Commit fa2953bb authored by Neil McGlohon's avatar Neil McGlohon
Slimfly/Fitfly RC Fixes - optimistic works
Prior to this commit, multi-rail slimfly was not working in optimistic
mode. Since it worked in sequential and conservative the issue was
surely in an RC. This bug in particular was caused by popping/pushing
from the incorrect queue in RC compared to FC.
Still not deterministic yet.
parent 773aac3b
...@@ -1236,14 +1236,18 @@ void slim_packet_generate_rc(terminal_state * s, tw_bf * bf, slim_terminal_messa ...@@ -1236,14 +1236,18 @@ void slim_packet_generate_rc(terminal_state * s, tw_bf * bf, slim_terminal_messa
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
s->in_send_loop[msg->saved_vc] = 0; s->in_send_loop[msg->saved_vc] = 0;
if(bf->c11)
for(int j = 0; j < s->params->ports_per_nic; j++)
s->issueIdle[msg->rail_id] = 0; if (s->terminal_length[j] >= s->params->cn_vc_size) {
if(bf->c8) s->issueIdle[j] = 0;
{ if (s->last_buf_full[j] != 0.0)
s->last_buf_full[msg->rail_id] = msg->saved_busy_time; {
s->last_buf_full[j] = msg->saved_busy_time[j];
struct mn_stats* stat; struct mn_stats* stat;
stat = model_net_find_stats(msg->category, s->slimfly_stats_array); stat = model_net_find_stats(msg->category, s->slimfly_stats_array);
stat->send_count--; stat->send_count--;
...@@ -1359,14 +1363,7 @@ void slim_packet_generate(terminal_state * s, tw_bf * bf, slim_terminal_message ...@@ -1359,14 +1363,7 @@ void slim_packet_generate(terminal_state * s, tw_bf * bf, slim_terminal_message
s->terminal_length[target_queue] += s->params->chunk_size; s->terminal_length[target_queue] += s->params->chunk_size;
// if(s->terminal_length[target_queue] < s->params->cn_vc_size) { //TODO: Inspect this and verify that we should be looking at each port always
// model_net_method_idle_event2(nic_ts, 0, msg->rail_id, lp);
// } else {
// bf->c11 = 1;
// s->issueIdle[msg->rail_id] = 1;
// msg->saved_busy_time = s->last_buf_full[msg->rail_id];
// s->last_buf_full[msg->rail_id] = tw_now(lp);
for(int j=0; j<s->params->ports_per_nic; j++){ for(int j=0; j<s->params->ports_per_nic; j++){
if(s->terminal_length[j] < s->params->cn_vc_size) if(s->terminal_length[j] < s->params->cn_vc_size)
...@@ -1382,7 +1379,7 @@ void slim_packet_generate(terminal_state * s, tw_bf * bf, slim_terminal_message ...@@ -1382,7 +1379,7 @@ void slim_packet_generate(terminal_state * s, tw_bf * bf, slim_terminal_message
if(s->last_buf_full[j] == 0.0) if(s->last_buf_full[j] == 0.0)
bf->c8 = 1; bf->c8 = 1;
msg->saved_busy_time = s->last_buf_full[j]; msg->saved_busy_time[j] = s->last_buf_full[j];
/* TODO: Assumes a single vc from terminal to router */ /* TODO: Assumes a single vc from terminal to router */
s->last_buf_full[j] = tw_now(lp); s->last_buf_full[j] = tw_now(lp);
...@@ -1420,12 +1417,13 @@ void slim_packet_send_rc(terminal_state * s, tw_bf * bf, slim_terminal_message * ...@@ -1420,12 +1417,13 @@ void slim_packet_send_rc(terminal_state * s, tw_bf * bf, slim_terminal_message *
// printf("slimfly packet send rc\n"); // printf("slimfly packet send rc\n");
if (bf->c10) {
s->last_buf_full[msg->vc_index] = msg->saved_busy_time[msg->vc_index];
if(bf->c1) { if(bf->c1) {
s->in_send_loop[msg->vc_index] = 1; s->in_send_loop[msg->vc_index] = 1;
