Commit ca197239 authored by Neil McGlohon's avatar Neil McGlohon
DFP: allow intermediate routers to be spines for adaptive routing
parent 171757e0
...@@ -2440,12 +2440,16 @@ static int dfp_pick_intermediate_router(router_state *s, tw_bf *bf, terminal_plu ...@@ -2440,12 +2440,16 @@ static int dfp_pick_intermediate_router(router_state *s, tw_bf *bf, terminal_plu
int intm_group_id = other_groups[tw_rand_integer(lp->rng, 0, other_groups.size() -1 )]; int intm_group_id = other_groups[tw_rand_integer(lp->rng, 0, other_groups.size() -1 )];
int intm_loc_id; int intm_loc_id;
int intm_router_id; int intm_router_id;
if (routing == NON_MINIMAL_SPINE) { if (isRoutingAdaptive(routing)) { //INTM ROUTER CAN BE SPINE OR LEAF
intm_loc_id = tw_rand_integer(lp->rng, 0, s->params->num_routers -1);
intm_router_id = (intm_group_id * s->params->num_routers) + intm_loc_id;
else if (routing == NON_MINIMAL_SPINE) {
intm_loc_id = tw_rand_integer(lp->rng, s->params->num_router_leaf, s->params->num_routers -1); intm_loc_id = tw_rand_integer(lp->rng, s->params->num_router_leaf, s->params->num_routers -1);
intm_router_id = (intm_group_id * s->params->num_routers) + intm_loc_id; intm_router_id = (intm_group_id * s->params->num_routers) + intm_loc_id;
assert(router_type_map[intm_router_id] == SPINE); assert(router_type_map[intm_router_id] == SPINE);
else { else { //non-minimal-leaf
intm_loc_id = tw_rand_integer(lp->rng, 0, s->params->num_router_leaf -1); intm_loc_id = tw_rand_integer(lp->rng, 0, s->params->num_router_leaf -1);
assert(router_type_map[intm_router_id] == LEAF); assert(router_type_map[intm_router_id] == LEAF);
...@@ -2565,8 +2569,8 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state * ...@@ -2565,8 +2569,8 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state *
int specific_group_id = specific_router_id / s->params->num_routers; int specific_group_id = specific_router_id / s->params->num_routers;
router_type specific_router_type = router_type_map[specific_router_id]; router_type specific_router_type = router_type_map[specific_router_id];
if (specific_router_type == SPINE) // if (specific_router_type == SPINE)
tw_error(TW_LOC, "ROUTING TO SPINE NOT SUPPORTED\n"); //TODO when picking intm_rtr_id at the origin leaf, we need to pick a spine router that has a direct connection to our group! // tw_error(TW_LOC, "ROUTING TO SPINE NOT SUPPORTED\n"); //TODO when picking intm_rtr_id at the origin leaf, we need to pick a spine router that has a direct connection to our group!
