Commit c7ff9d37 authored by Philip Carns's avatar Philip Carns
Kevin's configuration updates from CODES repo
parent 4fbef38d
...@@ -12,15 +12,6 @@ ...@@ -12,15 +12,6 @@
#include "lp-type-lookup.h" #include "lp-type-lookup.h"
#define MAX_NAME_LENGTH 256 #define MAX_NAME_LENGTH 256
/* number of LPs assigned to the current PE (abstraction of MPI rank) */
static int lps_for_this_pe = 0;
/* data structure to hold configuration */
configuration_t config;
/* char arrays for holding lp type name and group name*/
char local_grp_name[MAX_NAME_LENGTH], local_lp_name[MAX_NAME_LENGTH];
/* Returns number of LPs on the current PE */ /* Returns number of LPs on the current PE */
int codes_mapping_get_lps_for_pe(void); int codes_mapping_get_lps_for_pe(void);
...@@ -28,7 +19,7 @@ int codes_mapping_get_lps_for_pe(void); ...@@ -28,7 +19,7 @@ int codes_mapping_get_lps_for_pe(void);
tw_peid codes_mapping( tw_lpid gid); tw_peid codes_mapping( tw_lpid gid);
/* loads the configuration file and sets up the number of LPs on each PE. */ /* loads the configuration file and sets up the number of LPs on each PE. */
void codes_mapping_setup(char* filepath); void codes_mapping_setup(void);
/* Takes the group name , type name, rep ID and offset (for that lp type + repetition) and then returns the global LP ID. */ /* Takes the group name , type name, rep ID and offset (for that lp type + repetition) and then returns the global LP ID. */
void codes_mapping_get_lp_id(char* grp_name, char* lp_type_name, int rep_id, int offset, tw_lpid* gid); void codes_mapping_get_lp_id(char* grp_name, char* lp_type_name, int rep_id, int offset, tw_lpid* gid);
#ifndef __CONFIGURATION_H__ #ifndef __CONFIGURATION_H__
#define __CONFIGURATION_H__ #define __CONFIGURATION_H__
#include <stdint.h> #include <inttypes.h>
#include <stdlib.h> #include <mpi.h>
#include "codes/txt_configfile.h"
#define CONFIGURATION_MAX_NAME 256 #define CONFIGURATION_MAX_NAME 256
#define CONFIGURATION_MAX_GROUPS 10 #define CONFIGURATION_MAX_GROUPS 10
...@@ -22,13 +23,121 @@ typedef struct config_lpgroup_s ...@@ -22,13 +23,121 @@ typedef struct config_lpgroup_s
uint64_t lptypes_count; uint64_t lptypes_count;
} config_lpgroup_t; } config_lpgroup_t;
typedef struct configuration_s typedef struct config_lpgroups_s
config_lpgroup_t lpgroups[CONFIGURATION_MAX_GROUPS]; config_lpgroup_t lpgroups[CONFIGURATION_MAX_GROUPS];
uint64_t lpgroups_count; uint64_t lpgroups_count;
} configuration_t; } config_lpgroups_t;
int configuration_load (const char * filepath, configuration_t *config); /*
int configuration_dump (configuration_t *config); * Load a configuration on the system (collectively)
* filepath - path and name of file
* comm - communicator to distribute file on
* handle - output of configuration
* return 0 on success
MPI_Comm comm,
ConfigHandle *handle);
* Free any resources allocated on load.
* handle - configuration handle
int configuration_free (ConfigHandle *handle);
* Get's the value for a give section/key pair.
* Caller's responsible for transforming it to a useable type.
* Assumes the key name is a KEY configuration type.
* section_name - name of the section the key is in
* key_name - name of the key
* value - pointer to string
* length - maximum length of string
int configuration_get_value(ConfigHandle *handle,
const char * section_name,
const char * key_name,
char *value,
size_t length);
* Get's the value for a give section/key pair and converts it to an int.
* value - returned as a pointer to an integer
int configuration_get_value_int (ConfigHandle *handle,
const char *section_name,
const char *key_name,
int *value);
* unsigned int.
* value - returned as a pointer to an unsigned integer
int configuration_get_value_uint (ConfigHandle *handle,
unsigned int *value);
* Get's the value for a give section/key pair and converts it to a long int.
* value - returned as a pointer to a long integer
int configuration_get_value_longint (ConfigHandle *handle,
long int *value);
* Get's the value for a give section/key pair and converts it to a double.
* value - returned as a pointer to a double
int configuration_get_value_double (ConfigHandle *handle,
double *value);
* Get the LPGROUPS configuration from the config file which is stored
* in the associated data structures.
