Commit 5c5918aa authored by Shane Snyder's avatar Shane Snyder
add LD_PRELOAD functionality
parent 90c39ea6
...@@ -33,10 +33,16 @@ LIBS = -lz @LIBBZ2@ ...@@ -33,10 +33,16 @@ LIBS = -lz @LIBBZ2@
lib:: lib::
@mkdir -p $@ @mkdir -p $@
lib/darshan-core.o: lib/darshan-core.c darshan-core.h $(DARSHAN_LOG_FORMAT) | lib lib/darshan-core-init-finalize.o: lib/darshan-core-init-finalize.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
$(CC) $(CFLAGS) -c $< -o $@ $(CC) $(CFLAGS) -c $< -o $@
lib/darshan-core.po: lib/darshan-core.c darshan-core.h $(DARSHAN_LOG_FORMAT) | lib lib/darshan-core-init-finalize.po: lib/darshan-core-init-finalize.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
$(CC) $(CFLAGS_SHARED) -c $< -o $@
lib/darshan-core.o: lib/darshan-core.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
lib/darshan-core.po: lib/darshan-core.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
$(CC) $(CFLAGS_SHARED) -c $< -o $@ $(CC) $(CFLAGS_SHARED) -c $< -o $@
lib/darshan-common.o: lib/darshan-common.c darshan.h $(DARSHAN_LOG_FORMAT) | lib lib/darshan-common.o: lib/darshan-common.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
...@@ -72,10 +78,10 @@ lib/lookup8.po: lib/lookup8.c ...@@ -72,10 +78,10 @@ lib/lookup8.po: lib/lookup8.c
#%.i: %.c #%.i: %.c
# $(CC) -E $(CFLAGS) -c $< -o $@ # $(CC) -E $(CFLAGS) -c $< -o $@
lib/libdarshan.a: lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-core.o lib/darshan-common.o lib/lookup3.o lib/lookup8.o lib/libdarshan.a: lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darshan-common.o lib/darshan-posix.o lib/darshan-mpiio.o lib/lookup3.o lib/lookup8.o
ar rcs $@ $^ ar rcs $@ $^
lib/libdarshan.so: lib/darshan-core.po lib/darshan-common.po lib/darshan-posix.po lib/darshan-mpiio.po lib/lookup3.po lib/lookup8.po lib/libdarshan.so: lib/darshan-core-init-finalize.po lib/darshan-core.po lib/darshan-common.po lib/darshan-posix.po lib/darshan-mpiio.po lib/lookup3.po lib/lookup8.po
$(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ -lpthread -lrt -lz -ldl $(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ -lpthread -lrt -lz -ldl
install:: all install:: all
...@@ -687,7 +687,6 @@ with_zlib ...@@ -687,7 +687,6 @@ with_zlib
enable_cuserid enable_cuserid
enable_ld_preload enable_ld_preload
enable_group_readable_logs enable_group_readable_logs
enable_stat_at_open
with_mem_align with_mem_align
with_log_path_by_env with_log_path_by_env
with_log_hints with_log_hints
...@@ -1315,7 +1314,6 @@ Optional Features: ...@@ -1315,7 +1314,6 @@ Optional Features:
--disable-cuserid Disables attempted use of cuserid() at run time --disable-cuserid Disables attempted use of cuserid() at run time
--disable-ld-preload Disables support for LD_PRELOAD library --disable-ld-preload Disables support for LD_PRELOAD library
--enable-group-readable-logs Set log files to be group readable --enable-group-readable-logs Set log files to be group readable
--enable-stat-at-open Perform stat() call at open time to gather extra statistics
Optional Packages: Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes] --with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
...@@ -3567,17 +3565,6 @@ fi ...@@ -3567,17 +3565,6 @@ fi
fi fi
# Check whether --enable-stat-at-open was given.
if test "${enable_stat_at_open+set}" = set; then :
