Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project
Project
Details
Activity
Releases
Cycle Analytics
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Charts
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Charts
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
ef14e173
Commit
ef14e173
authored
Aug 19, 2016
by
Misbah Mubarak
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
modifying dragonfly-custom network setup, fixing connectivity display bug
parent
b2679607
Changes
7
Hide whitespace changes
Inline
Side-by-side
Showing
7 changed files
with
71 additions
and
36 deletions
+71
-36
Makefile.am
Makefile.am
+1
-1
torus.h
codes/net/torus.h
+2
-3
simple_con.c
scripts/simple_con.c
+1
-1
Makefile.subdir
src/Makefile.subdir
+0
-2
dragonfly-custom.C
src/networks/model-net/dragonfly-custom.C
+33
-26
dragonfly.c
src/networks/model-net/dragonfly.c
+2
-3
modelnet-test-dragonfly-custom.conf
tests/conf/modelnet-test-dragonfly-custom.conf
+32
-0
No files found.
Makefile.am
View file @
ef14e173
@@ -24,7 +24,7 @@ EXTRA_DIST += \
misc/README misc/ptrn_loggp-2.4.6.patch CONTRIBUTORS.md
README.md
README.md
AM_CPPFLAGS
-I
$(top_srcdir)
/src
ROSS_CFLAGS
AM_CPPFLAGS
-I
$(top_srcdir)
/src
ROSS_CFLAGS
AM_CFLAGS
AM_CFLAGS
codes/net/torus.h
View file @
ef14e173
@@ -11,11 +11,10 @@
@@ -11,11 +11,10 @@
extern
"C"
extern
"C"
#endif
#endif
typedef
enum
nodes_event_t
nodes_event_t
typedef
struct
nodes_message
nodes_message
typedef
struct
nodes_message
nodes_message
/* event type of each torus message, can be packet generate, flit arrival, flit send or credit */
enum
nodes_event_t
typedef
enum
nodes_event_t
GENERATE
1
GENERATE
1
ARRIVAL
ARRIVAL
@@ -24,7 +23,7 @@ enum nodes_event_t
T_COLLECTIVE_INIT
T_COLLECTIVE_INIT
T_COLLECTIVE_FAN_IN
T_COLLECTIVE_FAN_IN
T_COLLECTIVE_FAN_OUT
nodes_event_t
struct
nodes_message
struct
nodes_message
View file @
ef14e173
@@ -38,7 +38,7 @@ int main(int argc, char **argv) {
fwrite
router
sizeof
int
1
intra
fwrite
router
sizeof
int
1
intra
fwrite
dest
sizeof
int
1
intra
fwrite
dest
sizeof
int
1
intra
fwrite
green
sizeof
int
1
intra
fwrite
green
sizeof
int
1
intra
printf("INTRA %d %d %d\n", router, dest, green);
printf
"INTRA %d %d %d
\n
router
dest
green
src/Makefile.subdir
View file @
ef14e173
@@ -180,12 +180,10 @@ bin_PROGRAMS += src/network-workloads/model-net-dumpi-traces-dump
bin_PROGRAMS
src/network-workloads/model-net-synthetic
bin_PROGRAMS
bin_PROGRAMS
src/network-workloads/model-net-synthetic-slimfly
bin_PROGRAMS
src_workload_codes_workload_dump_SOURCES
src/workload/codes-workload-dump.c
src_network_workloads_model_net_mpi_replay_SOURCES
src/network-workloads/model-net-mpi-replay.c
src_network_workloads_model_net_synthetic_SOURCES
src/network-workloads/model-net-synthetic.c
src_network_workloads_model_net_synthetic_slimfly_SOURCES
src/network-workloads/model-net-synthetic-slimfly.c
src_network_workloads_model_net_dumpi_traces_dump_SOURCES
src/network-workloads/model-net-dumpi-traces-dump.c
View file @
ef14e173
@@ -23,6 +23,7 @@
@@ -23,6 +23,7 @@
#define GREEN 0
#define GREEN 0
#define BLACK 1
#define BLACK 1
#define BLUE 2
#define BLUE 2
#define DUMP_CONNECTIONS 1
using
namespace
std
using
namespace
std
struct
Link
struct
Link
@@ -31,8 +32,16 @@ struct Link {
struct
bLink
struct
bLink
int
offset
dest
int
offset
dest
/* Each entry in the vector is for a router id