* section_name - name of section which has the lptypes
* lpgroups - data structure to hold the lpgroup info
int configuration_get_lpgroups (ConfigHandle *handle,
config_lpgroups_t *lpgroups);
* Forward reference to the configuration handle
extern ConfigHandle config;
#endif #endif
...@@ -9,6 +9,14 @@ ...@@ -9,6 +9,14 @@
#include "codes/codes_mapping.h" #include "codes/codes_mapping.h"
config_lpgroups_t lpconf;
int codes_mapping_get_lps_for_pe() int codes_mapping_get_lps_for_pe()
return lps_for_this_pe; return lps_for_this_pe;
...@@ -21,21 +29,20 @@ tw_peid codes_mapping( tw_lpid gid) ...@@ -21,21 +29,20 @@ tw_peid codes_mapping( tw_lpid gid)
/* This function loads the configuration file and sets up the number of LPs on each PE */ /* This function loads the configuration file and sets up the number of LPs on each PE */
void codes_mapping_setup(char* filepath) void codes_mapping_setup()
/* TODO: Add full file path? This one only runs from current directory */
configuration_load(filepath, &config);
configuration_dump(&config);
int grp, lpt; int grp, lpt;
int pes = tw_nnodes(); int pes = tw_nnodes();
for (grp = 0; grp < config.lpgroups_count; grp++) configuration_get_lpgroups(&config, "LPGROUPS", &lpconf);
for (grp = 0; grp < lpconf.lpgroups_count; grp++)
for (lpt = 0; lpt < config.lpgroups[grp].lptypes_count; lpt++) for (lpt = 0; lpt < lpconf.lpgroups[grp].lptypes_count; lpt++)
lps_for_this_pe += (config.lpgroups[grp].lptypes[lpt].count * config.lpgroups[grp].repetitions); lps_for_this_pe += (lpconf.lpgroups[grp].lptypes[lpt].count * lpconf.lpgroups[grp].repetitions);
lps_for_this_pe /= pes; lps_for_this_pe /= pes;
//printf("\n LPs for this PE are %d reps %d ", lps_for_this_pe, config.lpgroups[grp].repetitions); //printf("\n LPs for this PE are %d reps %d ", lps_for_this_pe, lpconf.lpgroups[grp].repetitions);
/* This function takes the group ID , type ID and rep ID then returns the global LP ID */ /* This function takes the group ID , type ID and rep ID then returns the global LP ID */
...@@ -46,32 +53,32 @@ void codes_mapping_get_lp_id(char* grp_name, char* lp_type_name, int rep_id, int ...@@ -46,32 +53,32 @@ void codes_mapping_get_lp_id(char* grp_name, char* lp_type_name, int rep_id, int
short found = 0; short found = 0;
// Account for all lps in the previous groups // Account for all lps in the previous groups
for(grp = 0; grp < config.lpgroups_count; grp++) for(grp = 0; grp < lpconf.lpgroups_count; grp++)
lp_types_count = config.lpgroups[grp].lptypes_count; lp_types_count = lpconf.lpgroups[grp].lptypes_count;
rep = config.lpgroups[grp].repetitions; rep = lpconf.lpgroups[grp].repetitions;
if(strcmp(config.lpgroups[grp].name, grp_name) == 0) if(strcmp(lpconf.lpgroups[grp].name, grp_name) == 0)
found = 1; found = 1;
break; break;
for(lpt = 0; lpt < lp_types_count; lpt++) for(lpt = 0; lpt < lp_types_count; lpt++)
lpcount += (rep * config.lpgroups[grp].lptypes[lpt].count); lpcount += (rep * lpconf.lpgroups[grp].lptypes[lpt].count);
assert(found); assert(found);
found = 0; found = 0;
// Account for the previous lp types in the current repetition // Account for the previous lp types in the current repetition
count_for_this_lpt = config.lpgroups[grp].lptypes[lpt].count; count_for_this_lpt = lpconf.lpgroups[grp].lptypes[lpt].count;
if(strcmp(config.lpgroups[grp].lptypes[lpt].name, lp_type_name) == 0) if(strcmp(lpconf.lpgroups[grp].lptypes[lpt].name, lp_type_name) == 0)
break; break;
...@@ -85,7 +92,7 @@ void codes_mapping_get_lp_id(char* grp_name, char* lp_type_name, int rep_id, int ...@@ -85,7 +92,7 @@ void codes_mapping_get_lp_id(char* grp_name, char* lp_type_name, int rep_id, int
for(rep = 0; rep < rep_id; rep++) for(rep = 0; rep < rep_id; rep++)
