg->event_rc); model_net_event_rc2(lp, &msg->event_rc);
assert(tmp); assert(tmp);
tmp->num_chunks--; tmp->num_chunks--;
return; return;
void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, tw_bf * bf, char * event_data, int remote_event_size) void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, tw_bf * bf, char * event_data, int remote_event_size)
...@@ -1367,9 +1377,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1367,9 +1377,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
tw_stime ts = g_tw_lookahead + s->params->credit_delay + tw_rand_unif(lp->rng); tw_stime ts = g_tw_lookahead + s->params->credit_delay + tw_rand_unif(lp->rng);
if(msg->packet_ID == TRACK && msg->message_id == TRACK_MSG)
printf("\n terminal sending credit at chan %d ", msg->saved_vc);
// no method_event here - message going to router // no method_event here - message going to router
tw_event * buf_e; tw_event * buf_e;
terminal_message * buf_msg; terminal_message * buf_msg;
...@@ -1382,17 +1389,15 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1382,17 +1389,15 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
tw_event_send(buf_e); tw_event_send(buf_e);
bf->c1 = 0; bf->c1 = 0;
bf->c2 = 0; bf->c3 = 0;
bf->c4 = 0; bf->c4 = 0;
bf->c5 = 0;
bf->c6 = 0;
bf->c7 = 0; bf->c7 = 0;
bf->c8 = 0;
N_finished_chunks++;
/* WE do not allow self messages through dragonfly */ /* WE do not allow self messages through dragonfly */
assert(lp->gid != msg->src_terminal_id); assert(lp->gid != msg->src_terminal_id);
int is_last_msg = 0;
int num_chunks = msg->packet_size / s->params->chunk_size; int num_chunks = msg->packet_size / s->params->chunk_size;
uint64_t total_chunks = msg->total_size / s->params->chunk_size; uint64_t total_chunks = msg->total_size / s->params->chunk_size;
...@@ -1408,8 +1413,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1408,8 +1413,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(!num_chunks) if(!num_chunks)
num_chunks = 1; num_chunks = 1;
completed_packets++;
minimal_count++; minimal_count++;
...@@ -1419,6 +1422,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1419,6 +1422,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(msg->path_type != MINIMAL && msg->path_type != NON_MINIMAL) if(msg->path_type != MINIMAL && msg->path_type != NON_MINIMAL)
printf("\n Wrong message path type %d ", msg->path_type); printf("\n Wrong message path type %d ", msg->path_type);
total_hops += msg->my_N_hop;
#if DEBUG == 1 #if DEBUG == 1
if( msg->packet_ID == TRACK if( msg->packet_ID == TRACK
&& msg->chunk_id == num_chunks-1 && msg->chunk_id == num_chunks-1
...@@ -1434,7 +1438,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1434,7 +1438,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
#endif #endif
tw_event * e; /*tw_event * e;
terminal_message * m; terminal_message * m;
if(msg->chunk_id == num_chunks-1) if(msg->chunk_id == num_chunks-1)
...@@ -1474,13 +1478,12 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1474,13 +1478,12 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
tw_event_send(e); tw_event_send(e);
/* Now retreieve the number of chunks completed from the hash and update /* Now retreieve the number of chunks completed from the hash and update
* them */ * them */
/*void *m_data_src = model_net_method_get_edata(DRAGONFLY, msg); void *m_data_src = model_net_method_get_edata(DRAGONFLY, msg);
struct qhash_head *hash_link = NULL; struct qhash_head *hash_link = NULL;
key.message_id = msg->message_id; key.message_id = msg->message_id;
key.sender_id = msg->sender_lp; key.sender_id = msg->sender_lp;
...@@ -1488,14 +1491,15 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1488,14 +1491,15 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
*//* If an entry does not exist then create one */ /* If an entry does not exist then create one */
/*if(!hash_link) if(!hash_link)
bf->c5 = 1; bf->c5 = 1;
struct dfly_qhash_entry * d_entry = malloc(sizeof (struct dfly_qhash_entry)); struct dfly_qhash_entry * d_entry = malloc(sizeof (struct dfly_qhash_entry));
d_entry->num_chunks = 0; d_entry->num_chunks = 0;
d_entry->key = key; d_entry->key = key;
d_entry->remote_event_data = NULL; d_entry->remote_event_data = NULL;
d_entry->remote_event_size = 0;
qhash_add(s->rank_tbl, &key, &(d_entry->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry->hash_link));
s->rank_tbl_pop++; s->rank_tbl_pop++;
...@@ -1506,61 +1510,53 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1506,61 +1510,53 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
tmp->num_chunks++; tmp->num_chunks++;
if(tmp->num_chunks >= total_chunks) mn_stats* stat = model_net_find_stats(msg->category, s->dragonfly_stats_array);
is_last_msg = 1;
*//* if its the last chunk of the packet then handle the remote event data */ /* if its the last chunk of the packet then handle the remote event data */
/*if(msg->chunk_id == num_chunks - 1) if(msg->chunk_id == num_chunks - 1)
