Commits (9)
...@@ -6,7 +6,8 @@ Contributors to date (in chronological order, with current affiliations) ...@@ -6,7 +6,8 @@ Contributors to date (in chronological order, with current affiliations)
- Shane Snyder, Argonne National Labs - Shane Snyder, Argonne National Labs
- Jonathan P. Jenkins - Jonathan P. Jenkins
- Noah Wolfe, RPI - Noah Wolfe, RPI
- Nikhil Jain, Lawrence Livermore Labs - Nikhil Jain, Nvidia
- Giorgis Georgakoudis, Lawrence Livermore Labs
- Matthieu Dorier, Argonne National Labs - Matthieu Dorier, Argonne National Labs
- Caitlin Ross, RPI - Caitlin Ross, RPI
- Xu Yang, Amazon - Xu Yang, Amazon
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
# Process this file with autoconf to produce a configure script. # Process this file with autoconf to produce a configure script.
AC_PREREQ([2.67]) AC_PREREQ([2.67])
AC_INIT([codes], [1.0.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/]) AC_INIT([codes], [1.1.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/])
LT_INIT LT_INIT
...@@ -202,6 +202,15 @@ should be everything up to the rank number. E.g., if the dumpi files are of the ...@@ -202,6 +202,15 @@ should be everything up to the rank number. E.g., if the dumpi files are of the
form "dumpi-YYYY.MM.DD.HH.MM.SS-XXXX.bin", then the input should be form "dumpi-YYYY.MM.DD.HH.MM.SS-XXXX.bin", then the input should be
"dumpi-YYYY.MM.DD.HH.MM.SS-" "dumpi-YYYY.MM.DD.HH.MM.SS-"
=== Quality of Service
Two models (dragonfly-dally.C and dragonfly-plus.C) can now support traffic
differentiation and prioritization. The models support quality of service by
directing the network traffic on separate class of virtual channels. Additional
documentation on using traffic classes can be found at the wiki link:
https://xgitlab.cels.anl.gov/codes/codes/wikis/Quality-of-Service
=== Workload generator helpers === Workload generator helpers
The codes-jobmap API (codes/codes-jobmap.h) specifies mechanisms to initialize The codes-jobmap API (codes/codes-jobmap.h) specifies mechanisms to initialize
...@@ -44,7 +44,7 @@ Notes on how to release a new version of CODES ...@@ -44,7 +44,7 @@ Notes on how to release a new version of CODES
4. Upload the release tarball 4. Upload the release tarball
- Our release directory is at ftp.mcs.anl.gov/pub/CODES/releases . There's no - Our release directory is at ftp.mcs.anl.gov/pub/CODES/releases . There's no
web interface, so you have to get onto an MCS workstation and copy the web interface, so you have to get onto an MCS workstation and copy the
release in that way (the ftp server is mounted at /homes/ftp). release in that way (the ftp server is mounted at /mcs/ftp.mcs.anl.gov).
5. Update website 5. Update website
- Project wordpress: http://www.mcs.anl.gov/projects/codes/ (you need - Project wordpress: http://www.mcs.anl.gov/projects/codes/ (you need
...@@ -16,16 +16,16 @@ boost_cflags=@BOOST_CFLAGS@ ...@@ -16,16 +16,16 @@ boost_cflags=@BOOST_CFLAGS@
boost_libs=@BOOST_LIBS@ boost_libs=@BOOST_LIBS@
argobots_libs=@ARGOBOTS_LIBS@ argobots_libs=@ARGOBOTS_LIBS@
argobots_cflags=@ARGOBOTS_CFLAGS@ argobots_cflags=@ARGOBOTS_CFLAGS@
conceptual_libs=@CONCEPTUAL_LIBS@
conceptual_cflags=@CONCEPTUAL_CFLAGS@
swm_libs=@SWM_LIBS@ swm_libs=@SWM_LIBS@
swm_cflags=@SWM_CFLAGS@ swm_cflags=@SWM_CFLAGS@
swm_datarootdir=@SWM_DATAROOTDIR@ swm_datarootdir=@SWM_DATAROOTDIR@
Name: codes-base Name: codes-base
Description: Base functionality for CODES storage simulation Description: Base functionality for CODES storage simulation
Version: @PACKAGE_VERSION@ Version: @PACKAGE_VERSION@
URL: http://trac.mcs.anl.gov/projects/CODES URL: http://trac.mcs.anl.gov/projects/CODES
Requires: Requires:
Libs: -L${libdir} -lcodes ${ross_libs} ${argobots_libs} ${conceptual_libs} ${swm_libs} ${darshan_libs} ${dumpi_libs} ${cortex_libs} Libs: -L${libdir} -lcodes ${ross_libs} ${argobots_libs} ${swm_libs} ${darshan_libs} ${dumpi_libs} ${cortex_libs}
Cflags: -I${includedir} ${swm_datarootdir} ${ross_cflags} ${darshan_cflags} ${swm_cflags} ${argobots_cflags} ${conceptual_cflags} ${dumpi_cflags} ${cortex_cflags} Cflags: -I${includedir} -I${swm_datarootdir} ${ross_cflags} ${darshan_cflags} ${swm_cflags} ${argobots_cflags} ${dumpi_cflags} ${cortex_cflags}
2 conceptual-latency
2 conceptual-latencyall
...@@ -69,7 +69,6 @@ static struct codes_workload_method const * method_array_default[] = ...@@ -69,7 +69,6 @@ static struct codes_workload_method const * method_array_default[] =
#ifdef USE_CONC #ifdef USE_CONC
&conc_online_comm_workload_method, &conc_online_comm_workload_method,
#endif #endif
#ifdef USE_RECORDER #ifdef USE_RECORDER
&recorder_io_workload_method, &recorder_io_workload_method,
#endif #endif