enableval=$enable_stat_at_open; if test "x$enableval" = "xyes" ; then
$as_echo "#define __CP_STAT_AT_OPEN 1" >>confdefs.h
fi
fi
# Check whether --with-mem-align was given. # Check whether --with-mem-align was given.
if test "${with_mem_align+set}" = set; then : if test "${with_mem_align+set}" = set; then :
...@@ -11,7 +11,8 @@ ...@@ -11,7 +11,8 @@
#include <sys/types.h> #include <sys/types.h>
#include <stdint.h> #include <stdint.h>
#include "darshan.h" #include "uthash.h"
#include "darshan-log-format.h"
#define DARSHAN_CORE_MAX_RECORDS 1024 #define DARSHAN_CORE_MAX_RECORDS 1024
...@@ -50,6 +51,9 @@ struct darshan_core_record_ref ...@@ -50,6 +51,9 @@ struct darshan_core_record_ref
UT_hash_handle hlink; UT_hash_handle hlink;
void darshan_core_initialize(int argc, char **argv);
void darshan_core_shutdown(void);
uint32_t darshan_hashlittle(const void *key, size_t length, uint32_t initval); uint32_t darshan_hashlittle(const void *key, size_t length, uint32_t initval);
uint64_t darshan_hash(const register unsigned char *k, register uint64_t length, register uint64_t level); uint64_t darshan_hash(const register unsigned char *k, register uint64_t length, register uint64_t level);
...@@ -9,16 +9,10 @@ ...@@ -9,16 +9,10 @@
#ifdef DARSHAN_PRELOAD #ifdef DARSHAN_PRELOAD
#include <dlfcn.h>
#include <stdlib.h>
#define DARSHAN_MPI_CALL(func) __real_ ## func
#define DARSHAN_EXTERN_DECL(name,ret,args) \ #define DARSHAN_EXTERN_DECL(name,ret,args) \
extern ret (*__real_ ## name)args; extern ret (*__real_ ## name)args;
DARSHAN_EXTERN_DECL(PMPI_File_close, int, (MPI_File *fh)); DARSHAN_EXTERN_DECL(PMPI_File_close, int, (MPI_File *fh));
DARSHAN_EXTERN_DECL(PMPI_File_set_size, int, (MPI_File fh, MPI_Offset size));
DARSHAN_EXTERN_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request)); DARSHAN_EXTERN_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
DARSHAN_EXTERN_DECL(PMPI_File_iread, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request)); DARSHAN_EXTERN_DECL(PMPI_File_iread, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
DARSHAN_EXTERN_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request)); DARSHAN_EXTERN_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
...@@ -105,7 +99,6 @@ DARSHAN_EXTERN_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int co ...@@ -105,7 +99,6 @@ DARSHAN_EXTERN_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int co
DARSHAN_EXTERN_DECL(PMPI_Finalize, int, ()); DARSHAN_EXTERN_DECL(PMPI_Finalize, int, ());
DARSHAN_EXTERN_DECL(PMPI_Init, int, (int *argc, char ***argv)); DARSHAN_EXTERN_DECL(PMPI_Init, int, (int *argc, char ***argv));
DARSHAN_EXTERN_DECL(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided)); DARSHAN_EXTERN_DECL(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided));
DARSHAN_EXTERN_DECL(PMPI_Wtime, double, ()); DARSHAN_EXTERN_DECL(PMPI_Wtime, double, ());
DARSHAN_EXTERN_DECL(PMPI_Allreduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)); DARSHAN_EXTERN_DECL(PMPI_Allreduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
DARSHAN_EXTERN_DECL(PMPI_Bcast, int, (void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)); DARSHAN_EXTERN_DECL(PMPI_Bcast, int, (void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm));
