Commit c8cf3cc6 authored by Caitlin Ross's avatar Caitlin Ross
Merge branch 'master' into ross-updates
parents eca27707 aab92d45
...@@ -6,7 +6,8 @@ Contributors to date (in chronological order, with current affiliations) ...@@ -6,7 +6,8 @@ Contributors to date (in chronological order, with current affiliations)
- Shane Snyder, Argonne National Labs - Shane Snyder, Argonne National Labs
- Jonathan P. Jenkins - Jonathan P. Jenkins
- Noah Wolfe, RPI - Noah Wolfe, RPI
- Nikhil Jain, Lawrence Livermore Labs - Nikhil Jain, Nvidia
- Giorgis Georgakoudis, Lawrence Livermore Labs
- Matthieu Dorier, Argonne National Labs - Matthieu Dorier, Argonne National Labs
- Caitlin Ross, RPI - Caitlin Ross, RPI
- Xu Yang, Amazon - Xu Yang, Amazon
## README for using ROSS instrumentation with CODES ## README for using ROSS instrumentation with CODES
For details about the ROSS instrumentation, see the [ROSS Instrumentation blog post](http://carothersc.github.io/ROSS/instrumentation/instrumentation.html) For details about the ROSS instrumentation, see the [ROSS Instrumentation blog post](http://ross-org.github.io/instrumentation/instrumentation.html)
on the ROSS webpage. on the ROSS webpage.
There are currently 4 types of instrumentation: GVT-based, real time sampling, virtual time sampling, and event tracing. There are currently 4 types of instrumentation: GVT-based, real time sampling, virtual time sampling, and event tracing.
See the ROSS documentation for more info on the specific options or use `--help` with your model. See the ROSS documentation for more info on the specific options or use `--help` with your model.
To collect data about the simulation engine, no changes are needed to model code for any of the instrumentation modes. To collect data about the simulation engine, no changes are needed to model code for any of the instrumentation modes.
Some additions to the model code is needed in order to turn on any model-level data collection. Some additions to the model code is needed in order to turn on any model-level data collection.
See the "Model-level data sampling" section on [ROSS Instrumentation blog post](http://carothersc.github.io/ROSS/instrumentation/instrumentation.html). See the "Model-level data sampling" section on [ROSS Instrumentation blog post](http://ross-org.github.io/instrumentation/instrumentation.html).
Here we describe CODES specific details. Here we describe CODES specific details.
### Register Instrumentation Callback Functions ### Register Instrumentation Callback Functions
...@@ -37,13 +37,13 @@ The second pointer is for the data to be sampled at the GVT or real time samplin ...@@ -37,13 +37,13 @@ The second pointer is for the data to be sampled at the GVT or real time samplin
In this case the LPs have different function pointers since we want to collect different types of data for the two LP types. In this case the LPs have different function pointers since we want to collect different types of data for the two LP types.
For the terminal, I set the appropriate size of the data to be collected, but for the router, the size of the data is dependent on the radix for the dragonfly configuration being used, which isn't known until runtime. For the terminal, I set the appropriate size of the data to be collected, but for the router, the size of the data is dependent on the radix for the dragonfly configuration being used, which isn't known until runtime.
*Note*: You can only reuse the function for event tracing for LPs that use the same type of message struct. *Note*: You can only reuse the function for event tracing for LPs that use the same type of message struct.
For example, the dragonfly terminal and router LPs both use the `terminal_message` struct, so they can For example, the dragonfly terminal and router LPs both use the `terminal_message` struct, so they can
use the same functions for event tracing. use the same functions for event tracing.
However the model net base LP uses the `model_net_wrap_msg` struct, so it gets its own event collection function and `st_trace_type` struct, in order to read the event type correctly from the model. However the model net base LP uses the `model_net_wrap_msg` struct, so it gets its own event collection function and `st_trace_type` struct, in order to read the event type correctly from the model.
In the ROSS instrumentation documentation, there are two methods provided for letting ROSS know about these `st_model_types` structs. In the ROSS instrumentation documentation, there are two methods provided for letting ROSS know about these `st_model_types` structs.
In CODES, this step is a little different, as `codes_mapping_setup()` calls `tw_lp_settype()`. In CODES, this step is a little different, as `codes_mapping_setup()` calls `tw_lp_settype()`.
