Commit fb41c9c0 authored by Neil McGlohon's avatar Neil McGlohon
Update README.md to reflect GitHub migration
parent b498917e
# **IMPORTANT NOTICE**
## THE CODES PROJECT HAS BEEN MOVED
https://github.com/codes-org/codes
As of June 21, 2019, the location of the repo has been moved to GitHub as part of the codebase's shift to its open source BSD License. All issues will be moved in some form to the new location followed by merge requests (if possible). I will do my best to keep the master branch of the two repositories up to date with each other. That being said, if there is any conflict, the GitHub repo should be taken as the truth.
Thank you,
Neil McGlohon
# CODES Discrete-event Simulation Framework
https://xgitlab.cels.anl.gov/codes/codes/wikis/home
Markdown is supported
0%
or
Please register or to comment