lpcount += config.lpgroups[grp].lptypes[lpt].count; lpcount += lpconf.lpgroups[grp].lptypes[lpt].count;
*gid = lpcount + offset; *gid = lpcount + offset;
...@@ -99,16 +106,16 @@ void codes_mapping_get_lp_info(tw_lpid gid, char* grp_name, int* grp_id, int* lp ...@@ -99,16 +106,16 @@ void codes_mapping_get_lp_info(tw_lpid gid, char* grp_name, int* grp_id, int* lp
/* Find the group id first */ /* Find the group id first */
grp_offset = 0; grp_offset = 0;
rep_offset = 0; rep_offset = 0;
lp_count = config.lpgroups[grp].lptypes[lpt].count; lp_count = lpconf.lpgroups[grp].lptypes[lpt].count;
grp_offset += (rep * lp_count); grp_offset += (rep * lp_count);
rep_offset += lp_count; rep_offset += lp_count;
...@@ -117,7 +124,7 @@ void codes_mapping_get_lp_info(tw_lpid gid, char* grp_name, int* grp_id, int* lp ...@@ -117,7 +124,7 @@ void codes_mapping_get_lp_info(tw_lpid gid, char* grp_name, int* grp_id, int* lp
if(gid >= grp_lp_count && gid < grp_lp_count + grp_offset) if(gid >= grp_lp_count && gid < grp_lp_count + grp_offset)
*grp_id = grp; *grp_id = grp;
strcpy(local_grp_name, config.lpgroups[grp].name); strcpy(local_grp_name, lpconf.lpgroups[grp].name);
lp_offset = gid - grp_lp_count; /* gets the lp offset starting from the point where the group begins */ lp_offset = gid - grp_lp_count; /* gets the lp offset starting from the point where the group begins */
*grp_rep_id = lp_offset / rep_offset; *grp_rep_id = lp_offset / rep_offset;
lp_tmp_id = lp_offset - (*grp_rep_id * rep_offset); lp_tmp_id = lp_offset - (*grp_rep_id * rep_offset);
...@@ -133,11 +140,11 @@ void codes_mapping_get_lp_info(tw_lpid gid, char* grp_name, int* grp_id, int* lp ...@@ -133,11 +140,11 @@ void codes_mapping_get_lp_info(tw_lpid gid, char* grp_name, int* grp_id, int* lp
/* Now we compute the LP type ID here based on the lp offset that we just got */ /* Now we compute the LP type ID here based on the lp offset that we just got */
if(lp_tmp_id >= lp_offset && lp_tmp_id < lp_offset + lp_count) if(lp_tmp_id >= lp_offset && lp_tmp_id < lp_offset + lp_count)
*lp_type_id = lpt; *lp_type_id = lpt;
strcpy(local_lp_name, config.lpgroups[grp].lptypes[lpt].name); strcpy(local_lp_name, lpconf.lpgroups[grp].lptypes[lpt].name);
*offset = lp_tmp_id - lp_offset; *offset = lp_tmp_id - lp_offset;
break; break;
#include <stdio.h>
#include <stdlib.h>
#include <string.h> #include <string.h>
#include <assert.h>
#include <errno.h>
#include "codes/configuration.h" #include "codes/configuration.h"
int configuration_load (const char *filepath, configuration_t *config) /*
* Global to hold configuration in memory
MPI_Comm comm,
MPI_File fh;
MPI_Status status;
MPI_Offset txtsize;
FILE *f;
char *txtdata;
char *error;
int rc;
rc = MPI_File_open(comm, (char*)filepath, MPI_MODE_RDONLY, MPI_INFO_NULL, &fh);
assert(rc == MPI_SUCCESS);
rc = MPI_File_get_size(fh, &txtsize);
txtdata = malloc(txtsize);
assert(txtdata);
rc = MPI_File_read_all(fh, txtdata, txtsize, MPI_BYTE, &status);
rc = MPI_File_close(&fh);
f = fmemopen(txtdata, txtsize, "rb");
assert(f);
*handle = txtfile_openStream(f, &error);
if (error)
fprintf(stderr, "config error: %s\n", error);
free(error);
rc = 1;
else
rc = 0;
fclose(f);
return rc;
char *value,
size_t len)
SectionHandle section_handle;
int rc;
rc = cf_openSection(*handle, ROOT_SECTION, section_name, &section_handle);
assert(rc == 1);
rc = cf_getKey(*handle, section_handle, key_name, value, len);
assert(rc);
(void) cf_closeSection(*handle, section_handle);
return rc;
int *value)
char valuestr[256];
int rc = 1;
int r;
r = configuration_get_value(handle,
section_name,
key_name,
valuestr,
sizeof(valuestr));
if (r > 0)
*value = atoi(valuestr);
rc = 0;
return rc;
char valuestr[256];
int rc = 1;
int r;
section_name,
key_name,
valuestr,
