Commit f09362a3 authored by Misbah Mubarak's avatar Misbah Mubarak
Fixing warnings, local variable was being declared twice
parent eeb658fd
...@@ -1237,12 +1237,12 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1237,12 +1237,12 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(cur_entry != NULL && if(cur_entry != NULL &&
s->vc_occupancy[0] + s->params->chunk_size <= s->params->cn_vc_size) { s->vc_occupancy[0] + s->params->chunk_size <= s->params->cn_vc_size) {
bf->c3 = 1; bf->c3 = 1;
terminal_message *m; terminal_message *m_new;
ts = g_tw_lookahead + s->params->cn_delay + tw_rand_unif(lp->rng); ts = g_tw_lookahead + s->params->cn_delay + tw_rand_unif(lp->rng);
tw_event* e = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY, e = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY,
(void**)&m, NULL); (void**)&m_new, NULL);
m->type = T_SEND; m_new->type = T_SEND;
m->magic = terminal_magic_num; m_new->magic = terminal_magic_num;
tw_event_send(e); tw_event_send(e);
} else { } else {
/* If not then the LP will wait for another credit or packet generation */ /* If not then the LP will wait for another credit or packet generation */
...@@ -1796,7 +1796,6 @@ static void node_collective_fan_out(terminal_state * s, ...@@ -1796,7 +1796,6 @@ static void node_collective_fan_out(terminal_state * s,
msg->remote_event_size_bytes); msg->remote_event_size_bytes);
msg_new->type = D_COLLECTIVE_FAN_OUT; msg_new->type = D_COLLECTIVE_FAN_OUT;
msg_new->sender_node = s->node_id; msg_new->sender_node = s->node_id;
tw_event_send(e_new); tw_event_send(e_new);
...@@ -2612,13 +2611,13 @@ router_packet_send( router_state * s, ...@@ -2612,13 +2611,13 @@ router_packet_send( router_state * s,
if(cur_entry == NULL) cur_entry = s->pending_msgs[output_port][0]; if(cur_entry == NULL) cur_entry = s->pending_msgs[output_port][0];
if(cur_entry != NULL) { if(cur_entry != NULL) {
ts = g_tw_lookahead + delay + tw_rand_unif(lp->rng); ts = g_tw_lookahead + delay + tw_rand_unif(lp->rng);
tw_event *e = tw_event_new(lp->gid, ts, lp); e = tw_event_new(lp->gid, ts, lp);
m = tw_event_data(e); m_new = tw_event_data(e);
m->type = R_SEND; m_new->type = R_SEND;
m->magic = router_magic_num; m_new->magic = router_magic_num;
m->vc_index = output_port; m_new->vc_index = output_port;
} else { } else {
bf->c4 = 1; bf->c4 = 1;
Markdown is supported
0% or
Please register or to comment