...@@ -117,16 +110,14 @@ DARSHAN_EXTERN_DECL(PMPI_Type_contiguous, int, (int count, MPI_Datatype oldtype, ...@@ -117,16 +110,14 @@ DARSHAN_EXTERN_DECL(PMPI_Type_contiguous, int, (int count, MPI_Datatype oldtype,
DARSHAN_EXTERN_DECL(PMPI_Type_extent, int, (MPI_Datatype datatype, MPI_Aint *extent)); DARSHAN_EXTERN_DECL(PMPI_Type_extent, int, (MPI_Datatype datatype, MPI_Aint *extent));
DARSHAN_EXTERN_DECL(PMPI_Type_free, int, (MPI_Datatype *datatype)); DARSHAN_EXTERN_DECL(PMPI_Type_free, int, (MPI_Datatype *datatype));
DARSHAN_EXTERN_DECL(PMPI_Type_hindexed, int, (int count, int *array_of_blocklengths, MPI_Aint *array_of_displacements, MPI_Datatype oldtype, MPI_Datatype *newtype)); DARSHAN_EXTERN_DECL(PMPI_Type_hindexed, int, (int count, int *array_of_blocklengths, MPI_Aint *array_of_displacements, MPI_Datatype oldtype, MPI_Datatype *newtype));
DARSHAN_EXTERN_DECL(PMPI_Type_get_envelope, int, (MPI_Datatype datatype, int *num_integers, int *num_addresses, int *num_datatypes, int *combiner));
DARSHAN_EXTERN_DECL(PMPI_Type_size, int, (MPI_Datatype datatype, int *size));
DARSHAN_EXTERN_DECL(PMPI_Op_create, int, (MPI_User_function *function, int commute, MPI_Op *op)); DARSHAN_EXTERN_DECL(PMPI_Op_create, int, (MPI_User_function *function, int commute, MPI_Op *op));
DARSHAN_EXTERN_DECL(PMPI_Op_free, int, (MPI_Op *op)); DARSHAN_EXTERN_DECL(PMPI_Op_free, int, (MPI_Op *op));
DARSHAN_EXTERN_DECL(PMPI_Reduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm)); DARSHAN_EXTERN_DECL(PMPI_Reduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm));
DARSHAN_EXTERN_DECL(PMPI_Type_get_envelope, int, (MPI_Datatype datatype, int *num_integers, int *num_addresses, int *num_datatypes, int *combiner)); DARSHAN_EXTERN_DECL(PMPI_Send, int, (void *buf, int count, MPI_Datatype datatype, int dest, int tag, MPI_Comm comm));
DARSHAN_EXTERN_DECL(PMPI_Type_size, int, (MPI_Datatype datatype, int *size)); DARSHAN_EXTERN_DECL(PMPI_Recv, int, (void *buf, int count, MPI_Datatype datatype, int source, int tag, MPI_Comm comm, MPI_Status *status));
#else
#define DARSHAN_MPI_CALL(func) func
#endif #endif
#endif #endif /* __DARSHAN_DYNAMIC_H */
...@@ -105,9 +105,5 @@ ...@@ -105,9 +105,5 @@
/* Memory alignment in bytes */ /* Memory alignment in bytes */
#undef __CP_MEM_ALIGNMENT #undef __CP_MEM_ALIGNMENT
/* Define if Darshan should stat files at open time to collect extra
statistics */
#undef __CP_STAT_AT_OPEN
/* Generalized request type for MPI-IO */ /* Generalized request type for MPI-IO */
#undef __D_MPI_REQUEST #undef __D_MPI_REQUEST
...@@ -30,12 +30,12 @@ ...@@ -30,12 +30,12 @@
* consistently regardless of whether static or dynamic linking is used * consistently regardless of whether static or dynamic linking is used
#define __USE_GNU
#include <dlfcn.h> #include <dlfcn.h>
#include <stdlib.h> #include <stdlib.h>
#define DARSHAN_FORWARD_DECL(name,ret,args) \ #define DARSHAN_FORWARD_DECL(name,ret,args) \
ret (*__real_ ## name)args = NULL; ret (*__real_ ## name)args = NULL
#define DARSHAN_DECL(__name) __name #define DARSHAN_DECL(__name) __name
This diff is collapsed.