Instead, you add a function to return this struct for each of your LP types: Instead, you add a function to return this struct for each of your LP types:
```C ```C
static const st_model_types *dragonfly_get_model_types(void) static const st_model_types *dragonfly_get_model_types(void)
...@@ -73,7 +73,7 @@ static void router_register_model_types(st_model_types *base_type) ...@@ -73,7 +73,7 @@ static void router_register_model_types(st_model_types *base_type)
At this point, there are two different steps to follow depending on whether the model is one of the model-net models or not. At this point, there are two different steps to follow depending on whether the model is one of the model-net models or not.
##### Model-net Models ##### Model-net Models
In the `model_net_method` struct, two fields have been added: `mn_model_stat_register` and `mn_get_model_stat_types`. In the `model_net_method` struct, two fields have been added: `mn_model_stat_register` and `mn_get_model_stat_types`.
You need to set these to the functions described above. For example: You need to set these to the functions described above. For example:
```C ```C
...@@ -115,21 +115,21 @@ static void svr_register_model_types() ...@@ -115,21 +115,21 @@ static void svr_register_model_types()
int main(int argc, char **argv) int main(int argc, char **argv)
// ... some set up removed for brevity // ... some set up removed for brevity
model_net_register(); model_net_register();
svr_add_lp_type(); svr_add_lp_type();
if (g_st_ev_trace || g_st_model_stats) if (g_st_ev_trace || g_st_model_stats)
svr_register_model_types(); svr_register_model_types();
codes_mapping_setup(); codes_mapping_setup();
`g_st_ev_trace` is a ROSS flag for determining if event tracing is turned on and `g_st_model_stats` determines if the GVT-based or real time instrumentation `g_st_ev_trace` is a ROSS flag for determining if event tracing is turned on and `g_st_model_stats` determines if the GVT-based or real time instrumentation
modes are collecting model-level data as well. modes are collecting model-level data as well.
### CODES LPs that currently have event type collection implemented: ### CODES LPs that currently have event type collection implemented:
...@@ -144,4 +144,3 @@ If you're using any of the following CODES models, you don't have to add anythin ...@@ -144,4 +144,3 @@ If you're using any of the following CODES models, you don't have to add anythin
- slimfly router and terminal LPs (slimfly.c) - slimfly router and terminal LPs (slimfly.c)
- fat tree switch and terminal LPs (fat-tree.c) - fat tree switch and terminal LPs (fat-tree.c)
- model-net-base-lp (model-net-lp.c) - model-net-base-lp (model-net-lp.c)
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
# Process this file with autoconf to produce a configure script. # Process this file with autoconf to produce a configure script.
AC_PREREQ([2.67]) AC_PREREQ([2.67])
AC_INIT([codes], [1.0.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/]) AC_INIT([codes], [1.1.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/])
LT_INIT LT_INIT
...@@ -2,12 +2,12 @@ NOTE: see bottom of this file for suggested configurations on particular ANL ...@@ -2,12 +2,12 @@ NOTE: see bottom of this file for suggested configurations on particular ANL
machines. machines.
0 - Checkout, build, and install the trunk version of ROSS 0 - Checkout, build, and install the trunk version of ROSS
(https://github.com/carothersc/ROSS). At the time of (https://github.com/ross-org/ROSS). At the time of
release (0.6.0), ROSS's latest commit hash was 10d7a06b2d, so this revision is release (0.6.0), ROSS's latest commit hash was 10d7a06b2d, so this revision is
"safe" in the unlikely case incompatible changes come along in the future. If "safe" in the unlikely case incompatible changes come along in the future. If
working from the CODES master branches, use the ROSS master branch. working from the CODES master branches, use the ROSS master branch.
git clone http://github.com/carothersc/ROSS.git git clone http://github.com/ross-org/ROSS.git
# if using 0.5.2 release: git checkout d3bdc07 # if using 0.5.2 release: git checkout d3bdc07
cd ROSS cd ROSS
mkdir build mkdir build
...@@ -22,7 +22,7 @@ working from the CODES master branches, use the ROSS master branch. ...@@ -22,7 +22,7 @@ working from the CODES master branches, use the ROSS master branch.
ROSS/install/ directory> ROSS/install/ directory>
For more details on installing ROSS, go to For more details on installing ROSS, go to
https://github.com/carothersc/ROSS/blob/master/README.md . https://github.com/ross-org/ROSS/blob/master/README.md .