* against each router id, there is a map of links (key of the map is the dest
* router id)
* link has information on type (green or black) and offset (number of links
* between that particular source and dest router ID)*/
vector
map
int
vector
Link
intraGroupLinks
vector
map
int
vector
Link
intraGroupLinks
/* contains mapping between source router and destination group via link (link
* has dest ID)*/
vector
map
int
vector
bLink
interGroupLinks
vector
map
int
vector
bLink
interGroupLinks
/*MM: Maintains a connection between the source and destination groups */
vector
vector
vector
int
connectionList
vector
vector
vector
int
connectionList
struct
IntraGroupLink
struct
IntraGroupLink
@@ -191,7 +200,6 @@ struct dfly_qhash_entry
/* handles terminal and router events like packet generate/send/receive/buffer */
typedef
enum
event_t
event_t
typedef
struct
terminal_state
terminal_state
typedef
struct
terminal_state
terminal_state
typedef
struct
router_state
router_state
typedef
struct
router_state
router_state
@@ -284,7 +292,7 @@ struct terminal_state
/* terminal event type (1-4) */
enum
event_t
typedef
enum
event_t
T_GENERATE
1
T_GENERATE
1
T_ARRIVE
T_ARRIVE
@@ -296,7 +304,7 @@ enum event_t
D_COLLECTIVE_INIT
D_COLLECTIVE_INIT
D_COLLECTIVE_FAN_IN
D_COLLECTIVE_FAN_IN
D_COLLECTIVE_FAN_OUT
event_t
/* status of a virtual channel can be idle, active, allocated or wait for credit */
enum
vc_status
enum
vc_status
@@ -588,26 +596,27 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
printf
"Number of groups not specified. Aborting"
printf
MPI_Abort
MPI_COMM_WORLD
1
MPI_Abort
MPI_COMM_WORLD
1
rc
configuration_get_value_int
config
"PARAMS"
router_radix"
anno
p
radix
rc
config
"PARAMS"
num_cns_per_router"
anno
p
num_cn
if
rc
if
rc
printf
"Router radix not specified. Aborting"
printf
\n
Number of cns per router not specified, setting to %d "
p
num_routers
2
MPI_Abort
MPI_COMM_WORLD
1
p
num_cn
p
num_routers
2
rc
config
"PARAMS"
"num_global_channels"
anno
p
num_global_channels
if
rc
printf
\n
Number of global channels per router not specified, setting to %d "
p
num_routers
2
p
num_global_channels
p
num_routers
2
p
radix
p
num_cn
p
num_routers
p
num_global_channels
p
total_routers
p
num_groups
p
num_routers
p
total_routers
p
num_groups
p
num_routers
p
total_terminals
p
total_routers
p
num_cn
p
total_terminals
p
total_routers
p
num_cn
// should this be a input param too?
p
num_cn
p
num_routers
2
//comes after reading files
p
num_global_channels
p
num_routers
2
// read intra group connections, store from a router's perspective
// all links to the same router form a vector
char
intraFile
MAX_NAME_LENGTH
char
intraFile
MAX_NAME_LENGTH
rc
config
"PARAMS"
"intra-group-connections"
config
"PARAMS"
anno
intraFile
MAX_NAME_LENGTH
anno
intraFile
MAX_NAME_LENGTH
if
rc
if
strlen
intraFile
0
printf
"Intra group connections file not specified. Aborting"
tw_error
TW_LOC
MPI_Abort
MPI_COMM_WORLD
1
FILE
groupFile
fopen
intraFile
"rb"
FILE
groupFile
fopen
intraFile
"rb"
if
myRank
if
myRank
@@ -632,11 +641,10 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
// read inter group connections, store from a router's perspective
// also create a group level table that tells all the connecting routers
char
interFile
MAX_NAME_LENGTH
char
interFile
MAX_NAME_LENGTH
rc
config
"PARAMS"
"inter-group-connections"
config
"PARAMS"
anno
interFile
MAX_NAME_LENGTH
anno
interFile
MAX_NAME_LENGTH
if
rc
if
strlen
