Commit c7518e55 authored by Misbah Mubarak's avatar Misbah Mubarak
Fixing terminal queue length
parent 8bb120e6
...@@ -559,6 +559,7 @@ static void dragonfly_report_stats() ...@@ -559,6 +559,7 @@ static void dragonfly_report_stats()
tw_stime avg_time, max_time; tw_stime avg_time, max_time;
int total_minimal_packets, total_nonmin_packets; int total_minimal_packets, total_nonmin_packets;
long long total_gen, total_rev_gen, total_arrive, total_rev_arrive;
MPI_Reduce( &total_hops, &avg_hops, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD); MPI_Reduce( &total_hops, &avg_hops, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &N_finished_packets, &total_finished_packets, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD); MPI_Reduce( &N_finished_packets, &total_finished_packets, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
MPI_Reduce( &N_finished_msgs, &total_finished_msgs, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD); MPI_Reduce( &N_finished_msgs, &total_finished_msgs, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_WORLD);
...@@ -575,6 +576,8 @@ static void dragonfly_report_stats() ...@@ -575,6 +576,8 @@ static void dragonfly_report_stats()
/* print statistics */ /* print statistics */
if(!g_tw_mynode) if(!g_tw_mynode)
// printf("\n Total generate %lld total generate rev %lld total arrive %ld reverse arrive %ld ", total_gen, total_rev_gen,
// arrive_count, arrive_rev_count);
printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us avg message size %lf bytes finished messages %ld \n", (float)avg_hops/total_finished_chunks, avg_time/(total_finished_packets*1000), max_time/1000, (float)total_msg_sz/N_finished_msgs, N_finished_msgs); printf(" Average number of hops traversed %f average message latency %lf us maximum message latency %lf us avg message size %lf bytes finished messages %ld \n", (float)avg_hops/total_finished_chunks, avg_time/(total_finished_packets*1000), max_time/1000, (float)total_msg_sz/N_finished_msgs, N_finished_msgs);
if(routing == ADAPTIVE || routing == PROG_ADAPTIVE) if(routing == ADAPTIVE || routing == PROG_ADAPTIVE)
printf("\n ADAPTIVE ROUTING STATS: %d percent chunks routed minimally %d percent chunks routed non-minimally completed packets %lld ", total_minimal_packets, total_nonmin_packets, total_finished_chunks); printf("\n ADAPTIVE ROUTING STATS: %d percent chunks routed minimally %d percent chunks routed non-minimally completed packets %lld ", total_minimal_packets, total_nonmin_packets, total_finished_chunks);
...@@ -986,9 +989,6 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, ...@@ -986,9 +989,6 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg,
void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
term_rev_ecount++;
term_ecount--;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
int num_chunks = msg->packet_size/s->params->chunk_size; int num_chunks = msg->packet_size/s->params->chunk_size;
...@@ -1021,8 +1021,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1021,8 +1021,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
/* generates packet at the current dragonfly compute node */ /* generates packet at the current dragonfly compute node */
void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg, void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg,
tw_lp * lp) { tw_lp * lp) {
term_ecount++;
tw_stime ts, nic_ts; tw_stime ts, nic_ts;
assert(lp->gid != msg->dest_terminal_id); assert(lp->gid != msg->dest_terminal_id);
...@@ -1123,6 +1122,7 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1123,6 +1122,7 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
s->terminal_length += s->params->chunk_size;
s->packet_counter--; s->packet_counter--;
s->vc_occupancy[0] -= s->params->chunk_size; s->vc_occupancy[0] -= s->params->chunk_size;
...@@ -1217,6 +1217,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1217,6 +1217,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0); cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0);
copy_terminal_list_entry(cur_entry, msg); copy_terminal_list_entry(cur_entry, msg);
delete_terminal_message_list(cur_entry); delete_terminal_message_list(cur_entry);
s->terminal_length -= s->params->chunk_size;
cur_entry = s->terminal_msgs[0]; cur_entry = s->terminal_msgs[0];
...@@ -1244,9 +1245,6 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1244,9 +1245,6 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
term_ecount--;
term_rev_ecount++;
if(msg->path_type == MINIMAL) if(msg->path_type == MINIMAL)
minimal_count--; minimal_count--;
...@@ -1361,7 +1359,6 @@ void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, t ...@@ -1361,7 +1359,6 @@ void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, t
void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
term_ecount++;
// NIC aggregation - should this be a separate function? // NIC aggregation - should this be a separate function?
// Trigger an event on receiving server // Trigger an event on receiving server
...@@ -2401,7 +2398,7 @@ void router_packet_send_rc(router_state * s, ...@@ -2401,7 +2398,7 @@ void router_packet_send_rc(router_state * s,
s->link_traffic[output_port] -= s->params->chunk_size; s->link_traffic[output_port] -= s->params->chunk_size;
create_prepend_to_terminal_message_list(s->pending_msgs[output_port], create_prepend_to_terminal_message_list(s->pending_msgs[output_port],
s->pending_msgs_tail[output_port], output_chan, msg); s->pending_msgs_tail[output_port], output_chan, msg);
if(routing == PROG_ADAPTIVE) if(routing == PROG_ADAPTIVE)
if(bf->c2) if(bf->c2)
Markdown is supported
0% or
Please register or to comment
