Commit 3f30b9ba authored by Philip Carns's avatar Philip Carns
Browse files
stub in tracker structure for aio_write64 example
git-svn-id: https://svn.mcs.anl.gov/repos/darshan/trunk@759 3b7491f3-a168-0410-bf4b-c445ed680a29
parent 45e9d26c
...@@ -60,6 +60,8 @@ struct cp_access_counter ...@@ -60,6 +60,8 @@ struct cp_access_counter
int freq; int freq;
struct darshan_io_tracker;
/* in memory structure to keep up with file level data */ /* in memory structure to keep up with file level data */
struct darshan_file_runtime struct darshan_file_runtime
...@@ -80,6 +82,8 @@ struct darshan_file_runtime ...@@ -80,6 +82,8 @@ struct darshan_file_runtime
double last_mpi_read_end; double last_mpi_read_end;
double last_posix_meta_end; double last_posix_meta_end;
double last_mpi_meta_end; double last_mpi_meta_end;
struct darshan_aio_tracker* aio_list_head;
struct darshan_aio_tracker* aio_list_tail;
/* handles used by various APIs to refer to files */ /* handles used by various APIs to refer to files */
...@@ -117,6 +117,14 @@ static int my_rank = -1; ...@@ -117,6 +117,14 @@ static int my_rank = -1;
static struct stat64 cp_stat_buf; static struct stat64 cp_stat_buf;
static int darshan_mem_alignment = 1; static int darshan_mem_alignment = 1;
/* struct to track information about aio operations in flight */
double tm1;
struct aio_cb *aiocbp;
struct darshan_aio_tracker* next;
/* these are paths that we will not trace */ /* these are paths that we will not trace */
static char* exclusions[] = { static char* exclusions[] = {
"/etc/", "/etc/",
...@@ -1085,12 +1093,37 @@ int DARSHAN_DECL(lio_listio64)(int mode, struct aiocb *const aiocb_list[], ...@@ -1085,12 +1093,37 @@ int DARSHAN_DECL(lio_listio64)(int mode, struct aiocb *const aiocb_list[],
int DARSHAN_DECL(aio_write64)(struct aiocb *aiocbp) int DARSHAN_DECL(aio_write64)(struct aiocb *aiocbp)
int ret; int ret;
struct darshan_aio_tracker* tracker;
struct darshan_file_runtime* file;
MAP_OR_FAIL(aio_write64); MAP_OR_FAIL(aio_write64);
printf("TESTING: wrapped aio_write64()\n"); printf("TESTING: wrapped aio_write64()\n");
ret = __real_aio_write64(aiocbp); ret = __real_aio_write64(aiocbp);
if(ret == 0)
file = darshan_file_by_fd(aiocbp->aio_fildes);
if(file)
tracker = malloc(sizeof(*tracker));
if(tracker)
tracker->tm1 = darshan_wtime();
tracker->aiocbp = aiocbp;
tracker->next = NULL;
if(file->aio_list_tail)
file->aio_list_tail->next = tracker;
file->aio_list_tail = tracker;
else
file->aio_list_head = file->aio_list_tail = tracker;
return(ret); return(ret);
Markdown is supported
0% or .
Please register or to comment
