Commit bf248d0f authored by Misbah Mubarak's avatar Misbah Mubarak
Adding more statistics to dragonfly model
parent 2f6b3005
...@@ -74,6 +74,8 @@ struct terminal_message ...@@ -74,6 +74,8 @@ struct terminal_message
tw_stime saved_credit_time; tw_stime saved_credit_time;
tw_stime saved_collective_init_time; tw_stime saved_collective_init_time;
tw_stime saved_hist_start_time; tw_stime saved_hist_start_time;
tw_stime msg_start_time;
short saved_completed_chunks; short saved_completed_chunks;
int saved_hist_num; int saved_hist_num;
int saved_occupancy; int saved_occupancy;
...@@ -22,7 +22,6 @@ ...@@ -22,7 +22,6 @@
#define CREDIT_SIZE 8 #define CREDIT_SIZE 8
#define MEAN_PROCESS 1.0 #define MEAN_PROCESS 1.0
#define MAX_GEN_PACKETS 2000000
/* collective specific parameters */ /* collective specific parameters */
#define TREE_DEGREE 4 #define TREE_DEGREE 4
...@@ -185,6 +184,12 @@ struct terminal_state ...@@ -185,6 +184,12 @@ struct terminal_state
struct qhash_table *rank_tbl; struct qhash_table *rank_tbl;
uint64_t rank_tbl_pop; uint64_t rank_tbl_pop;
tw_stime total_msg_time;
long total_msg_size;
long finished_msgs;
char output_buf[512];
/* terminal event type (1-4) */ /* terminal event type (1-4) */
...@@ -385,6 +390,7 @@ static void copy_terminal_list_entry( terminal_message_list *cur_entry, ...@@ -385,6 +390,7 @@ static void copy_terminal_list_entry( terminal_message_list *cur_entry,
msg->packet_ID = cur_msg->packet_ID; msg->packet_ID = cur_msg->packet_ID;
strcpy(msg->category, cur_msg->category); strcpy(msg->category, cur_msg->category);
msg->final_dest_gid = cur_msg->final_dest_gid; msg->final_dest_gid = cur_msg->final_dest_gid;
msg->msg_start_time = msg->msg_start_time;
msg->sender_lp = cur_msg->sender_lp; msg->sender_lp = cur_msg->sender_lp;
msg->dest_terminal_id = cur_msg->dest_terminal_id; msg->dest_terminal_id = cur_msg->dest_terminal_id;
msg->src_terminal_id = cur_msg->src_terminal_id; msg->src_terminal_id = cur_msg->src_terminal_id;
...@@ -652,6 +658,10 @@ terminal_init( terminal_state * s, ...@@ -652,6 +658,10 @@ terminal_init( terminal_state * s,
s->router_id=(int)s->terminal_id / (s->params->num_routers/2); s->router_id=(int)s->terminal_id / (s->params->num_routers/2);
s->terminal_available_time = 0.0; s->terminal_available_time = 0.0;
s->packet_counter = 0; s->packet_counter = 0;
s->finished_msgs = 0;
s->total_msg_time = 0.0;
s->total_msg_size = 0;
s->num_vcs = 1; s->num_vcs = 1;
s->vc_occupancy = (int*)malloc(s->num_vcs * sizeof(int)); s->vc_occupancy = (int*)malloc(s->num_vcs * sizeof(int));
...@@ -832,6 +842,7 @@ static tw_stime dragonfly_packet_event( ...@@ -832,6 +842,7 @@ static tw_stime dragonfly_packet_event(
msg->sender_lp=req->src_lp; msg->sender_lp=req->src_lp;
msg->sender_mn_lp = sender->gid; msg->sender_mn_lp = sender->gid;
msg->packet_size = packet_size; msg->packet_size = packet_size;
msg->travel_start_time = tw_now(sender);
msg->remote_event_size_bytes = 0; msg->remote_event_size_bytes = 0;
msg->local_event_size_bytes = 0; msg->local_event_size_bytes = 0;
msg->type = T_GENERATE; msg->type = T_GENERATE;
...@@ -840,7 +851,8 @@ static tw_stime dragonfly_packet_event( ...@@ -840,7 +851,8 @@ static tw_stime dragonfly_packet_event(
msg->is_pull = req->is_pull; msg->is_pull = req->is_pull;
msg->pull_size = req->pull_size; msg->pull_size = req->pull_size;
msg->magic = terminal_magic_num; msg->magic = terminal_magic_num;
msg->msg_start_time = req->msg_start_time;
if(is_last_pckt) /* Its the last packet so pass in remote and local event information*/ if(is_last_pckt) /* Its the last packet so pass in remote and local event information*/
if(req->remote_event_size > 0) if(req->remote_event_size > 0)
...@@ -1004,7 +1016,6 @@ void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1004,7 +1016,6 @@ void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg,
num_chunks = 1; num_chunks = 1;
msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter; msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter;
msg->travel_start_time = tw_now(lp);
msg->my_N_hop = 0; msg->my_N_hop = 0;
msg->my_l_hop = 0; msg->my_l_hop = 0;
msg->my_g_hop = 0; msg->my_g_hop = 0;
...@@ -1215,19 +1226,37 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1215,19 +1226,37 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
