Commit e648f8a6 authored by Neil McGlohon's avatar Neil McGlohon
slimfly/all workload: function prototype to make XL compiler happy
parent cc659082
...@@ -59,6 +59,9 @@ static int group_index, lp_type_index, rep_id, offset; ...@@ -59,6 +59,9 @@ static int group_index, lp_type_index, rep_id, offset;
/* Function for computing local and global connections for a given router id */ /* Function for computing local and global connections for a given router id */
static void get_router_connections(int src_router_id, int* local_channels, int* global_channels); static void get_router_connections(int src_router_id, int* local_channels, int* global_channels);
//declare prior to usage to make certain compilers happy
void init_worst_case_mapping();
/* Global variables for worst-case workload pairing */ /* Global variables for worst-case workload pairing */
static int num_local_channels; static int num_local_channels;
static int num_global_channels; static int num_global_channels;
...@@ -63,6 +63,9 @@ static int **comm_map; ...@@ -63,6 +63,9 @@ static int **comm_map;
Markdown is supported
0% or
Please register or to comment
