Commit 563bf08f authored by Philip Carns's avatar Philip Carns
comment out some infrequently used benchmark routines
git-svn-id: https://svn.mcs.anl.gov/repos/darshan/trunk@79 3b7491f3-a168-0410-bf4b-c445ed680a29
parent fe7739f0
...@@ -1276,6 +1276,7 @@ static void cp_access_counter(struct darshan_file_runtime* file, ssize_t size, e ...@@ -1276,6 +1276,7 @@ static void cp_access_counter(struct darshan_file_runtime* file, ssize_t size, e
return; return;
#if 0
void darshan_shutdown_bench(int argc, char** argv, int rank, int nprocs) void darshan_shutdown_bench(int argc, char** argv, int rank, int nprocs)
int* fd_array; int* fd_array;
...@@ -1503,6 +1504,7 @@ void darshan_search_bench(int argc, char** argv, int iters) ...@@ -1503,6 +1504,7 @@ void darshan_search_bench(int argc, char** argv, int iters)
free(fd_array); free(fd_array);
free(size_array); free(size_array);
#endif
double darshan_wtime(void) double darshan_wtime(void)
Markdown is supported
0% or
Please register or to comment
