Commit c7b1894a authored by Shane Snyder's avatar Shane Snyder
adding the mpi-replay tool to the tests/workload directory for replaying...
adding the mpi-replay tool to the tests/workload directory for replaying workloads from the codes workload api
parent db1ab1d2
check_PROGRAMS += tests/lp-io-test \ check_PROGRAMS += tests/lp-io-test \
tests/workload/codes-workload-test tests/workload/codes-workload-test \
tests/workload/codes-workload-mpi-replay
TESTS += tests/lp-io-test.sh \ TESTS += tests/lp-io-test.sh \
tests/workload/codes-workload-test.sh tests/workload/codes-workload-test.sh
...@@ -22,3 +23,7 @@ tests_workload_codes_workload_test_SOURCES = \ ...@@ -22,3 +23,7 @@ tests_workload_codes_workload_test_SOURCES = \
tests/workload/codes-workload-test-svr-lp.h \ tests/workload/codes-workload-test-svr-lp.h \
tests/workload/codes-workload-test-cn-lp.c \ tests/workload/codes-workload-test-cn-lp.c \
tests/workload/codes-workload-test-cn-lp.h tests/workload/codes-workload-test-cn-lp.h
tests_workload_codes_workload_mpi_replay_LDADD = $(testlib) ${ROSS_LIBS}
tests_workload_codes_workload_mpi_replay_LDFLAGS = ${ROSS_LDFLAGS}
tests_workload_codes_workload_mpi_replay_SOURCES = tests/workload/codes-workload-mpi-replay.c
This diff is collapsed.
Markdown is supported
0% or
Please register or to comment
