Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
c3f2c08e
Commit
c3f2c08e
authored
Mar 16, 2015
by
Jonathan Jenkins
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
uncrustify config and reformatting tool
parent
a28856ca
Changes
2
Expand all
Show whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
1652 additions
and
0 deletions
+1652
-0
reformat.sh
reformat.sh
+104
-0
uc-codes.cfg
uc-codes.cfg
+1548
-0
No files found.
reformat.sh
0 → 100755
View file @
c3f2c08e
#!/bin/bash
script_dir
cd
dirname
BASH_SOURCE
[0]
pwd
function
error
echo
"ERROR:
&2
exit
1
function
usage
cat
EOF
USAGE: reformat.sh [-x] [-i] [-c CFG] [-b FILE] {-a | FILE...}
-i: perform in-place (will ask to confirm if being done recursively)
-c CFG: use CFG as the uncrustify config (default:
$script_dir
/uc-codes.cfg)
-b FILE[,...]: add FILE to the blacklist of directories (in the form *FILE/*)
multiple files can be added by separating with commas
-a: perform recursively on all files ending in .c or .h
if -a not provided, then perform on all files passed in
-x: instead of formatting, check if output format is the same as input
EOF
function
build_blacklist
for
x
in
do
echo
-n
"-and -not -path
$x
done
function
getfiles
find
-name
.c
-or
-name
.h
build_blacklist
cfg
$script_dir
/uc-codes.cfg
which uncrustify
/dev/null 2>&1
error
"uncrustify not found"
do_inplace
no
do_recursive
no
do_check
no
blacklist
while
getopts
":ib:ax"
opt
do
case
$opt
in
i
do_inplace
yes
b
blacklist
cat
$OPTARG
sed
s/,/ /g
c
cfg
$OPTARG
a
do_recursive
yes
x
do_check
yes
usage
error
"invalid argument: -
$OPTARG
esac
done
shift
OPTIND-1
-e
$cfg
usage
error
"config file
$cfg
not found"
-gt
0
$do_recursive
yes
usage
error
"no file args expected in recursive mode"
-eq
0
$do_recursive
no
usage
error
"expected file args in non-recursive mode"
if
$do_recursive
yes
then
file_list
getfiles
$blacklist
else
file_list
fi
if
$do_recursive
yes
$do_inplace
yes
then
echo
-n
"Do recursive in-place reformat? (y/n) "
read
answer
$answer
"[^y].*"
echo
"...aborting reformat"
exit
1
fi
$do_inplace
yes
output_arg
"--replace"
output_arg
if
$do_check
yes
then
check_arg
--check
output_arg
echo
"checking format..."
else
check_arg
fi
function
echolines
for
x
in
do
echo
$x
done
echolines
$file_list
| uncrustify
$check_arg
-c
$cfg
$output_arg
-F
uc-codes.cfg
0 → 100644
View file @
c3f2c08e
This diff is collapsed.
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
