Commit df2a6601 authored by Neil McGlohon's avatar Neil McGlohon
cleanup
parent 935f3eca
...@@ -1728,23 +1728,23 @@ static void packet_arrive(terminal_state *s, tw_bf *bf, terminal_plus_message *m ...@@ -1728,23 +1728,23 @@ static void packet_arrive(terminal_state *s, tw_bf *bf, terminal_plus_message *m
// Trigger an event on receiving server // Trigger an event on receiving server
// printf("Packet arrived: %d hops\n", msg->my_N_hop); // printf("Packet arrived: %d hops\n", msg->my_N_hop);
if (routing == MINIMAL) { // if (routing == MINIMAL) {
if (msg->my_N_hop > 4) // if (msg->my_N_hop > 4)
printf("Bad Routed Packet Arrived: %d hops\n",msg->my_N_hop); // printf("Bad Routed Packet Arrived: %d hops\n",msg->my_N_hop);
if (routing == NON_MINIMAL_LEAF) { // if (routing == NON_MINIMAL_LEAF) {
if (msg->my_N_hop > 7) // if (msg->my_N_hop > 7)
if (routing == NON_MINIMAL_SPINE) { // if (routing == NON_MINIMAL_SPINE) {
if (msg->my_N_hop > 5) // if (msg->my_N_hop > 5)
if (routing == PROG_ADAPTIVE) { // if (routing == PROG_ADAPTIVE) {
if (!s->rank_tbl) if (!s->rank_tbl)
s->rank_tbl = qhash_init(dragonfly_rank_hash_compare, dragonfly_hash_func, DFLY_HASH_TABLE_SIZE); s->rank_tbl = qhash_init(dragonfly_rank_hash_compare, dragonfly_hash_func, DFLY_HASH_TABLE_SIZE);
...@@ -2615,12 +2615,12 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state * ...@@ -2615,12 +2615,12 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state *
else { //then we are not the specific router, nor are we in the specific router's group. else { //then we are not the specific router, nor are we in the specific router's group.
if (s->dfp_router_type == SPINE) { //then we need to send to the specific group if we have a connection, otherwise we send to a leaf in our group if (s->dfp_router_type == SPINE) { //then we need to send to the specific group if we have a connection, otherwise we send to a leaf in our group
if (specific_router_type == SPINE) { //then it's not good enough to just send to the specific group, we have to send to the specific router // if (specific_router_type == SPINE) { //then it's not good enough to just send to the specific group, we have to send to the specific router
vector< Connection > conns_to_spec_router = s->connMan->get_connections_to_gid(specific_router_id, CONN_GLOBAL); // vector< Connection > conns_to_spec_router = s->connMan->get_connections_to_gid(specific_router_id, CONN_GLOBAL);
if (conns_to_spec_router.size() < 1) // if (conns_to_spec_router.size() < 1)
tw_error(TW_LOC, "Failed to find a connection to specific router\n"); // tw_error(TW_LOC, "Failed to find a connection to specific router\n");
possible_next_conns = conns_to_spec_router; // possible_next_conns = conns_to_spec_router;
vector< Connection > conns_to_spec_group = s->connMan->get_connections_to_group(specific_group_id); vector< Connection > conns_to_spec_group = s->connMan->get_connections_to_group(specific_group_id);
if (conns_to_spec_group.size() < 1) { //then we have to send to a leaf on local if (conns_to_spec_group.size() < 1) { //then we have to send to a leaf on local
...@@ -2781,7 +2781,8 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2781,7 +2781,8 @@ static Connection do_dfp_routing(router_state *s,
if (poss_next_stops.size() < 1) if (poss_next_stops.size() < 1)
tw_error(TW_LOC, "MINIMAL DEAD END\n"); tw_error(TW_LOC, "MINIMAL DEAD END\n");
return poss_next_stops[0]; int randsel = tw_rand_integer(lp->rng, 0, poss_next_stops.size() -1 );
return poss_next_stops[randsel];
else { //routing algorithm is specified in routing else { //routing algorithm is specified in routing
assert( (routing == NON_MINIMAL_LEAF) || (routing == NON_MINIMAL_SPINE) ); assert( (routing == NON_MINIMAL_LEAF) || (routing == NON_MINIMAL_SPINE) );
...@@ -2817,58 +2818,20 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2817,58 +2818,20 @@ static Connection do_dfp_routing(router_state *s,
if (route_to_fdest) { if (route_to_fdest) {
vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id); vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id);
else { //then we need to be going toward the intermediate router else { //then we need to be going toward the intermediate router
msg->path_type = NON_MINIMAL; msg->path_type = NON_MINIMAL;
vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, msg->intm_rtr_id); vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, msg->intm_rtr_id);
tw_error(TW_LOC, "do_dfp_routing(): No route chosen!\n"); tw_error(TW_LOC, "do_dfp_routing(): No route chosen!\n");
static void router_packet_receive_rc(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp)
router_rev_ecount++;
router_ecount--;
int output_port = msg->saved_vc;
int output_chan = msg->saved_channel;
if( isRoutingAdaptive(routing) ) {
//we need to reverse 4
for(int i =0; i < 4; i++)
tw_rand_reverse_unif(lp->rng);
else {
if (bf->c2) {
terminal_plus_message_list *tail =
return_tail(s->pending_msgs[output_port], s->pending_msgs_tail[output_port], output_chan);
delete_terminal_plus_message_list(tail);
s->vc_occupancy[output_port][output_chan] -= s->params->chunk_size;
if (bf->c3) {
codes_local_latency_reverse(lp);
s->in_send_loop[output_port] = 0;
if (bf->c4) {
if (bf->c22) {
s->last_buf_full[output_port][output_chan] = msg->saved_busy_time;
return_tail(s->queued_msgs[output_port], s->queued_msgs_tail[output_port], output_chan));
s->queued_count[output_port] -= s->params->chunk_size;
static void router_verify_valid_receipt(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp) static void router_verify_valid_receipt(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp)
tw_lpid last_sender_lpid = msg->intm_lp_id; tw_lpid last_sender_lpid = msg->intm_lp_id;
...@@ -2922,6 +2885,45 @@ static void router_verify_valid_receipt(router_state *s, tw_bf *bf, terminal_plu ...@@ -2922,6 +2885,45 @@ static void router_verify_valid_receipt(router_state *s, tw_bf *bf, terminal_plu
assert(has_valid_connection); assert(has_valid_connection);
router_ecount--;
else {
if (bf->c2) {
if (bf->c3) {
if (bf->c4) {
if (bf->c22) {
/* MM: This will need changes for the port selection and routing part. The /* MM: This will need changes for the port selection and routing part. The
* progressive adaptive routing would need modification as well. */ * progressive adaptive routing would need modification as well. */
/* Packet arrives at the router and a credit is sent back to the sending terminal/router */ /* Packet arrives at the router and a credit is sent back to the sending terminal/router */
...@@ -2972,7 +2974,6 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -2972,7 +2974,6 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
cur_chunk->msg.next_stop = next_stop; cur_chunk->msg.next_stop = next_stop;
output_chan = 0; output_chan = 0;
if(cur_chunk->msg.dfp_upward_channel_flag) { if(cur_chunk->msg.dfp_upward_channel_flag) {
output_chan = 1; output_chan = 1;
Markdown is supported
0% or
Please register or to comment