If using ccmake to configure, don't forget to set CMAKE_C_COMPILER and If using ccmake to configure, don't forget to set CMAKE_C_COMPILER and
CMAKE_CXX_COMPILER to mpicc/mpicxx CMAKE_CXX_COMPILER to mpicc/mpicxx
...@@ -14,7 +14,7 @@ https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users ...@@ -14,7 +14,7 @@ https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
== CODES == CODES
* main site: http://www.mcs.anl.gov/projects/codes/ * main site: http://www.mcs.anl.gov/projects/codes/
* repositories: * repositories:
* "base" (this repository): git.mcs.anl.gov:radix/codes-base * "base" (this repository): git.mcs.anl.gov:radix/codes-base
* codes-net (networking component of CODES): git.mcs.anl.gov:radix/codes-net * codes-net (networking component of CODES): git.mcs.anl.gov:radix/codes-net
...@@ -22,11 +22,11 @@ https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users ...@@ -22,11 +22,11 @@ https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
== ROSS == ROSS
* main site, repository, etc.: https://github.com/carothersc/ROSS * main site, repository, etc.: https://github.com/ross-org/ROSS
* both the site and repository contain good documentation as well - refer to * both the site and repository contain good documentation as well - refer to
it for an in-depth introduction and overview of ROSS proper it for an in-depth introduction and overview of ROSS proper
= Components of CODES = Components of CODES
== Configuration == Configuration
...@@ -36,7 +36,7 @@ structured configuration file. The configuration format allows categories, and ...@@ -36,7 +36,7 @@ structured configuration file. The configuration format allows categories, and
optionally subgroups within the category, of key-value pairs for configuration. optionally subgroups within the category, of key-value pairs for configuration.
The LPGROUPS category defines the LP configuration. The PARAMS category is The LPGROUPS category defines the LP configuration. The PARAMS category is
currently used for networking and ROSS-specific parameters. User-defined currently used for networking and ROSS-specific parameters. User-defined
categories can also be used. categories can also be used.
The configuration system additionally allows LP specialization via the usage of The configuration system additionally allows LP specialization via the usage of
"annotations". This allows two otherwise identical LPs to have different "annotations". This allows two otherwise identical LPs to have different
...@@ -125,7 +125,7 @@ The format of the metadata file is a set of lines containing: ...@@ -125,7 +125,7 @@ The format of the metadata file is a set of lines containing:
<group ID> <start ID> <end ID inclusive> <kernel file> <group ID> <start ID> <end ID inclusive> <kernel file>
where: where:
* <group ID> is the ID of this group (see restrictions) * <group ID> is the ID of this group (see restrictions)
* <start ID> and <end ID> form the range of logical client IDs that will * <start ID> and <end ID> form the range of logical client IDs that will
perform the given workload. Note that the end ID is inclusive, so a start, perform the given workload. Note that the end ID is inclusive, so a start,
end pair of 0, 3 will include IDs 0, 1, 2, and 3. An <end ID> of -1 indicates end pair of 0, 3 will include IDs 0, 1, 2, and 3. An <end ID> of -1 indicates
to use the remaining number of clients as specified by the user. to use the remaining number of clients as specified by the user.
...@@ -202,6 +202,15 @@ should be everything up to the rank number. E.g., if the dumpi files are of the ...@@ -202,6 +202,15 @@ should be everything up to the rank number. E.g., if the dumpi files are of the
form "dumpi-YYYY.MM.DD.HH.MM.SS-XXXX.bin", then the input should be form "dumpi-YYYY.MM.DD.HH.MM.SS-XXXX.bin", then the input should be
"dumpi-YYYY.MM.DD.HH.MM.SS-" "dumpi-YYYY.MM.DD.HH.MM.SS-"
=== Quality of Service
Two models (dragonfly-dally.C and dragonfly-plus.C) can now support traffic
differentiation and prioritization. The models support quality of service by
directing the network traffic on separate class of virtual channels. Additional
documentation on using traffic classes can be found at the wiki link:
https://xgitlab.cels.anl.gov/codes/codes/wikis/Quality-of-Service
=== Workload generator helpers === Workload generator helpers
The codes-jobmap API (codes/codes-jobmap.h) specifies mechanisms to initialize The codes-jobmap API (codes/codes-jobmap.h) specifies mechanisms to initialize
...@@ -288,7 +297,7 @@ lsm ...@@ -288,7 +297,7 @@ lsm
The API can be found at codes/local-storage-model.h and example usage can be The API can be found at codes/local-storage-model.h and example usage can be
seen in tests/local-storage-model-test.c and tests/conf/lsm-test.conf. seen in tests/local-storage-model-test.c and tests/conf/lsm-test.conf.