sizeof(valuestr));
if (r > 0)
*value = (unsigned int) atoi(valuestr);
rc = 0;
return rc;
long int *value)
char valuestr[256];
int rc = 1;
int r;
section_name,
key_name,
valuestr,
sizeof(valuestr));
if (r > 0)
errno = 0;
*value = strtol(valuestr, NULL, 10);
rc = errno;
return rc;
double *value)
char valuestr[256];
int rc = 1;
int r;
section_name,
key_name,
valuestr,
sizeof(valuestr));
if (r > 0)
errno = 0;
*value = strtod(valuestr, NULL);
rc = errno;
return rc;
char *errstr;
ConfigHandle ch;
SectionHandle sh; SectionHandle sh;
SectionHandle subsh; SectionHandle subsh;
SectionEntry se[10]; SectionEntry se[10];
...@@ -15,74 +184,51 @@ int configuration_load (const char *filepath, configuration_t *config) ...@@ -15,74 +184,51 @@ int configuration_load (const char *filepath, configuration_t *config)
int i, j, lpt; int i, j, lpt;
char data[256]; char data[256];
memset (config, 0, sizeof(*config)); memset (lpgroups, 0, sizeof(*lpgroups));
errstr = NULL;
ch = txtfile_openConfig(filepath, &errstr); cf_openSection(*handle, ROOT_SECTION, section_name, &sh);
cf_openSection(ch, ROOT_SECTION, "LPGROUPS", &sh); cf_listSection(*handle, sh, se, &se_count);
cf_listSection(ch, sh, se, &se_count);
for (i = 0; i < se_count; i++) for (i = 0; i < se_count; i++)
printf("section: %s type: %d\n", se[i].name, se[i].type); //printf("section: %s type: %d\n", se[i].name, se[i].type);
if (se[i].type == SE_SECTION) if (se[i].type == SE_SECTION)
subse_count = 10; subse_count = 10;
cf_openSection(ch, sh, se[i].name, &subsh); cf_openSection(*handle, sh, se[i].name, &subsh);
cf_listSection(ch, subsh, subse, &subse_count); cf_listSection(*handle, subsh, subse, &subse_count);
strncpy(config->lpgroups[i].name, se[i].name, strncpy(lpgroups->lpgroups[i].name, se[i].name,
CONFIGURATION_MAX_NAME); CONFIGURATION_MAX_NAME);
config->lpgroups[i].repetitions = 1; lpgroups->lpgroups[i].repetitions = 1;
config->lpgroups_count++; lpgroups->lpgroups_count++;
for (j = 0, lpt = 0; j < subse_count; j++) for (j = 0, lpt = 0; j < subse_count; j++)
if (subse[j].type == SE_KEY) if (subse[j].type == SE_KEY)
cf_getKey(ch, subsh, subse[j].name, data, sizeof(data)); cf_getKey(*handle, subsh, subse[j].name, data, sizeof(data));
printf("key: %s value: %s\n", subse[j].name, data); //printf("key: %s value: %s\n", subse[j].name, data);
if (strcmp("repetitions", subse[j].name) == 0) if (strcmp("repetitions", subse[j].name) == 0)
config->lpgroups[i].repetitions = atoi(data); lpgroups->lpgroups[i].repetitions = atoi(data);
// printf("\n Repetitions: %d ", config->lpgroups[i].repetitions); //printf("\n Repetitions: %ld ", lpgroups->lpgroups[i].repetitions);
else else
// assume these are lptypes and counts // assume these are lptypes and counts
strncpy(config->lpgroups[i].lptypes[lpt].name, strncpy(lpgroups->lpgroups[i].lptypes[lpt].name,
subse[j].name, subse[j].name,
sizeof(config->lpgroups[i].lptypes[lpt].name)); sizeof(lpgroups->lpgroups[i].lptypes[lpt].name));
config->lpgroups[i].lptypes[lpt].count = atoi(data); lpgroups->lpgroups[i].lptypes[lpt].count = atoi(data);
config->lpgroups[i].lptypes_count++; lpgroups->lpgroups[i].lptypes_count++;
lpt++; lpt++;
cf_closeSection(ch, subsh); cf_closeSection(*handle, subsh);
cf_closeSection(ch, sh); cf_closeSection(*handle, sh);
if (errstr) free(errstr);
return 0;
int grp;
int lpt;
for (grp = 0; grp < config->lpgroups_count; grp++)
printf("group: %s\n", config->lpgroups[grp].name);
printf("\trepetitions: %d\n", config->lpgroups[grp].repetitions);
for (lpt = 0; lpt < config->lpgroups[grp].lptypes_count; lpt++)
printf("\t%s: %ld\n",
config->lpgroups[grp].lptypes[lpt].name,
config->lpgroups[grp].lptypes[lpt].count);
return 0; return 0;
Markdown is supported
0% or
Please register or to comment