struct qhash_head * hash_link = NULL; struct qhash_head * hash_link = NULL;
hash_link = qhash_search(s->rank_tbl, &key); hash_link = qhash_search(s->rank_tbl, &key);
if(bf->c8) if(bf->c1)
assert(hash_link); mn_stats* stat;
struct dfly_qhash_entry * tmp = NULL; stat = model_net_find_stats(msg->category, s->dragonfly_stats_array);
tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link); stat->recv_count--;
assert(tmp); stat->recv_bytes -= msg->packet_size;
tmp->remote_event_size = 0; stat->recv_time -= tw_now(lp) - msg->travel_start_time;
free(tmp->remote_event_data); N_finished_packets--;
dragonfly_total_time -= (tw_now(lp) - msg->travel_start_time);
total_hops -= msg->my_N_hop;
if(bf->c3)
dragonfly_max_latency = msg->saved_available_time;
if(bf->c8)
assert(hash_link);
assert(tmp);
if(bf->c7) if(bf->c7)
s->finished_msgs--;
s->total_msg_time -= (tw_now(lp) - msg->msg_start_time);
s->total_msg_size -= msg->total_size;
assert(!hash_link); assert(!hash_link);
void *m_data_src = model_net_method_get_edata(DRAGONFLY, msg); void *m_data_src = model_net_method_get_edata(DRAGONFLY, msg);
struct dfly_qhash_entry * d_entry = malloc(sizeof(struct dfly_qhash_entry)); struct dfly_qhash_entry * d_entry = malloc(sizeof(struct dfly_qhash_entry));
...@@ -1243,6 +1272,8 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1243,6 +1272,8 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
d_entry->remote_event_size = msg->saved_remote_esize; d_entry->remote_event_size = msg->saved_remote_esize;
qhash_add(s->rank_tbl, &key, &(d_entry->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry->hash_link));
int net_id = model_net_get_id(LP_METHOD_NM); int net_id = model_net_get_id(LP_METHOD_NM);
if(bf->c4) if(bf->c4)
...@@ -1269,19 +1300,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1269,19 +1300,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
tmp2->num_chunks--; tmp2->num_chunks--;
if(bf->c2) {
mn_stats* stat;
stat->recv_count--;
if(bf->c3)
msg->my_N_hop--; msg->my_N_hop--;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
...@@ -1299,6 +1317,9 @@ void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, t ...@@ -1299,6 +1317,9 @@ void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, t
struct codes_mctx mc_src = struct codes_mctx mc_src =
codes_mctx_set_global_direct(lp->gid); codes_mctx_set_global_direct(lp->gid);
model_net_set_msg_param(MN_MSG_PARAM_START_TIME, MN_MSG_PARAM_START_TIME_VAL, &(msg->msg_start_time));
model_net_event_mctx(net_id, &mc_src, &mc_dst, msg->category, model_net_event_mctx(net_id, &mc_src, &mc_dst, msg->category,
msg->sender_lp, msg->pull_size, ts, msg->sender_lp, msg->pull_size, ts,
remote_event_size, tmp_ptr, 0, NULL, lp); remote_event_size, tmp_ptr, 0, NULL, lp);
...@@ -1316,6 +1337,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1316,6 +1337,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
term_ecount++; term_ecount++;
bf->c1 = 0;
bf->c2 = 0; bf->c2 = 0;
bf->c4 = 0; bf->c4 = 0;
bf->c5 = 0; bf->c5 = 0;
...@@ -1384,13 +1406,13 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1384,13 +1406,13 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
/* If an entry does not exist then create one */ /* If an entry does not exist then create one */
if(!hash_link) if(!hash_link)
bf->c5 = 1;
d_entry->num_chunks = 1; d_entry->num_chunks = 1;
d_entry->key = key; d_entry->key = key;
d_entry->remote_event_data = NULL; d_entry->remote_event_data = NULL;
s->rank_tbl_pop++; s->rank_tbl_pop++;
bf->c5 = 1;
else { else {
/* if one exists already then update it*/ /* if one exists already then update it*/
...@@ -1406,6 +1428,11 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1406,6 +1428,11 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(tmp->num_chunks >= total_chunks) if(tmp->num_chunks >= total_chunks)
bf->c7 = 1; bf->c7 = 1;
s->finished_msgs++;
s->total_msg_time += (tw_now(lp) - msg->msg_start_time);
s->total_msg_size += msg->total_size;
if(msg->remote_event_size_bytes > 0) if(msg->remote_event_size_bytes > 0)
char * remote_data = malloc(msg->remote_event_size_bytes); char * remote_data = malloc(msg->remote_event_size_bytes);