The queueing policy of LSM is currently FIFO, and the default mode uses an The queueing policy of LSM is currently FIFO, and the default mode uses an
implicit queue, simply incrementing counters and scheduling future events when implicit queue, simply incrementing counters and scheduling future events when
...@@ -359,7 +368,7 @@ model-net LPs, like any other LP in CODES/ROSS, require specification in the ...@@ -359,7 +368,7 @@ model-net LPs, like any other LP in CODES/ROSS, require specification in the
configuration file as well as LP-specific parameters. To identify model-net LPs configuration file as well as LP-specific parameters. To identify model-net LPs
to CODES, we use the naming scheme of prefixing model-net LP names with the to CODES, we use the naming scheme of prefixing model-net LP names with the
string "modelnet_". For example, the "simplenet" LP (see "model-net models") string "modelnet_". For example, the "simplenet" LP (see "model-net models")
would be specified in the LPGROUPS section as "modelnet_simplenet". would be specified in the LPGROUPS section as "modelnet_simplenet".
Currently, model-net LPs expect their configuration values in the PARAMS Currently, model-net LPs expect their configuration values in the PARAMS
section. This is due to historical precedent and may be changed in the future section. This is due to historical precedent and may be changed in the future
...@@ -389,7 +398,7 @@ program, they will be printed to the specified directory. ...@@ -389,7 +398,7 @@ program, they will be printed to the specified directory.
= model-net models = model-net models
Currently, model-net contains a combination of analytical models and specific Currently, model-net contains a combination of analytical models and specific
models for high-performance networking, with an HPC bent. models for high-performance networking, with an HPC bent.
Configuration files for each model can be found in tests/conf, under the name Configuration files for each model can be found in tests/conf, under the name
"model-net-test*.conf". "model-net-test*.conf".
...@@ -402,7 +411,7 @@ infinite packet buffering when routing. These are best used for models that ...@@ -402,7 +411,7 @@ infinite packet buffering when routing. These are best used for models that
require little fidelity out of the network performance. SimpleP2P is the same require little fidelity out of the network performance. SimpleP2P is the same
model as Simplenet, except it provides heterogeneous link capacities from point model as Simplenet, except it provides heterogeneous link capacities from point
to point. Rather than a single entry, it requires files containing a matrix of to point. Rather than a single entry, it requires files containing a matrix of
point-to-point bandwidths and latencies. point-to-point bandwidths and latencies.
Simplenet models require two configuration parameters: "net_startup_ns" and Simplenet models require two configuration parameters: "net_startup_ns" and
"net_bw_mbps", which define the startup and bandwidth costs in nanoseconds and "net_bw_mbps", which define the startup and bandwidth costs in nanoseconds and
...@@ -426,7 +435,7 @@ The only configuration entry the LogGP model requires is ...@@ -426,7 +435,7 @@ The only configuration entry the LogGP model requires is
configuration file. configuration file.
For more details on gathering parameters for the LogGP model, as well as it's For more details on gathering parameters for the LogGP model, as well as it's
usage and caveats, see the document src/model-net/doc/README.loggp.txt. usage and caveats, see the document src/model-net/doc/README.loggp.txt.
== Torus == Torus
...@@ -454,7 +463,7 @@ The configuration parameters are a little trickier here, as additional LPs ...@@ -454,7 +463,7 @@ The configuration parameters are a little trickier here, as additional LPs
other than the "modelnet_dragonfly" LP must be specified. "modelnet_dragonfly" other than the "modelnet_dragonfly" LP must be specified. "modelnet_dragonfly"
represent the node LPs (terminals), while a second type "dragonfly_router" represent the node LPs (terminals), while a second type "dragonfly_router"
represents a physical router. At least one "dragonfly_router" LP must be represents a physical router. At least one "dragonfly_router" LP must be
present in every LP group with a "modelnet_dragonfly" LP. present in every LP group with a "modelnet_dragonfly" LP.
Further configuration and model setup can be found at Further configuration and model setup can be found at
src/model-net/doc/README.dragonfly.txt. src/model-net/doc/README.dragonfly.txt.
...@@ -509,7 +518,7 @@ section of the example.conf config file. ...@@ -509,7 +518,7 @@ section of the example.conf config file.
== Server state and event handlers == Server state and event handlers
The server LP state maintains a count of the number of remote messages it has The server LP state maintains a count of the number of remote messages it has
sent and received as well as the number of local completion messages. sent and received as well as the number of local completion messages.