bf->c1 = 1; bf->c1 = 1;
stat->recv_count++; stat->recv_count++;
stat->recv_bytes += msg->packet_size; stat->recv_bytes += msg->packet_size;
stat->recv_time += tw_now(lp) - msg->travel_start_time;
N_finished_packets++; N_finished_packets++;
s->finished_packets++; s->finished_packets++;
dragonfly_total_time += tw_now( lp ) - msg->travel_start_time;
if (dragonfly_max_latency < tw_now( lp ) - msg->travel_start_time) {
bf->c3 = 1;
msg->saved_available_time = dragonfly_max_latency;
dragonfly_max_latency = tw_now( lp ) - msg->travel_start_time;
if(msg->remote_event_size_bytes > 0 && !tmp->remote_event_data) if(msg->remote_event_size_bytes > 0 && !tmp->remote_event_data)
*//* Retreive the remote event entry */ /* Retreive the remote event entry */
/*tmp->remote_event_data = (void*)malloc(msg->remote_event_size_bytes); tmp->remote_event_data = (void*)malloc(msg->remote_event_size_bytes);
assert(tmp->remote_event_data); assert(tmp->remote_event_data);
tmp->remote_event_size = msg->remote_event_size_bytes; tmp->remote_event_size = msg->remote_event_size_bytes;
memcpy(tmp->remote_event_data, m_data_src, msg->remote_event_size_bytes); memcpy(tmp->remote_event_data, m_data_src, msg->remote_event_size_bytes);
/* If all chunks of a message have arrived then send a remote event to the /* If all chunks of a message have arrived then send a remote event to the
* callee*/ * callee*/
/*if(is_last_msg) if(tmp->num_chunks >= total_chunks)
bf->c7 = 1; bf->c7 = 1;
N_finished_msgs++;
total_msg_sz += msg->total_size;
s->finished_msgs++; s->finished_msgs++;
s->total_msg_time += (tw_now(lp) - msg->msg_start_time); s->total_msg_time += (tw_now(lp) - msg->msg_start_time);
s->total_msg_size += msg->total_size; s->total_msg_size += msg->total_size;
if(msg->remote_event_size_bytes > 0) if (dragonfly_max_latency < tw_now( lp ) - msg->travel_start_time) {
{ bf->c3 = 1;
send_remote_event(s, msg, lp, bf, m_data_src, msg->remote_event_size_bytes); msg->saved_available_time = dragonfly_max_latency;
} dragonfly_max_latency = tw_now( lp ) - msg->travel_start_time;
else
void *m_data = model_net_method_get_edata(DRAGONFLY, msg);
send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size);
*//* Remove the hash entry */ assert(tmp->remote_event_data && tmp->remote_event_size);
/*qhash_del(hash_link); send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size);
rc_stack_push(lp, tmp, free_tmp, s->st); rc_stack_push(lp, tmp, free_tmp, s->st);
s->rank_tbl_pop--; s->rank_tbl_pop--;
return; return;
...@@ -2188,8 +2184,8 @@ static int do_adaptive_routing( router_state * s, ...@@ -2188,8 +2184,8 @@ static int do_adaptive_routing( router_state * s,
int min_port_count = s->vc_occupancy[minimal_out_port][min_vc]; int min_port_count = s->vc_occupancy[minimal_out_port][min_vc];
// Now get the expected number of hops to be traversed for both routes // Now get the expected number of hops to be traversed for both routes
int num_min_hops = get_num_hops(s->router_id, dest_router_id, //int num_min_hops = get_num_hops(s->router_id, dest_router_id,
s->params->num_routers, 0, s->params->num_groups); // s->params->num_routers, 0, s->params->num_groups);
int intm_router_id = getRouterFromGroupID(intm_id, int intm_router_id = getRouterFromGroupID(intm_id,
s->router_id / s->params->num_routers, s->params->num_routers, s->router_id / s->params->num_routers, s->params->num_routers,
...@@ -2213,16 +2209,16 @@ static int do_adaptive_routing( router_state * s, ...@@ -2213,16 +2209,16 @@ static int do_adaptive_routing( router_state * s,
q_avg = q_avg / (s->params->radix - 1); q_avg = q_avg / (s->params->radix - 1);
int min_out_chan = minimal_out_port; //int min_out_chan = minimal_out_port;
int nonmin_out_chan = nonmin_out_port; //int nonmin_out_chan = nonmin_out_port;
/* Adding history window approach, not taking the queue status at every /* Adding history window approach, not taking the queue status at every
* simulation time thats why, we are maintaining the current history * simulation time thats why, we are maintaining the current history
* window number and an average of the previous history window number. */ * window number and an average of the previous history window number. */
int min_hist_count = s->cur_hist_num[min_out_chan] + //int min_hist_count = s->cur_hist_num[min_out_chan] +
(s->prev_hist_num[min_out_chan]/2); // (s->prev_hist_num[min_out_chan]/2);
int nonmin_hist_count = s->cur_hist_num[nonmin_out_chan] + //int nonmin_hist_count = s->cur_hist_num[nonmin_out_chan] +
int nonmin_port_count = s->vc_occupancy[nonmin_out_port][nomin_vc]; int nonmin_port_count = s->vc_occupancy[nonmin_out_port][nomin_vc];
//if(num_min_hops * (min_port_count - min_hist_count) <= (num_nonmin_hops * ((q_avg + 1) - nonmin_hist_count))) { //if(num_min_hops * (min_port_count - min_hist_count) <= (num_nonmin_hops * ((q_avg + 1) - nonmin_hist_count))) {
Markdown is supported
0% or .
Please register or to comment