vector< Connection > possible_next_conns; vector< Connection > possible_next_conns;
...@@ -2575,11 +2579,11 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state * ...@@ -2575,11 +2579,11 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state *
else if (my_group_id == specific_group_id) { else if (my_group_id == specific_group_id) {
if (s->dfp_router_type == SPINE) { if (s->dfp_router_type == SPINE) { //we are spine and we are not the specific router
if (specific_router_type == SPINE) { //Then we need to send to one of our leafs first on local if (specific_router_type == SPINE) { //the specific router is a spine and we're not it so then we need to send to one of our leafs first on local
possible_next_conns = s->connMan->get_connections_by_type(CONN_LOCAL); possible_next_conns = s->connMan->get_connections_by_type(CONN_LOCAL);
else { //Then we have a local connection to the specific router on local else { // Then the spec router's a leaf and we have a local connection to the specific router on local
assert(specific_router_type == LEAF); assert(specific_router_type == LEAF);
possible_next_conns = s->connMan->get_connections_to_gid(specific_router_id, CONN_LOCAL); possible_next_conns = s->connMan->get_connections_to_gid(specific_router_id, CONN_LOCAL);
...@@ -2630,15 +2634,18 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state * ...@@ -2630,15 +2634,18 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state *
if (possible_next_conns_to_group.size() < 1) if (possible_next_conns_to_group.size() < 1)
tw_error(TW_LOC, "Something went wrong when trying to send to a spine with connection to spec group\n"); tw_error(TW_LOC, "Something went wrong when trying to send to a spine with connection to spec group\n");
if (specific_router_type == SPINE) { //then its not good enough to just send to a spine with a connection to the group, it has to go to a spine that has a direct conn to the spec router id // if (specific_router_type == SPINE) { //then its not good enough to just send to a spine with a connection to the group, it has to go to a spine that has a direct conn to the spec router id
for(int i = 0; i < possible_next_conns_to_group.size(); i++) // for(int i = 0; i < possible_next_conns_to_group.size(); i++)
Connection poss_next_spine = possible_next_conns_to_group[i]; // Connection poss_next_spine = possible_next_conns_to_group[i];
vector< Connection> connecting_conns_to_spec = connManagerList[poss_next_spine.dest_gid].get_connections_to_gid(specific_router_id, CONN_GLOBAL); // vector< Connection> connecting_conns_to_spec = connManagerList[poss_next_spine.dest_gid].get_connections_to_gid(specific_router_id, CONN_GLOBAL);
if (connecting_conns_to_spec.size() > 0) { //then poss_next_spine is a valid next stop, add my connections to it as possible next stops // if (connecting_conns_to_spec.size() > 0) { //then poss_next_spine is a valid next stop, add my connections to it as possible next stops
possible_next_conns.push_back(poss_next_spine); // possible_next_conns.push_back(poss_next_spine);
if (specific_router_type == SPINE) { //for now let's allow our spine routers to just send to the group, let them route it to the spec router
possible_next_conns = possible_next_conns_to_group;
else { //then just sending to the group is good enough else { //then just sending to the group is good enough
possible_next_conns = possible_next_conns_to_group; possible_next_conns = possible_next_conns_to_group;
...@@ -2663,8 +2670,6 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi ...@@ -2663,8 +2670,6 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi
bool outside_source_group = (my_group_id != origin_group_id); bool outside_source_group = (my_group_id != origin_group_id);
int adaptive_threshold = s->params->adaptive_threshold; int adaptive_threshold = s->params->adaptive_threshold;
if (msg->intm_rtr_id == -1) //then we havent picked an intermediate router yet
msg->intm_rtr_id = dfp_pick_intermediate_router(s, bf, msg, lp, origin_group_id, fdest_group_id);
if (msg->intm_rtr_id == my_router_id) //then we are the intermediate router and need to forward to fdest on the upward channel (VL 1) if (msg->intm_rtr_id == my_router_id) //then we are the intermediate router and need to forward to fdest on the upward channel (VL 1)
msg->dfp_upward_channel_flag = 1; msg->dfp_upward_channel_flag = 1;
...@@ -2733,6 +2738,9 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2733,6 +2738,9 @@ static Connection do_dfp_routing(router_state *s,
bool in_intermediate_group = (my_group_id != origin_group_id) && (my_group_id != fdest_group_id); bool in_intermediate_group = (my_group_id != origin_group_id) && (my_group_id != fdest_group_id);
Connection nextStopConn; //the connection that we will forward the packet to Connection nextStopConn; //the connection that we will forward the packet to
//----------- LOCAL GROUP ROUTING -------------- //----------- LOCAL GROUP ROUTING --------------
...@@ -2781,8 +2789,9 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2781,8 +2789,9 @@ static Connection do_dfp_routing(router_state *s,
route_to_fdest = true; route_to_fdest = true;
else { //then we still need to go to the intermediate router else { //then we still need to go to the intermediate router
//do nothing for now
if (msg->intm_rtr_id == -1) if (msg->intm_rtr_id == -1)
msg->intm_rtr_id = dfp_pick_intermediate_router(s, bf, msg, lp, origin_group_id, fdest_group_id); tw_error(TW_LOC, "intm router id not set!");
else { else {
Markdown is supported
0% or
Please register or to comment