For the server event message, we have four message types: KICKOFF, REQ, ACK and For the server event message, we have four message types: KICKOFF, REQ, ACK and
LOCAL. With a KICKOFF event, each LP sends a message to itself to begin the LOCAL. With a KICKOFF event, each LP sends a message to itself to begin the
...@@ -517,7 +526,7 @@ simulation proper. To avoid event ties, we add a small amount of random noise ...@@ -517,7 +526,7 @@ simulation proper. To avoid event ties, we add a small amount of random noise
using codes_local_latency. The REQ message is sent by a server to its using codes_local_latency. The REQ message is sent by a server to its
neighboring server and when received, neighboring server sends back a message neighboring server and when received, neighboring server sends back a message
of type ACK. We've shown a hard-coded direct communication method which of type ACK. We've shown a hard-coded direct communication method which
directly computes the LP ID, and a codes-mapping API-based method. directly computes the LP ID, and a codes-mapping API-based method.
== Server reverse computation == Server reverse computation
...@@ -533,19 +542,19 @@ conservative modes, so reverse computation may not be necessary if the ...@@ -533,19 +542,19 @@ conservative modes, so reverse computation may not be necessary if the
simulation is not compute- or memory-intensive. simulation is not compute- or memory-intensive.
For our example program, recall the "forward" event handlers. They perform the For our example program, recall the "forward" event handlers. They perform the
following: following:
* Kickoff: send a message to the peer server, and increment sender LP's * Kickoff: send a message to the peer server, and increment sender LP's
count of sent messages. count of sent messages.
* Request (received from peer server): increment receiver count of * Request (received from peer server): increment receiver count of
received messages, and send an acknowledgement to the sender. received messages, and send an acknowledgement to the sender.
* Acknowledgement (received from message receiver): send the next * Acknowledgement (received from message receiver): send the next
message to the receiver and increment messages sent count. Set a flag message to the receiver and increment messages sent count. Set a flag
indicating whether a message has been sent. indicating whether a message has been sent.
* Local model-net callback: increment the local model-net * Local model-net callback: increment the local model-net
received messages count. received messages count.
In terms of LP state, the four operations are simply modifying counts. Hence, In terms of LP state, the four operations are simply modifying counts. Hence,
the "reverse" event handlers need to merely roll back those changes: the "reverse" event handlers need to merely roll back those changes:
* Kickoff: decrement sender LP's count of sent messages. * Kickoff: decrement sender LP's count of sent messages.
* Request (received from peer server): decrement receiver count of * Request (received from peer server): decrement receiver count of
received messages. received messages.
...@@ -16,7 +16,7 @@ per compute node or one multi-port NIC per node. ...@@ -16,7 +16,7 @@ per compute node or one multi-port NIC per node.
Adding a generic template for building new network models. For simplest case, Adding a generic template for building new network models. For simplest case,
only 2 functions and premable changes should suffice to add a new network. only 2 functions and premable changes should suffice to add a new network.
Updated Express Mesh network model to serve as an example. For details, see Updated Express Mesh network model to serve as an example. For details, see
Darshan workload generator has been updated to use Darshan version 3.x. Darshan workload generator has been updated to use Darshan version 3.x.
...@@ -28,11 +28,11 @@ https://xgitlab.cels.anl.gov/codes/codes/wikis/Using-ROSS-Instrumentation-with-C ...@@ -28,11 +28,11 @@ https://xgitlab.cels.anl.gov/codes/codes/wikis/Using-ROSS-Instrumentation-with-C
Compatible with ROSS version that enables statistics collection of simulation Compatible with ROSS version that enables statistics collection of simulation
performance. For details see: performance. For details see:
http://carothersc.github.io/ROSS/instrumentation/instrumentation.html http://ross-org.github.io/instrumentation/instrumentation.html
Online workload replay functionality has been added that allows SWM workloads Online workload replay functionality has been added that allows SWM workloads
to be simulated insitu on the network models. WIP to integrate Conceptual to be simulated insitu on the network models. WIP to integrate Conceptual
domain specific language for network communication. domain specific language for network communication.
Multiple traffic patterns were added in the background traffic generation Multiple traffic patterns were added in the background traffic generation
including stencil, all-to-all and random permutation. including stencil, all-to-all and random permutation.
...@@ -93,7 +93,7 @@ Background network communication using uniform random workload can now be ...@@ -93,7 +93,7 @@ Background network communication using uniform random workload can now be
generated. The traffic generation gets automatically shut off when the main workload generated. The traffic generation gets automatically shut off when the main workload
finishes. finishes.
Collectives can now be translated into point to point using the CoRTex library. Collectives can now be translated into point to point using the CoRTex library.
Performance of MPI_AllReduce is reported when debug_cols option is enabled. Performance of MPI_AllReduce is reported when debug_cols option is enabled.