...@@ -1415,8 +1442,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1415,8 +1442,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
else else
void *m_data = model_net_method_get_edata(DRAGONFLY, msg); void *m_data = model_net_method_get_edata(DRAGONFLY, msg);
assert(tmp->remote_event_size > 0); assert(tmp->remote_event_size > 0);
send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size); send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size);
msg->saved_remote_esize = tmp->remote_event_size; msg->saved_remote_esize = tmp->remote_event_size;
/* append remote event data to this message */ /* append remote event data to this message */
memcpy(m_data, tmp->remote_event_data, tmp->remote_event_size); memcpy(m_data, tmp->remote_event_data, tmp->remote_event_size);
...@@ -1431,7 +1458,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1431,7 +1458,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
msg->my_N_hop++; msg->my_N_hop++;
if(msg->chunk_id == num_chunks-1) if(msg->chunk_id == num_chunks-1)
bf->c2 = 1; bf->c1 = 1;
mn_stats* stat = model_net_find_stats(msg->category, s->dragonfly_stats_array); mn_stats* stat = model_net_find_stats(msg->category, s->dragonfly_stats_array);
stat->recv_count++; stat->recv_count++;
stat->recv_bytes += msg->packet_size; stat->recv_bytes += msg->packet_size;
...@@ -1446,7 +1473,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1446,7 +1473,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
msg->saved_available_time = dragonfly_max_latency; msg->saved_available_time = dragonfly_max_latency;
dragonfly_max_latency = tw_now( lp ) - msg->travel_start_time; dragonfly_max_latency = tw_now( lp ) - msg->travel_start_time;
if(!bf->c7 && msg->remote_event_size_bytes > 0) if(!bf->c7 && msg->remote_event_size_bytes > 0)
/* Retreive the remote event entry */ /* Retreive the remote event entry */
...@@ -1459,10 +1486,10 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1459,10 +1486,10 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
assert(tmp); assert(tmp);
tmp->remote_event_data = (void*)malloc(msg->remote_event_size_bytes); tmp->remote_event_data = (void*)malloc(msg->remote_event_size_bytes);
assert(tmp->remote_event_data);
tmp->remote_event_size = msg->remote_event_size_bytes; tmp->remote_event_size = msg->remote_event_size_bytes;
memcpy(tmp->remote_event_data, m_data_src, msg->remote_event_size_bytes); memcpy(tmp->remote_event_data, m_data_src, msg->remote_event_size_bytes);
// NIC aggregation - should this be a separate function? // NIC aggregation - should this be a separate function?
...@@ -1845,7 +1872,15 @@ dragonfly_terminal_final( terminal_state * s, ...@@ -1845,7 +1872,15 @@ dragonfly_terminal_final( terminal_state * s,
tw_lp * lp ) tw_lp * lp )
model_net_print_stats(lp->gid, s->dragonfly_stats_array); model_net_print_stats(lp->gid, s->dragonfly_stats_array);
int written = 0;
if(!s->terminal_id)
written = sprintf(s->output_buf, "# Format <LP id> <Terminal ID> <Avg Msg Size> <Avg Msg Time> <# Msgs finished>");
written += sprintf(s->output_buf + written, "%lu %lu %ld %lf %ld\n", lp->gid, s->terminal_id, s->total_msg_size, s->total_msg_time, s->finished_msgs);
lp_io_write(lp->gid, "dragonfly-msg-stats", written, s->output_buf);
if(s->terminal_msgs[0] != NULL) if(s->terminal_msgs[0] != NULL)
printf("[%lu] leftover terminal messages \n", lp->gid); printf("[%lu] leftover terminal messages \n", lp->gid);
...@@ -9,7 +9,7 @@ LPGROUPS ...@@ -9,7 +9,7 @@ LPGROUPS
PARAMS PARAMS
message_size="328"; message_size="336";
modelnet_order=( "loggp" ); modelnet_order=( "loggp" );
# scheduler options # scheduler options
modelnet_scheduler="fcfs-full"; modelnet_scheduler="fcfs-full";
...@@ -14,7 +14,7 @@ PARAMS ...@@ -14,7 +14,7 @@ PARAMS
modelnet_scheduler="fcfs"; modelnet_scheduler="fcfs";
# modelnet_scheduler="round-robin"; # modelnet_scheduler="round-robin";
n_dims="4"; n_dims="4";
dim_length="4,2,2,2"; dim_length="4,2,2,2";
link_bandwidth="2.0"; link_bandwidth="2.0";
...@@ -10,7 +10,7 @@ LPGROUPS ...@@ -10,7 +10,7 @@ LPGROUPS
PARAMS PARAMS
packet_size="512"; packet_size="512";
modelnet_order=( "simplenet" ); modelnet_order=( "simplenet" );
Markdown is supported
0% or
Please register or to comment
