Commit d603bf86 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Fleshing out example program, and other cleanups
parent 7b22be99
...@@ -16,15 +16,5 @@ LDLIBS = $(shell $(ROSS)/bin/ross-config --libs) -lcodes-net -lcodes-base ...@@ -16,15 +16,5 @@ LDLIBS = $(shell $(ROSS)/bin/ross-config --libs) -lcodes-net -lcodes-base
example: example.c example: example.c
#$(CC) $(ROSS_CPPFLAGS) $(CPPFLAGS) $(CFLAGS) $(ROSS_LDFLAGS) $^ -o $@ -L$(ROSS)/lib -lROSS -lm -L$(CODESBASE)/lib -lcodes-base -L$(CODESNET)/lib -lcodes-net clean:
rm -f example
check-env:
ifndef CODESBASE
$(error CODESBASE is undefined, see README.txt)
endif
ifndef CODESNET
$(error CODESNET is undefined, see README.txt)
endif
ifndef ROSS
$(error ROSS is undefined, see README.txt)
endif
This diff is collapsed.
# the LPGROUPS set is required by all simulations using codes. Multiple groups
# can be entered (only one is here for our example), each consisting of a set
# of application- and codes-specific key-value pairs.
LPGROUPS
# in our simulation, we simply have a set of servers, each with
# point-to-point access to each other
SERVERS
# required: number of times to repeat the following key-value pairs
repetitions="16";
# application-specific: parsed in main
server="1";
# model-net-specific field defining the network backend. In this example,
# each server has one NIC, and each server are point-to-point connected
modelnet_simplenet="1";
# required by CODES: miscellaneous parameters used in the simulation that
# don't fit in group definition.
PARAMS
# ROSS-specific parmeters:
# - message_size: ROSS expects you to upper bound your event message size.
# Going over this size will crash or otherwise destroy your
# simulation.
message_size="256";
# model-net-specific parameters:
# - individual packet sizes for network operations
# (each "packet" is represented by an event)
# - independent of underlying network being used
packet_size="512";
# - type of model to use (must match with corresponding LPGROUPS entry)
modelnet="simplenet";
# - model-specific parameters
net_startup_ns="1.5";
net_bw_mbps="20000";
# custom parameter sets can also be added - this one isn't used in the
# simulation, but is included for illustrative purposes
blah
param1="hello";
param2="goodbye";
param3="0.0001";
LPGROUPS
MODELNET_GRP
repetitions="16";
server="1";
PARAMS
packet_size="512";
message_size="256";
Markdown is supported
0%
or
Please register or to comment