...@@ -121,7 +121,7 @@ xleftmargin=6ex ...@@ -121,7 +121,7 @@ xleftmargin=6ex
% IEEEtran.cls handling of captions and this will result in nonIEEE style % IEEEtran.cls handling of captions and this will result in nonIEEE style
% figure/table captions. To prevent this problem, be sure and preload % figure/table captions. To prevent this problem, be sure and preload
% caption.sty with its "caption=false" package option. This is will preserve % caption.sty with its "caption=false" package option. This is will preserve
% IEEEtran.cls handing of captions. Version 1.3 (2005/06/28) and later % IEEEtran.cls handing of captions. Version 1.3 (2005/06/28) and later
% (recommended due to many improvements over 1.2) of subfig.sty supports % (recommended due to many improvements over 1.2) of subfig.sty supports
% the caption=false option directly: % the caption=false option directly:
%\usepackage[caption=false,font=footnotesize]{subfig} %\usepackage[caption=false,font=footnotesize]{subfig}
...@@ -188,7 +188,7 @@ easily shared and reused. It also includes a few tips to help avoid common ...@@ -188,7 +188,7 @@ easily shared and reused. It also includes a few tips to help avoid common
simulation bugs. simulation bugs.
For more information, ROSS has a bunch of documentation available in their For more information, ROSS has a bunch of documentation available in their
repository/wiki - see \url{https://github.com/carothersc/ROSS}. repository/wiki - see \url{https://github.com/ross-org/ROSS}.
\end{abstract} \end{abstract}
\section{CODES: modularizing models} \section{CODES: modularizing models}
...@@ -394,7 +394,7 @@ action upon the completion of them. More generally, the problem is: an event ...@@ -394,7 +394,7 @@ action upon the completion of them. More generally, the problem is: an event
issuance (an ack to the client) is based on the completion of more than one issuance (an ack to the client) is based on the completion of more than one
asynchronous/parallel events (local write on primary server, forwarding write to asynchronous/parallel events (local write on primary server, forwarding write to
replica server). Further complicating the matter for storage simulations, there replica server). Further complicating the matter for storage simulations, there
can be any number of outstanding requests, each waiting on multiple events. can be any number of outstanding requests, each waiting on multiple events.
In ROSS's sequential and conservative parallel modes, the necessary state can In ROSS's sequential and conservative parallel modes, the necessary state can
easily be stored in the LP as a queue of statuses for each set of events, easily be stored in the LP as a queue of statuses for each set of events,
...@@ -488,7 +488,7 @@ Most core ROSS examples are design to intentionally hit ...@@ -488,7 +488,7 @@ Most core ROSS examples are design to intentionally hit
the end timestamp for the simulation (i.e. they are modeling a continuous, the end timestamp for the simulation (i.e. they are modeling a continuous,
steady state system). This isn't necessarily true for other models. Quite steady state system). This isn't necessarily true for other models. Quite
simply, set g\_tw\_ts\_end to an arbitrary large number when running simulations simply, set g\_tw\_ts\_end to an arbitrary large number when running simulations
that have a well-defined end-point in terms of events processed. that have a well-defined end-point in terms of events processed.
Within the LP finalize function, do not call tw\_now. The time returned may not Within the LP finalize function, do not call tw\_now. The time returned may not
be consistent in the case of an optimistic simulation. be consistent in the case of an optimistic simulation.
...@@ -515,7 +515,7 @@ section(s). ...@@ -515,7 +515,7 @@ section(s).
\item generating multiple concurrent events makes rollback more difficult \item generating multiple concurrent events makes rollback more difficult
\end{enumerate} \end{enumerate}
\item use dummy events to work around "event-less" advancement of simulation time \item use dummy events to work around "event-less" advancement of simulation time
\item add a small amount of time "noise" to events to prevent ties \item add a small amount of time "noise" to events to prevent ties
...@@ -44,7 +44,7 @@ Notes on how to release a new version of CODES ...@@ -44,7 +44,7 @@ Notes on how to release a new version of CODES
4. Upload the release tarball 4. Upload the release tarball
- Our release directory is at ftp.mcs.anl.gov/pub/CODES/releases . There's no - Our release directory is at ftp.mcs.anl.gov/pub/CODES/releases . There's no
web interface, so you have to get onto an MCS workstation and copy the web interface, so you have to get onto an MCS workstation and copy the
release in that way (the ftp server is mounted at /homes/ftp). release in that way (the ftp server is mounted at /mcs/ftp.mcs.anl.gov).
