Commit e126fea1 authored by Francois Tessier's avatar Francois Tessier
Browse files
Merge branch 'master' of xgitlab.cels.anl.gov:ftessier/TAPIOCA
parents 84616544 4b562591
...@@ -193,8 +193,10 @@ int Tapioca::Write (MPI_File fileHandle, MPI_Offset offset, void *buf, ...@@ -193,8 +193,10 @@ int Tapioca::Write (MPI_File fileHandle, MPI_Offset offset, void *buf,
while ( this->roundsIds[targetRoundIdx] > this->currentRound_ ) { while ( this->roundsIds[targetRoundIdx] > this->currentRound_ ) {
for ( i = 0; i < this->nAggr_ ; i++ ) { for ( i = 0; i < this->nAggr_ ; i++ ) {
fprintf (stdout, "[INFO] %d calls 1st GlobalFence, buff %d, dat %s (r: %d)\n", this->commRank_, (this->currentRound_ % NBUFFERS), var, this->currentRound_); fprintf (stdout, "[INFO] %d calls 1st GlobalFence, buff %d, dat %s (r: %d, f: %d)\n", this->commRank_, (this->currentRound_ % NBUFFERS), var, this->currentRound_, this->currentFence_);
this->GlobalFence (var); this->GlobalFence (var);
fprintf (stdout, "[INFO] %d passes 1st GlobalFence, buff %d, dat %s (r: %d, f: %d)\n", this->commRank_, (this->currentRound_ % NBUFFERS), var, this->currentRound_, this->currentFence_);
this->currentFence_++;
this->roundCounter_++; this->roundCounter_++;
...@@ -241,8 +243,10 @@ int Tapioca::Write (MPI_File fileHandle, MPI_Offset offset, void *buf, ...@@ -241,8 +243,10 @@ int Tapioca::Write (MPI_File fileHandle, MPI_Offset offset, void *buf,
if ( this->currentDataSize_ == this->rankDataSize_) { if ( this->currentDataSize_ == this->rankDataSize_) {
while ( this->roundCounter_ < this->totalRounds_) { while ( this->roundCounter_ < this->totalRounds_) {
fprintf (stdout, "[INFO] %d calls 2nt GlobalFence, buff %d, dat %s (r: %d)\n", this->commRank_, (this->currentRound_ % NBUFFERS), var, this->currentRound_); fprintf (stdout, "[INFO] %d calls 2nd GlobalFence, buff %d, dat %s (r: %d, f: %d)\n", this->commRank_, (this->currentRound_ % NBUFFERS), var, this->currentRound_, this->currentFence_);
fprintf (stdout, "[INFO] %d passes 2nd GlobalFence, buff %d, dat %s (r: %d, f: %d)\n", this->commRank_, (this->currentRound_ % NBUFFERS), var, this->currentRound_, this->currentFence_);
if ( (this->roundCounter_ % this->nAggr_) == 0 ) { if ( (this->roundCounter_ % this->nAggr_) == 0 ) {
if ( this->amAnAggr_ ) { if ( this->amAnAggr_ ) {
...@@ -253,7 +257,7 @@ int Tapioca::Write (MPI_File fileHandle, MPI_Offset offset, void *buf, ...@@ -253,7 +257,7 @@ int Tapioca::Write (MPI_File fileHandle, MPI_Offset offset, void *buf,
//this->iPush (fileHandle, &iRequest); //this->iPush (fileHandle, &iRequest);
fprintf (stdout, "[INFO] %d increment 2nd currentRound (r: %d)\n", this->commRank_, this->currentRound_); fprintf (stdout, "[INFO] %d increment 2nd currentRound (r: %d, rc: %d, nag: %d)\n", this->commRank_, this->currentRound_, this->roundCounter_, this->nAggr_);
this->currentRound_++; this->currentRound_++;
...@@ -416,6 +420,8 @@ void Tapioca::SetDefaultValues () ...@@ -416,6 +420,8 @@ void Tapioca::SetDefaultValues ()
this->currentDataSize_ = 0; this->currentDataSize_ = 0;
this->nCommit_ = 0; this->nCommit_ = 0;
this->writeDevNull_ = false; this->writeDevNull_ = false;
/* DEBUG */
this->currentFence_ = 1;
...@@ -176,6 +176,9 @@ class Tapioca ...@@ -176,6 +176,9 @@ class Tapioca
/* TIMING */ /* TIMING */
double startAggrTime, endAggrTime, totAggrTime; double startAggrTime, endAggrTime, totAggrTime;
double startIOTime, endIOTime, totIOTime; double startIOTime, endIOTime, totIOTime;
/* DEBUG */
int currentFence_;
#endif /* AGGREGATION_H */ #endif /* AGGREGATION_H */
Markdown is supported
0% or .
Please register or to comment
