Commit e9d2b236 authored by Philip Carns's avatar Philip Carns
implement --perf mode for stdio module
parent b904f795
...@@ -113,6 +113,8 @@ void mpiio_calc_file(hash_entry_t *file_hash, file_data_t *fdata); ...@@ -113,6 +113,8 @@ void mpiio_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
void mpiio_print_total_file(struct darshan_mpiio_file *mfile); void mpiio_print_total_file(struct darshan_mpiio_file *mfile);
void mpiio_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag); void mpiio_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
void stdio_accum_perf(struct darshan_stdio_file *pfile, perf_data_t *pdata);
void calc_perf(perf_data_t *pdata, int64_t nprocs); void calc_perf(perf_data_t *pdata, int64_t nprocs);
int usage (char *exename) int usage (char *exename)
...@@ -389,9 +391,10 @@ int main(int argc, char **argv) ...@@ -389,9 +391,10 @@ int main(int argc, char **argv)
"for module %s, SKIPPING.\n", darshan_module_names[i]); "for module %s, SKIPPING.\n", darshan_module_names[i]);
continue; continue;
/* currently we only do base parsing for non MPI & POSIX modules */ /* currently only POSIX, MPIIO, and STDIO modules support non-base
else if((i != DARSHAN_POSIX_MOD) && (i != DARSHAN_MPIIO_MOD) && * parsing
!(mask & OPTION_BASE)) */
else if((i != DARSHAN_POSIX_MOD) && (i != DARSHAN_MPIIO_MOD) && (i != DARSHAN_STDIO_MOD) && !(mask & OPTION_BASE))
continue; continue;
/* this module has data to be parsed and printed */ /* this module has data to be parsed and printed */
...@@ -470,10 +473,10 @@ int main(int argc, char **argv) ...@@ -470,10 +473,10 @@ int main(int argc, char **argv)
mnt_pt, fs_type, fd->mod_ver[i]); mnt_pt, fs_type, fd->mod_ver[i]);
/* we calculate more detailed stats for POSIX and MPI-IO modules, /* we calculate more detailed stats for POSIX, MPI-IO, and STDIO modules,
* if the parser is executed with more than the base option * if the parser is executed with more than the base option
if(i != DARSHAN_POSIX_MOD && i != DARSHAN_MPIIO_MOD) if(i != DARSHAN_POSIX_MOD && i != DARSHAN_MPIIO_MOD && i != DARSHAN_STDIO_MOD)
continue; continue;
HASH_FIND(hlink, file_hash, &(base_rec->id), sizeof(darshan_record_id), hfile); HASH_FIND(hlink, file_hash, &(base_rec->id), sizeof(darshan_record_id), hfile);
...@@ -510,6 +513,10 @@ int main(int argc, char **argv) ...@@ -510,6 +513,10 @@ int main(int argc, char **argv)
mpiio_accum_file((struct darshan_mpiio_file*)mod_buf, hfile, job.nprocs); mpiio_accum_file((struct darshan_mpiio_file*)mod_buf, hfile, job.nprocs);
mpiio_accum_perf((struct darshan_mpiio_file*)mod_buf, &pdata); mpiio_accum_perf((struct darshan_mpiio_file*)mod_buf, &pdata);
else if(i == DARSHAN_STDIO_MOD)
stdio_accum_perf((struct darshan_stdio_file*)mod_buf, &pdata);
memset(mod_buf, 0, DEF_MOD_BUF_SIZE); memset(mod_buf, 0, DEF_MOD_BUF_SIZE);
...@@ -523,7 +530,7 @@ int main(int argc, char **argv) ...@@ -523,7 +530,7 @@ int main(int argc, char **argv)
/* we calculate more detailed stats for POSIX and MPI-IO modules, /* we calculate more detailed stats for POSIX and MPI-IO modules,
continue; continue;
/* Total Calc */ /* Total Calc */
...@@ -1042,6 +1049,89 @@ void mpiio_accum_file(struct darshan_mpiio_file *mfile, ...@@ -1042,6 +1049,89 @@ void mpiio_accum_file(struct darshan_mpiio_file *mfile,
return; return;
perf_data_t *pdata)
pdata->total_bytes += pfile->counters[STDIO_BYTES_READ] +
pfile->counters[STDIO_BYTES_WRITTEN];
* Calculation of Shared File Time
* Four Methods!!!!
* by_cumul: sum time counters and divide by nprocs
* (inaccurate if lots of variance between procs)
* by_open: difference between timestamp of open and close
* (inaccurate if file is left open without i/o happening)
* by_open_lastio: difference between timestamp of open and the
* timestamp of last i/o
* (similar to above but fixes case where file is left
* open after io is complete)
* by_slowest: use slowest rank time from log data
* (most accurate but requires newer log version)
if(pfile->base_rec.rank == -1)
/* by_open */
if(pfile->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] >
pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
pdata->shared_time_by_open +=
pfile->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] -
pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP];
/* by_open_lastio */
if(pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] >
pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP])
/* be careful: file may have been opened but not read or written */
if(pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] > pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
pdata->shared_time_by_open_lastio +=
pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] -
else
if(pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP] > pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP] -
pdata->shared_time_by_cumul +=
pfile->fcounters[STDIO_F_META_TIME] +
pfile->fcounters[STDIO_F_READ_TIME] +
pfile->fcounters[STDIO_F_WRITE_TIME];
pdata->shared_meta_time += pfile->fcounters[STDIO_F_META_TIME];
/* by_slowest */
pdata->shared_time_by_slowest +=
pfile->fcounters[STDIO_F_SLOWEST_RANK_TIME];
* Calculation of Unique File Time
* record the data for each file and sum it
else
pdata->rank_cumul_io_time[pfile->base_rec.rank] +=
(pfile->fcounters[STDIO_F_META_TIME] +
pfile->fcounters[STDIO_F_WRITE_TIME]);
pdata->rank_cumul_md_time[pfile->base_rec.rank] +=
return;
void posix_accum_perf(struct darshan_posix_file *pfile, void posix_accum_perf(struct darshan_posix_file *pfile,
perf_data_t *pdata) perf_data_t *pdata)
Markdown is supported
0%
or
Please register or to comment