5. Update website 5. Update website
- Project wordpress: http://www.mcs.anl.gov/projects/codes/ (you need - Project wordpress: http://www.mcs.anl.gov/projects/codes/ (you need
...@@ -18,6 +18,7 @@ argobots_libs=@ARGOBOTS_LIBS@ ...@@ -18,6 +18,7 @@ argobots_libs=@ARGOBOTS_LIBS@
argobots_cflags=@ARGOBOTS_CFLAGS@ argobots_cflags=@ARGOBOTS_CFLAGS@
swm_libs=@SWM_LIBS@ swm_libs=@SWM_LIBS@
swm_cflags=@SWM_CFLAGS@ swm_cflags=@SWM_CFLAGS@
swm_datarootdir=@SWM_DATAROOTDIR@
Name: codes-base Name: codes-base
Description: Base functionality for CODES storage simulation Description: Base functionality for CODES storage simulation
...@@ -25,4 +26,4 @@ Version: @PACKAGE_VERSION@ ...@@ -25,4 +26,4 @@ Version: @PACKAGE_VERSION@
URL: http://trac.mcs.anl.gov/projects/CODES URL: http://trac.mcs.anl.gov/projects/CODES
Requires: Requires:
Libs: -L${libdir} -lcodes ${ross_libs} ${argobots_libs} ${swm_libs} ${darshan_libs} ${dumpi_libs} ${cortex_libs} Libs: -L${libdir} -lcodes ${ross_libs} ${argobots_libs} ${swm_libs} ${darshan_libs} ${dumpi_libs} ${cortex_libs}
Cflags: -I${includedir} ${swm_datarootdir} ${ross_cflags} ${darshan_cflags} ${swm_cflags} ${argobots_cflags} ${dumpi_cflags} ${cortex_cflags} Cflags: -I${includedir} -I${swm_datarootdir} ${ross_cflags} ${darshan_cflags} ${swm_cflags} ${argobots_cflags} ${dumpi_cflags} ${cortex_cflags}
...@@ -11,15 +11,8 @@ import sys ...@@ -11,15 +11,8 @@ import sys
from enum import Enum from enum import Enum
import struct import struct
import numpy as np import numpy as np
argv = sys.argv
import random import random
import os argv = sys.argv
import copy
class RandomError(Exception):
def __init__(self, message):
self.message = message
super().__init__(message)
class Loudness(Enum): class Loudness(Enum):
DEBUG = 0 #prints all output DEBUG = 0 #prints all output
...@@ -32,6 +25,7 @@ global DRYRUN ...@@ -32,6 +25,7 @@ global DRYRUN
global LOUDNESS global LOUDNESS
global SHOW_ADJACENCY global SHOW_ADJACENCY
global NO_OUTPUT_FILE global NO_OUTPUT_FILE
global TRUE_RANDOM
LOUDNESS = Loudness.STANDARD LOUDNESS = Loudness.STANDARD
DRYRUN = 0 DRYRUN = 0
...@@ -164,31 +158,34 @@ class DragonflyPlusNetwork(object): ...@@ -164,31 +158,34 @@ class DragonflyPlusNetwork(object):
def generateGlobalGroupConnections(self): def generateGlobalGroupConnections(self):
log("Dragonfly Plus Network: Generating Global Group Connections", Loudness.STANDARD) log("Dragonfly Plus Network: Generating Global Group Connections", Loudness.STANDARD)
pair_set = set()
for i in range(self.num_groups):
for j in range(self.num_groups):
if i != j:
pair_set.add(frozenset((i,j)))
for pair in pair_set:
groups = [-1,-1]
for i,group_id in enumerate(pair):
groups[i] = group_id
if groups[0] == -1 or groups[1] == -1:
raise Exception("DragonflyPlusNetwork: Bad Generation of Group Pairs")
group1 = self.groups[groups[0]]
group2 = self.groups[groups[1]]
for i in range(self.num_global_links_between_groups):
the_group_connection = GroupConnection(group1,group2)
group1.addGlobalConnection(the_group_connection)
group2.addGlobalConnection(the_group_connection)
for group in self.groups: for group in self.groups:
other_groups = group.getOtherGroupIDsStartingAfterMe(self.num_groups) group.assignRoutersToGlobalConnections()
for ogid in other_groups:
og = self.groups[ogid]
gcb = GroupConnectionBundle(group, og, self.num_global_links_between_groups)
group.groupConnBundles[ogid] = gcb
group_copy = copy.deepcopy(self.groups)
tries = 0
success = False
while success is False:
try:
group.assignGlobalConnectionsToRouters()
success = True
except RandomError:
tries += 1
self.groups = copy.deepcopy(group_copy)
if tries%20 == 0:
log("Failed after %d tries, trying again..."%tries, Loudness.STANDARD)
else:
log("Failed after %d tries, trying again..."%tries, Loudness.LOUD)
group.bakeGlobalConnections()
def getNumGlobalConnsPerSpine(self): def getNumGlobalConnsPerSpine(self):
