Commit eb083337 authored by Philip Carns's avatar Philip Carns
add workload generator test harness to make check
parent b5c828d5
...@@ -2,8 +2,11 @@ ...@@ -2,8 +2,11 @@
check_PROGRAMS += tests/lp-io-test \ check_PROGRAMS += tests/lp-io-test \
tests/workload/codes-workload-test tests/workload/codes-workload-test
TESTS += tests/lp-io-test.sh TESTS += tests/lp-io-test.sh \
EXTRA_DIST += tests/lp-io-test.sh tests/workload/codes-workload-test.sh
EXTRA_DIST += tests/lp-io-test.sh \
testlib = src/libcodes-base.a testlib = src/libcodes-base.a
#!/bin/bash
tests/workload/codes-workload-test --sync=1
Markdown is supported
0% or
Please register or to comment
