Commit defaa102 authored by Misbah Mubarak's avatar Misbah Mubarak
Updates to modelnet torus plugin: reporting torus average+maximum latency and...
Updates to modelnet torus plugin: reporting torus average+maximum latency and hops traversed via model-net API function
parent ee56819b
...@@ -27,6 +27,7 @@ struct model_net_method ...@@ -27,6 +27,7 @@ struct model_net_method
void (*model_net_method_packet_event_rc)(tw_lp *sender); void (*model_net_method_packet_event_rc)(tw_lp *sender);
const tw_lptype* (*mn_get_lp_type)(); const tw_lptype* (*mn_get_lp_type)();
int (*mn_get_msg_sz)(); int (*mn_get_msg_sz)();
void (*mn_report_stats)();
#endif /* MODELNET_METHOD_H */ #endif /* MODELNET_METHOD_H */
...@@ -128,6 +128,8 @@ const tw_lptype* model_net_get_lp_type(int net_id); ...@@ -128,6 +128,8 @@ const tw_lptype* model_net_get_lp_type(int net_id);
const int model_net_get_packet_size(int net_id); const int model_net_get_packet_size(int net_id);
void model_net_add_lp_type(int net_id); void model_net_add_lp_type(int net_id);
void model_net_report_stats(int net_id);
#endif /* MODELNET_H */ #endif /* MODELNET_H */
...@@ -49,6 +49,7 @@ static void torus_packet_event_rc(tw_lp *sender); ...@@ -49,6 +49,7 @@ static void torus_packet_event_rc(tw_lp *sender);
static void torus_setup(const void* net_params); static void torus_setup(const void* net_params);
static int torus_get_msg_sz(void); static int torus_get_msg_sz(void);
static const tw_lptype* torus_get_lp_type(void); static const tw_lptype* torus_get_lp_type(void);
static void torus_report_stats(void);
/* data structure for torus statistics */ /* data structure for torus statistics */
struct model_net_method torus_method = struct model_net_method torus_method =
...@@ -59,6 +60,7 @@ struct model_net_method torus_method = ...@@ -59,6 +60,7 @@ struct model_net_method torus_method =
.model_net_method_packet_event_rc = torus_packet_event_rc, .model_net_method_packet_event_rc = torus_packet_event_rc,
.mn_get_lp_type = torus_get_lp_type, .mn_get_lp_type = torus_get_lp_type,
.mn_get_msg_sz = torus_get_msg_sz, .mn_get_msg_sz = torus_get_msg_sz,
.mn_report_stats = torus_report_stats,
enum nodes_event_t enum nodes_event_t
...@@ -96,7 +96,7 @@ int model_net_set_params() ...@@ -96,7 +96,7 @@ int model_net_set_params()
char mn_name[MAX_NAME_LENGTH]; char mn_name[MAX_NAME_LENGTH];
int packet_size = 0; int packet_size = 0;
int net_id; int net_id=-1;
config_lpgroups_t paramconf; config_lpgroups_t paramconf;
configuration_get_lpgroups(&config, "PARAMS", &paramconf); configuration_get_lpgroups(&config, "PARAMS", &paramconf);
...@@ -176,7 +176,6 @@ int model_net_set_params() ...@@ -176,7 +176,6 @@ int model_net_set_params()
exit(-1); exit(-1);
i++; i++;
token = strtok(NULL,","); token = strtok(NULL,",");
net_id = model_net_setup("torus", packet_size, (const void*)&net_params); net_id = model_net_setup("torus", packet_size, (const void*)&net_params);
...@@ -249,6 +248,18 @@ const tw_lptype* model_net_get_lp_type(int net_id) ...@@ -249,6 +248,18 @@ const tw_lptype* model_net_get_lp_type(int net_id)
return method_array[net_id]->mn_get_lp_type(); return method_array[net_id]->mn_get_lp_type();
if(net_id < 0 || net_id > NUM_NETS)
fprintf(stderr, "%s Error: Uninitializied modelnet network, call modelnet_init first\n", __FUNCTION__);
exit(-1);
// TODO: ADd checks by network names
// // Add dragonfly and torus network models
return method_array[net_id]->mn_report_stats();
/* registers the lp type */ /* registers the lp type */
void model_net_add_lp_type(int net_id) void model_net_add_lp_type(int net_id)
...@@ -121,6 +121,9 @@ static void simplenet_packet_event( ...@@ -121,6 +121,9 @@ static void simplenet_packet_event(
static void simplenet_packet_event_rc(tw_lp *sender); static void simplenet_packet_event_rc(tw_lp *sender);
static void sn_report_stats();
/* data structure for model-net statistics */ /* data structure for model-net statistics */
struct model_net_method simplenet_method = struct model_net_method simplenet_method =
...@@ -130,6 +133,7 @@ struct model_net_method simplenet_method = ...@@ -130,6 +133,7 @@ struct model_net_method simplenet_method =
.model_net_method_packet_event_rc = simplenet_packet_event_rc, .model_net_method_packet_event_rc = simplenet_packet_event_rc,
.mn_get_lp_type = sn_get_lp_type, .mn_get_lp_type = sn_get_lp_type,
.mn_get_msg_sz = sn_get_msg_sz, .mn_get_msg_sz = sn_get_msg_sz,
.mn_report_stats = sn_report_stats,
static void sn_init( static void sn_init(
...@@ -204,6 +208,12 @@ static void sn_set_params(double net_startup_ns, double net_bw_mbs) ...@@ -204,6 +208,12 @@ static void sn_set_params(double net_startup_ns, double net_bw_mbs)
return; return;
/* report network statistics */
/* TODO: Do we have some simplenet statistics to report like we have for torus and dragonfly? */
return;
sn_state * ns, sn_state * ns,
tw_lp * lp) tw_lp * lp)
...@@ -460,6 +460,21 @@ static void packet_arrive( nodes_state * s, ...@@ -460,6 +460,21 @@ static void packet_arrive( nodes_state * s,
static void torus_report_stats()
unsigned long long avg_hops, total_finished_packets;
tw_stime avg_time, max_time;
MPI_Reduce( &total_hops, &avg_hops, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &N_finished_packets, &total_finished_packets, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &total_time, &avg_time, 1,MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &max_latency, &max_time, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
if(!g_tw_mynode)
printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us \n", (float)avg_hops/total_finished_packets, avg_time/(total_finished_packets*1000), max_time/1000);
void void
final( nodes_state * s, tw_lp * lp ) final( nodes_state * s, tw_lp * lp )
...@@ -195,6 +195,7 @@ int main( ...@@ -195,6 +195,7 @@ int main(
tw_run(); tw_run();
model_net_report_stats(net_id);
ret = lp_io_flush(handle, MPI_COMM_WORLD); ret = lp_io_flush(handle, MPI_COMM_WORLD);
assert(ret == 0); assert(ret == 0);
Markdown is supported
0% or
Please register or to comment