...@@ -279,19 +276,15 @@ class DragonflyPlusNetwork(object): ...@@ -279,19 +276,15 @@ class DragonflyPlusNetwork(object):
if glob is not glob_conns: if glob is not glob_conns:
failed = True failed = True
if failed:
raise Exception("DragonflyPlusNetwork: Failed Verification: Fairness")
log("Verifying Dragonfly Nature...", Loudness.STANDARD) log("Verifying Dragonfly Nature...", Loudness.STANDARD)
for g in self.groups:
for gcb in g.groupConnBundles.values(): if failed:
if gcb.assigned_num_gc_between != self.num_global_links_between_groups: raise Exception("DragonflyPlusNetwork: Failed Verification: Fairness")
raise Exception("DragonflyPlusNetwork: Invalid number of connections between groups")
for g in self.groups: for g in self.groups:
if len(set(g.groupConns)) != self.num_global_links_pg: if len(set(g.groupConns)) != self.num_global_links_pg:
raise Exception("DragonflyPlusNetwork: Not Enough Group Connections for Group %d (%d != %d)"%(g.group_id,len(set(g.groupConns)), self.num_global_links_pg)) raise Exception("DragonflyPlusNetwork: Not Enough Group Connections")
log("Verifying Inter Group Connection Uniformity...", Loudness.STANDARD) log("Verifying Inter Group Connection Uniformity...", Loudness.STANDARD)
num_gc_between_0_1 = len(self.groups[0].getConnectionsToGroup(1)) num_gc_between_0_1 = len(self.groups[0].getConnectionsToGroup(1))
...@@ -299,7 +292,18 @@ class DragonflyPlusNetwork(object): ...@@ -299,7 +292,18 @@ class DragonflyPlusNetwork(object):
other_groups = g.getOtherGroupIDsStartingAfterMe(self.num_groups) other_groups = g.getOtherGroupIDsStartingAfterMe(self.num_groups)
for other_group_id in other_groups: for other_group_id in other_groups:
if len(g.getConnectionsToGroup(other_group_id)) != num_gc_between_0_1: if len(g.getConnectionsToGroup(other_group_id)) != num_gc_between_0_1:
raise Exception("DragonflyPlusNetwork: Failed Verification: InterGroup Connection Uniformity") raise Exception("DragonflyPlusNetwork: Failed Verification: InterGroup Connection Uniformity: %d != %d")
log("Verifying Number of Links Generated...", Loudness.STANDARD)
link_sum = 0
for row in A:
for item in row:
link_sum += item
if link_sum != (self.router_radix * ((self.num_leaf_pg + self.num_spine_pg)*self.num_groups)) - (self.num_leaf_pg * self.num_hosts_per_leaf * self.num_groups): #number of links per router - number of terminals (because those links weren't generated)
raise Exception("DragonflyPlusNetwork: Failed Verification: Number of links generated doesn't match expected")
def commitConnection(self,conn, connType): def commitConnection(self,conn, connType):
if connType is ConnType.LOCAL: if connType is ConnType.LOCAL:
...@@ -365,13 +369,20 @@ class Group(object): ...@@ -365,13 +369,20 @@ class Group(object):
self.network = network self.network = network
self.groupConns = [] self.groupConns = []
self.groupConnBundles = {}
def addRouter(self,router): def addRouter(self,router):
self.group_routers.append(router) self.group_routers.append(router)
self.used_radix += router.inter_radix self.used_radix += router.inter_radix
def addGlobalConnection(self, group_conn):
if group_conn.src_group == self:
other_group_id = group_conn.dest_group.group_id
else:
other_group_id = group_conn.src_group.group_id
log("Group %d -> Group %d" % (self.group_id, other_group_id), Loudness.LOUD)
self.groupConns.append(group_conn)
def getSpineRouters(self): def getSpineRouters(self):
return [r for r in self.group_routers if r.routerType is RouterType.SPINE] return [r for r in self.group_routers if r.routerType is RouterType.SPINE]
...@@ -379,45 +390,13 @@ class Group(object): ...@@ -379,45 +390,13 @@ class Group(object):
def getLeafRouters(self): def getLeafRouters(self):
return [r for r in self.group_routers if r.routerType is RouterType.LEAF] return [r for r in self.group_routers if r.