...@@ -26,7 +26,9 @@ ...@@ -26,7 +26,9 @@
#include <assert.h> #include <assert.h>
#include "uthash.h" #include "uthash.h"
#include "darshan-core.h" #include "darshan-core.h"
#include "darshan-dynamic.h"
extern char* __progname; extern char* __progname;
extern char* __progname_full; extern char* __progname_full;
...@@ -70,12 +72,6 @@ static struct mnt_data mnt_data_array[DARSHAN_MAX_MNTS]; ...@@ -70,12 +72,6 @@ static struct mnt_data mnt_data_array[DARSHAN_MAX_MNTS];
static int mnt_data_count = 0; static int mnt_data_count = 0;
/* prototypes for internal helper functions */ /* prototypes for internal helper functions */
static void darshan_core_initialize(
static void darshan_core_shutdown(
void);
static void darshan_core_cleanup(
struct darshan_core_runtime* core);
static void darshan_get_logfile_name( static void darshan_get_logfile_name(
char* logfile_name, int jobid, struct tm* start_tm); char* logfile_name, int jobid, struct tm* start_tm);
static void darshan_log_record_hints_and_ver( static void darshan_log_record_hints_and_ver(
...@@ -100,67 +96,12 @@ static int darshan_log_write_record_hash( ...@@ -100,67 +96,12 @@ static int darshan_log_write_record_hash(
static int darshan_log_append_all( static int darshan_log_append_all(
MPI_File log_fh, struct darshan_core_runtime *core, void *buf, MPI_File log_fh, struct darshan_core_runtime *core, void *buf,
int count, uint64_t *inout_off, uint64_t *agg_uncomp_sz); int count, uint64_t *inout_off, uint64_t *agg_uncomp_sz);
/* intercept MPI initialize and finalize to manage darshan core runtime */ struct darshan_core_runtime* core);
int MPI_Init(int *argc, char ***argv)
int ret;
ret = DARSHAN_MPI_CALL(PMPI_Init)(argc, argv);
if(ret != MPI_SUCCESS)
return(ret);
if(argc && argv)
darshan_core_initialize(*argc, *argv);
else
/* we don't see argc and argv here in fortran */
darshan_core_initialize(0, NULL);
return(ret);
int MPI_Init_thread(int *argc, char ***argv, int required, int *provided)
int ret;
ret = DARSHAN_MPI_CALL(PMPI_Init_thread)(argc, argv, required, provided);
return(ret);
if(argc && argv)
else
return(ret);
int MPI_Finalize(void)
int ret;
darshan_core_shutdown();
ret = DARSHAN_MPI_CALL(PMPI_Finalize)();
return(ret);
static void darshan_core_initialize(int argc, char **argv) void darshan_core_initialize(int argc, char **argv)
int i; int i;
int internal_timing_flag = 0; int internal_timing_flag = 0;
...@@ -270,7 +211,7 @@ static void darshan_core_initialize(int argc, char **argv) ...@@ -270,7 +211,7 @@ static void darshan_core_initialize(int argc, char **argv)
return; return;
static void darshan_core_shutdown() void darshan_core_shutdown()
int i; int i;
char *logfile_name; char *logfile_name;
...@@ -769,33 +710,7 @@ static void darshan_core_shutdown() ...@@ -769,33 +710,7 @@ static void darshan_core_shutdown()
return; return;
/* free darshan core data structures to shutdown */ /* *********************************** */
static void darshan_core_cleanup(struct darshan_core_runtime* core)
struct darshan_core_record_ref *tmp, *ref;
int i;
HASH_ITER(hlink, core->rec_hash, ref, tmp)
HASH_DELETE(hlink, core->rec_hash, ref);
free(ref->rec.name);
free(ref);
for(i = 0; i < DARSHAN_MAX_MODS; i++)
if(core->mod_array[i])
free(core->mod_array[i]);
core->mod_array[i] = NULL;
free(core->trailing_data);
free(core);
return;
/* construct the darshan log file name */ /* construct the darshan log file name */
static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* start_tm) static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* start_tm)
...@@ -1564,6 +1479,34 @@ static int darshan_log_append_all(MPI_File log_fh, struct darshan_core_runtime * ...@@ -1564,6 +1479,34 @@ static int darshan_log_append_all(MPI_File log_fh, struct darshan_core_runtime *
return(0); return(0);
int i;
free(ref);
free(core);
return;
void darshan_core_register_module( void darshan_core_register_module(
...@@ -27,6 +27,7 @@ ...@@ -27,6 +27,7 @@
#include "darshan.h" #include "darshan.h"
#include "darshan-mpiio-log-format.h" #include "darshan-mpiio-log-format.h"
/* The mpiio_file_runtime structure maintains necessary runtime metadata /* The mpiio_file_runtime structure maintains necessary runtime metadata