if(bf->c10)
s->last_buf_full[msg->vc_index] = msg->saved_busy_time;
return; return;
...@@ -1442,7 +1440,7 @@ void slim_packet_send_rc(terminal_state * s, tw_bf * bf, slim_terminal_message * ...@@ -1442,7 +1440,7 @@ void slim_packet_send_rc(terminal_state * s, tw_bf * bf, slim_terminal_message *
slim_terminal_message_list* cur_entry = rc_stack_pop(s->st); slim_terminal_message_list* cur_entry = rc_stack_pop(s->st);
prepend_to_terminal_message_list(s->terminal_msgs, prepend_to_terminal_message_list(s->terminal_msgs,
s->terminal_msgs_tail, 0, cur_entry); s->terminal_msgs_tail, msg->vc_index, cur_entry);
if(bf->c3) { if(bf->c3) {
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
...@@ -1451,12 +1449,11 @@ void slim_packet_send_rc(terminal_state * s, tw_bf * bf, slim_terminal_message * ...@@ -1451,12 +1449,11 @@ void slim_packet_send_rc(terminal_state * s, tw_bf * bf, slim_terminal_message *
if(bf->c5) if(bf->c5)
s->issueIdle[msg->vc_index] = 1; s->issueIdle[msg->vc_index] = 1;
if(bf->c6) if(bf->c6)
s->busy_time[msg->vc_index] = msg->saved_total_time; s->busy_time[msg->vc_index] = msg->saved_total_time;
s->last_buf_full[msg->vc_index] = msg->saved_busy_time; s->last_buf_full[msg->vc_index] = msg->saved_busy_time[msg->vc_index];
return; return;
...@@ -1474,15 +1471,15 @@ void slim_packet_send(terminal_state * s, tw_bf * bf, slim_terminal_message * ms ...@@ -1474,15 +1471,15 @@ void slim_packet_send(terminal_state * s, tw_bf * bf, slim_terminal_message * ms
slim_terminal_message_list* cur_entry = s->terminal_msgs[msg->vc_index]; slim_terminal_message_list* cur_entry = s->terminal_msgs[msg->vc_index];
if(s->vc_occupancy[msg->vc_index] + s->params->chunk_size > s->params->cn_vc_size) if(s->vc_occupancy[msg->vc_index] + s->params->chunk_size > s->params->cn_vc_size)
if(s->last_buf_full[msg->vc_index] == 0.0) if(s->last_buf_full[msg->vc_index] == 0.0)
bf->c10 = 1; bf->c10 = 1;
msg->saved_busy_time = s->last_buf_full[msg->vc_index]; msg->saved_busy_time[msg->vc_index] = s->last_buf_full[msg->vc_index];
s->last_buf_full[msg->vc_index] = tw_now(lp); s->last_buf_full[msg->vc_index] = tw_now(lp);
if(s->vc_occupancy[msg->vc_index] + s->params->chunk_size > s->params->cn_vc_size if(s->vc_occupancy[msg->vc_index] + s->params->chunk_size > s->params->cn_vc_size
|| cur_entry == NULL) || cur_entry == NULL)
...@@ -1509,10 +1506,7 @@ void slim_packet_send(terminal_state * s, tw_bf * bf, slim_terminal_message * ms ...@@ -1509,10 +1506,7 @@ void slim_packet_send(terminal_state * s, tw_bf * bf, slim_terminal_message * ms
s->terminal_available_time[msg->vc_index] += ts; s->terminal_available_time[msg->vc_index] += ts;
ts = s->terminal_available_time[msg->vc_index] - tw_now(lp); ts = s->terminal_available_time[msg->vc_index] - tw_now(lp);
//TODO: be annotation-aware
codes_mapping_get_lp_info(lp->gid, lp_group_name, &mapping_grp_id, NULL,
&mapping_type_id, NULL, &mapping_rep_id, &mapping_offset);
// we are sending an event to the router, so no method_event here
void *remote_event; void *remote_event;
e = model_net_method_event_new(s->router_lp[msg->vc_index], ts, lp, SLIMFLY_ROUTER, (void**)&m, &remote_event); e = model_net_method_event_new(s->router_lp[msg->vc_index], ts, lp, SLIMFLY_ROUTER, (void**)&m, &remote_event);
