Commit d1e36f84 authored by Caitlin Ross's avatar Caitlin Ross
updating dfly-plus for use with damaris
parent 3e4bff24
...@@ -416,6 +416,11 @@ int main( ...@@ -416,6 +416,11 @@ int main(
tw_opt_add(app_opt); tw_opt_add(app_opt);
tw_init(&argc, &argv); tw_init(&argc, &argv);
#ifdef USE_RDAMARIS
if(g_st_ross_rank)
{ // keep damaris ranks from running code between here up until tw_end()
#endif
codes_comm_update();
if(argc < 2) if(argc < 2)
...@@ -477,6 +482,9 @@ int main( ...@@ -477,6 +482,9 @@ int main(
assert(ret == 0 || !"lp_io_flush failure"); assert(ret == 0 || !"lp_io_flush failure");
model_net_report_stats(net_id); model_net_report_stats(net_id);
#ifdef USE_RDAMARIS
} // end if(g_st_ross_rank)
#endif
tw_end(); tw_end();
return 0; return 0;
Markdown is supported
0% or
Please register or to comment