* for the MPIIO file record (darshan_mpiio_file structure, defined in * for the MPIIO file record (darshan_mpiio_file structure, defined in
...@@ -35,6 +35,10 @@ typedef int64_t off64_t; ...@@ -35,6 +35,10 @@ typedef int64_t off64_t;
#define aiocb64 aiocb #define aiocb64 aiocb
#endif #endif
extern double (*__real_PMPI_Comm_rank)(MPI_Comm comm, int *rank);
#endif
/* TODO: more libc, fgetc, etc etc etc. */ /* TODO: more libc, fgetc, etc etc etc. */
DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...)); DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
...@@ -215,7 +219,7 @@ static int darshan_mem_alignment = 1; ...@@ -215,7 +219,7 @@ static int darshan_mem_alignment = 1;
} while(0) } while(0)
#define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \ #define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
size_t stride; \ /* size_t stride; */\
int64_t this_offset; \ int64_t this_offset; \
struct posix_file_runtime* file; \ struct posix_file_runtime* file; \
int64_t file_alignment; \ int64_t file_alignment; \
...@@ -231,11 +235,11 @@ static int darshan_mem_alignment = 1; ...@@ -231,11 +235,11 @@ static int darshan_mem_alignment = 1;
DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_READS, 1); \ DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_READS, 1); \
if(this_offset == (file->last_byte_read + 1)) \ if(this_offset == (file->last_byte_read + 1)) \
DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_READS, 1); \ DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_READS, 1); \
if(this_offset > 0 && this_offset > file->last_byte_read \ /* if(this_offset > 0 && this_offset > file->last_byte_read \
&& file->last_byte_read != 0) \ && file->last_byte_read != 0) \
stride = this_offset - file->last_byte_read - 1; \ stride = this_offset - file->last_byte_read - 1; \
else \ else \
stride = 0; \ stride = 0; */\
file->last_byte_read = this_offset + __ret - 1; \ file->last_byte_read = this_offset + __ret - 1; \
file->offset = this_offset + __ret; \ file->offset = this_offset + __ret; \
DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_READ, (this_offset + __ret - 1)); \ DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_READ, (this_offset + __ret - 1)); \
...@@ -265,7 +269,7 @@ static int darshan_mem_alignment = 1; ...@@ -265,7 +269,7 @@ static int darshan_mem_alignment = 1;
#define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \ #define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
...@@ -281,11 +285,11 @@ static int darshan_mem_alignment = 1; ...@@ -281,11 +285,11 @@ static int darshan_mem_alignment = 1;
DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_WRITES, 1); \ DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_WRITES, 1); \
if(this_offset == (file->last_byte_written + 1)) \ if(this_offset == (file->last_byte_written + 1)) \
DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_WRITES, 1); \ DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_WRITES, 1); \
if(this_offset > 0 && this_offset > file->last_byte_written \ /* if(this_offset > 0 && this_offset > file->last_byte_written \
&& file->last_byte_written != 0) \ && file->last_byte_written != 0) \
stride = this_offset - file->last_byte_written - 1; \ stride = this_offset - file->last_byte_written - 1; \
else \ else \
file->last_byte_written = this_offset + __ret - 1; \ file->last_byte_written = this_offset + __ret - 1; \
DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_WRITTEN, (this_offset + __ret - 1)); \ DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_WRITTEN, (this_offset + __ret - 1)); \
...@@ -579,7 +583,7 @@ ssize_t DARSHAN_DECL(read)(int fd, void *buf, size_t count) ...@@ -579,7 +583,7 @@ ssize_t DARSHAN_DECL(read)(int fd, void *buf, size_t count)
int aligned_flag = 0; int aligned_flag = 0;
double tm1, tm2; double tm1, tm2;
MAP_OR_FAIL(write); MAP_OR_FAIL(read);
if((unsigned long)buf % darshan_mem_alignment == 0) aligned_flag = 1; if((unsigned long)buf % darshan_mem_alignment == 0) aligned_flag = 1;
Markdown is supported
0%
or
Please register or to comment
