Commit e6ab9e42 authored by Neil McGlohon's avatar Neil McGlohon
Broken fix before restarting from scratch
parent 45cd61c5
...@@ -34,7 +34,7 @@ static char lp_io_dir[256] = {'\0'}; ...@@ -34,7 +34,7 @@ static char lp_io_dir[256] = {'\0'};
static lp_io_handle io_handle; static lp_io_handle io_handle;
static unsigned int lp_io_use_suffix = 0; static unsigned int lp_io_use_suffix = 0;
static int do_lp_io = 0; static int do_lp_io = 0;
static int num_msgs = 10; static int num_msgs = 20;
static tw_stime sampling_interval = 800000; static tw_stime sampling_interval = 800000;
static tw_stime sampling_end_time = 1600000; static tw_stime sampling_end_time = 1600000;
This diff is collapsed.
Markdown is supported
0% or
Please register or to comment
