still merging? also, slimfly needs commit_f
parent 5022b2e6
...@@ -1455,21 +1455,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1455,21 +1455,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
struct dfly_hash_key key; struct dfly_hash_key key;
key.message_id = msg->message_id; key.message_id = msg->message_id;
key.sender_id = msg->sender_lp; key.sender_id = msg->sender_lp;
<<<<<<< HEAD
uint64_t total_chunks = msg->total_size / s->params->chunk_size; uint64_t total_chunks = msg->total_size / s->params->chunk_size;
struct qhash_head *hash_link = NULL;
struct dfly_qhash_entry * tmp = NULL;
hash_link = qhash_search(s->rank_tbl, &key);
if(hash_link)
tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link);
int total_chunks = msg->total_size / s->params->chunk_size;
>>>>>>> commit_f
if(msg->total_size % s->params->chunk_size) if(msg->total_size % s->params->chunk_size)
total_chunks++; total_chunks++;
...@@ -1589,12 +1576,9 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1589,12 +1576,9 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
hash_link = &(d_entry->hash_link); hash_link = &(d_entry->hash_link);
<<<<<<< HEAD
if(hash_link) if(hash_link)
tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link); tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link);
>>>>>>> commit_f
assert(tmp); assert(tmp);
tmp->num_chunks++; tmp->num_chunks++;
...@@ -1640,13 +1624,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1640,13 +1624,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
total_msg_sz += msg->total_size; total_msg_sz += msg->total_size;
s->total_msg_size += msg->total_size; s->total_msg_size += msg->total_size;
s->finished_msgs++; s->finished_msgs++;
<<<<<<< HEAD
//assert(tmp->remote_event_data && tmp->remote_event_size > 0); //assert(tmp->remote_event_data && tmp->remote_event_size > 0);
>>>>>>> commit_f
send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size); send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size);
/* Remove the hash entry */ /* Remove the hash entry */
qhash_del(hash_link); qhash_del(hash_link);
...@@ -2385,11 +2364,7 @@ void dragonfly_router_final(router_state * s, ...@@ -2385,11 +2364,7 @@ void dragonfly_router_final(router_state * s,
written += sprintf(s->output_buf + written, "# Router ports in the order: %d local channels, %d global channels \n", written += sprintf(s->output_buf + written, "# Router ports in the order: %d local channels, %d global channels \n",
p->num_routers, p->num_global_channels); p->num_routers, p->num_global_channels);
<<<<<<< HEAD
written += sprintf(s->output_buf + written, "\n %llu %d %d", written += sprintf(s->output_buf + written, "\n %llu %d %d",
written += sprintf(s->output_buf + written, "%llu %d %d",
>>>>>>> commit_f
LLU(lp->gid), LLU(lp->gid),
s->router_id / p->num_routers, s->router_id / p->num_routers,
s->router_id % p->num_routers); s->router_id % p->num_routers);
This diff is collapsed.
...@@ -359,12 +359,9 @@ static void handle_kickoff_event( ...@@ -359,12 +359,9 @@ static void handle_kickoff_event(
if(net_id == DRAGONFLY && (lp->gid % lps_per_rep == num_servers_per_rep - 1)) if(net_id == DRAGONFLY && (lp->gid % lps_per_rep == num_servers_per_rep - 1))
opt_offset = num_servers_per_rep + num_routers_per_rep; /* optional offset due to dragonfly mapping */ opt_offset = num_servers_per_rep + num_routers_per_rep; /* optional offset due to dragonfly mapping */
<<<<<<< HEAD
if(net_id == SLIMFLY && (lp->gid % lps_per_rep == num_servers_per_rep -1)) if(net_id == SLIMFLY && (lp->gid % lps_per_rep == num_servers_per_rep -1))
opt_offset = num_servers_per_rep + num_routers_per_rep; opt_offset = num_servers_per_rep + num_routers_per_rep;
>>>>>>> commit_f
/* each server sends a request to the next highest server */ /* each server sends a request to the next highest server */
int dest_id = (lp->gid + offset + opt_offset)%total_lps; int dest_id = (lp->gid + offset + opt_offset)%total_lps;
if (do_pull){ if (do_pull){
...@@ -456,12 +453,9 @@ static void handle_ack_event( ...@@ -456,12 +453,9 @@ static void handle_ack_event(
<<<<<<< HEAD
>>>>>>> commit_f
tw_lpid dest_id = (lp->gid + offset + opt_offset)%(num_servers*2 + num_routers); tw_lpid dest_id = (lp->gid + offset + opt_offset)%(num_servers*2 + num_routers);
...@@ -521,12 +515,9 @@ static void handle_req_event( ...@@ -521,12 +515,9 @@ static void handle_req_event(
if(net_id == DRAGONFLY && (m->src % lps_per_rep == num_servers_per_rep - 1)) if(net_id == DRAGONFLY && (m->src % lps_per_rep == num_servers_per_rep - 1))
<<<<<<< HEAD
if(net_id == SLIMFLY && (m->src % lps_per_rep == num_servers_per_rep -1)) if(net_id == SLIMFLY && (m->src % lps_per_rep == num_servers_per_rep -1))
>>>>>>> commit_f
assert(lp->gid == (m->src + offset + opt_offset)%(num_servers*2 + num_routers)); assert(lp->gid == (m->src + offset + opt_offset)%(num_servers*2 + num_routers));
ns->msg_recvd_count++; ns->msg_recvd_count++;
Markdown is supported
0% or
Please register or to comment