interFile
0
printf
"Inter group connections file not specified. Aborting"
tw_error
TW_LOC
MPI_Abort
MPI_COMM_WORLD
1
FILE
systemFile
fopen
interFile
"rb"
FILE
systemFile
fopen
interFile
"rb"
if
myRank
if
myRank
@@ -671,7 +679,7 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
fclose
systemFile
fclose
systemFile
#if DUMP_CONNECTIONS
== 1
printf
"Dumping intra-group connections
\n
printf
\n
for
int
a
0
a
intraGroupLinks
size
a
for
int
a
0
a
intraGroupLinks
size
a
printf
"Connections for router %d
\n
a
printf
\n
a
@@ -687,12 +695,12 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
printf
\n
printf
\n
#endif
#endif
== 1
printf
"Dumping inter-group connections
\n
printf
\n
for
int
a
0
a
interGroupLinks
size
a
for
int
a
0
a
interGroupLinks
size
a
printf
\n
a
printf
\n
a
map
int
vector
Link
curMap
interGroupLinks
a
map
int
vector
b
Link
curMap
interGroupLinks
a
map
int
vector
Link
iterator
it
curMap
begin
map
int
vector
b
Link
iterator
it
curMap
begin
for
it
curMap
end
it
for
it
curMap
end
it
printf
" ( %d - "
it
first
printf
" ( %d - "
it
first
for
int
l
0
l
it
second
size
l
for
int
l
0
l
it
second
size
l
@@ -704,7 +712,7 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
#endif
#endif
== 1
printf
"Dumping source aries for global connections
\n
printf
\n
for
int
g
0
g
p
num_groups
g
for
int
g
0
g
p
num_groups
g
for
int
g1
0
g1
p
num_groups
g1
for
int
g1
0
g1
p
num_groups
g1
@@ -873,8 +881,7 @@ terminal_custom_init( terminal_state * s,
int
num_lps
codes_mapping_get_lp_count
lp_group_name
1
LP_CONFIG_NM_TERM
int
num_lps
lp_group_name
1
LP_CONFIG_NM_TERM
s
anno
0
s
anno
0
s
terminal_id
mapping_rep_id
num_lps
mapping_offset
s
terminal_id
codes_mapping_get_lp_relative_id
lp
gid
0
0
s
router_id
int
s
terminal_id
s
params
num_cn
s
router_id
int
s
terminal_id
s
params
num_cn
s
terminal_available_time
0
0
s
0
0
s
packet_counter
0
s
packet_counter
0
@@ -943,7 +950,7 @@ void router_custom_setup(router_state * r, tw_lp * lp)
// shorthand
// shorthand
const
dragonfly_param
p
r
params
const
dragonfly_param
p
r
params
num_routers_per_mgrp
lp_group_name
1
"modelnet_dragonfly_router"
lp_group_name
1
custom_
router"
NULL
0
NULL
0
int
num_grp_reps
codes_mapping_get_group_reps
lp_group_name
int
num_grp_reps
lp_group_name
if
p
total_routers
num_grp_reps
if
p
total_routers
num_grp_reps
View file @
ef14e173
@@ -725,9 +725,8 @@ terminal_init( terminal_state * s,
int
num_lps
lp_group_name
1
LP_CONFIG_NM_TERM
int
num_lps
lp_group_name
1
LP_CONFIG_NM_TERM
s
anno
0
s
anno
0
s
terminal_id
mapping_rep_id
num_lps
mapping_offset
s
terminal_id
lp
gid
0
0
s
router_id
int
s
terminal_id
s
params
num_cn
s
router_id
int
s
terminal_id
s
params
num_routers
2
s
0
0
s
0
0
s
packet_counter
0
s
packet_counter
0
0 → 100644
View file @
ef14e173
LPGROUPS
MODELNET_GRP
repetitions
"288"
server
"2"
modelnet_dragonfly_custom
"2"
modelnet_dragonfly_custom_router
"1"
PARAMS
packet_size
"512"
modelnet_order
"dragonfly_custom"
"dragonfly_custom_router"
# scheduler options
modelnet_scheduler
"fcfs"
chunk_size
"256"
# modelnet_scheduler="round-robin";
num_routers
"16"
num_groups
"18"
local_vc_size
"2048"
global_vc_size
"8192"
cn_vc_size
"1024"
local_bandwidth
"5.25"
global_bandwidth
"4.7"
cn_bandwidth
"5.25"
message_size
"368"
intra
group
connections
"intra"
inter
group
connections
"inter"
routing
"nonminimal"
router_radix
"48"
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