memcpy(m, &cur_entry->msg, sizeof(slim_terminal_message)); memcpy(m, &cur_entry->msg, sizeof(slim_terminal_message));
...@@ -1620,7 +1614,7 @@ void slim_packet_send(terminal_state * s, tw_bf * bf, slim_terminal_message * ms ...@@ -1620,7 +1614,7 @@ void slim_packet_send(terminal_state * s, tw_bf * bf, slim_terminal_message * ms
bf->c6 = 1; bf->c6 = 1;
msg->saved_total_time = s->busy_time[msg->vc_index]; msg->saved_total_time = s->busy_time[msg->vc_index];
s->busy_time[msg->vc_index] += (tw_now(lp) - s->last_buf_full[msg->vc_index]); s->busy_time[msg->vc_index] += (tw_now(lp) - s->last_buf_full[msg->vc_index]);
s->last_buf_full[msg->vc_index] = 0.0; s->last_buf_full[msg->vc_index] = 0.0;
...@@ -3108,7 +3102,7 @@ void slim_router_packet_receive_rc(router_state * s, ...@@ -3108,7 +3102,7 @@ void slim_router_packet_receive_rc(router_state * s,
if(bf->c4) { if(bf->c4) {
if(bf->c22) if(bf->c22)
s->last_buf_full[output_port][output_chan] = msg->saved_busy_time; s->last_buf_full[output_port][output_chan] = msg->saved_busy_time[output_port];
slim_delete_terminal_message_list(return_tail(s->queued_msgs[output_port], slim_delete_terminal_message_list(return_tail(s->queued_msgs[output_port],
s->queued_msgs_tail[output_port], output_chan)); s->queued_msgs_tail[output_port], output_chan));
...@@ -3327,7 +3321,7 @@ slim_router_packet_receive( router_state * s, ...@@ -3327,7 +3321,7 @@ slim_router_packet_receive( router_state * s,
if(s->pending_msgs[output_port][output_chan] == NULL && s->last_buf_full[output_port][output_chan] == 0.0) if(s->pending_msgs[output_port][output_chan] == NULL && s->last_buf_full[output_port][output_chan] == 0.0)
bf->c22 = 1; bf->c22 = 1;
msg->saved_busy_time = s->last_buf_full[output_port][output_chan]; msg->saved_busy_time[output_port] = s->last_buf_full[output_port][output_chan];
s->last_buf_full[output_port][output_chan] = tw_now(lp); s->last_buf_full[output_port][output_chan] = tw_now(lp);
...@@ -3570,7 +3564,7 @@ void slim_router_buf_update_rc(router_state * s, ...@@ -3570,7 +3564,7 @@ void slim_router_buf_update_rc(router_state * s,
if(bf->c3) if(bf->c3)
s->busy_time[indx] = msg->saved_rcv_time; s->busy_time[indx] = msg->saved_rcv_time;
s->last_buf_full[indx][output_chan] = msg->saved_busy_time; s->last_buf_full[indx][output_chan] = msg->saved_busy_time[indx];
slim_terminal_message_list* head = return_tail(s->pending_msgs[indx], slim_terminal_message_list* head = return_tail(s->pending_msgs[indx],
...@@ -3598,7 +3592,7 @@ void slim_router_buf_update(router_state * s, tw_bf * bf, slim_terminal_message ...@@ -3598,7 +3592,7 @@ void slim_router_buf_update(router_state * s, tw_bf * bf, slim_terminal_message
bf->c3 = 1; bf->c3 = 1;
msg->saved_rcv_time = s->busy_time[indx]; msg->saved_rcv_time = s->busy_time[indx];
msg->saved_busy_time = s->last_buf_full[indx][output_chan]; msg->saved_busy_time[indx] = s->last_buf_full[indx][output_chan];
s->busy_time[indx] += (tw_now(lp) - s->last_buf_full[indx][output_chan]); s->busy_time[indx] += (tw_now(lp) - s->last_buf_full[indx][output_chan]);
s->last_buf_full[indx][output_chan] = 0.0; s->last_buf_full[indx][output_chan] = 0.0;
Markdown is supported
0% or
Please register or to comment
