Commit b879c8d2 authored by Jonathan Jenkins's avatar Jonathan Jenkins
fixup delay time calc - some traces don't have mpi-init
parent dd49374c
...@@ -29,6 +29,8 @@ static int rank_tbl_pop = 0; ...@@ -29,6 +29,8 @@ static int rank_tbl_pop = 0;
typedef struct rank_mpi_context typedef struct rank_mpi_context
int my_app_id; int my_app_id;
// whether we've seen an init op (needed for timing correctness)
int is_init;
int64_t my_rank; int64_t my_rank;
double last_op_time; double last_op_time;
double init_time; double init_time;
...@@ -180,22 +182,32 @@ static void dumpi_remove_next_op(void *mpi_op_array, struct codes_workload_op *m ...@@ -180,22 +182,32 @@ static void dumpi_remove_next_op(void *mpi_op_array, struct codes_workload_op *m
/* check for initialization and normalize reported time */
static inline void check_set_init_time(const dumpi_time *t, rank_mpi_context * my_ctx)
if (!my_ctx->is_init) {
my_ctx->is_init = 1;
my_ctx->init_time = time_to_ns_lf(t->start);
my_ctx->last_op_time = time_to_ns_lf(t->stop) - my_ctx->init_time;
/* introduce delay between operations: delay is the compute time NOT spent in MPI operations*/ /* introduce delay between operations: delay is the compute time NOT spent in MPI operations*/
void update_compute_time(const dumpi_time* time, rank_mpi_context* my_ctx) void update_compute_time(const dumpi_time* time, rank_mpi_context* my_ctx)
double start = time_to_ns_lf(time->start) - my_ctx->init_time; double start = time_to_ns_lf(time->start) - my_ctx->init_time;
double stop = time_to_ns_lf(time->stop) - my_ctx->init_time; double stop = time_to_ns_lf(time->stop) - my_ctx->init_time;
if((start - my_ctx->last_op_time) > DUMPI_IGNORE_DELAY) if((start - my_ctx->last_op_time) > DUMPI_IGNORE_DELAY)
struct codes_workload_op wrkld_per_rank; struct codes_workload_op wrkld_per_rank;
wrkld_per_rank.op_type = CODES_WK_DELAY; wrkld_per_rank.op_type = CODES_WK_DELAY;
wrkld_per_rank.start_time = my_ctx->last_op_time; wrkld_per_rank.start_time = my_ctx->last_op_time;
wrkld_per_rank.end_time = start; wrkld_per_rank.end_time = start;
wrkld_per_rank.u.delay.seconds = (start - my_ctx->last_op_time) / 1e9; wrkld_per_rank.u.delay.seconds = (start - my_ctx->last_op_time) / 1e9;
my_ctx->last_op_time = stop; dumpi_insert_next_op(my_ctx->dumpi_mpi_array, &wrkld_per_rank);
static int handleDUMPIInit( static int handleDUMPIInit(
...@@ -207,7 +219,7 @@ static int handleDUMPIInit( ...@@ -207,7 +219,7 @@ static int handleDUMPIInit(
void *uarg) void *uarg)
rank_mpi_context *myctx = (rank_mpi_context*)uarg; rank_mpi_context *myctx = (rank_mpi_context*)uarg;
myctx->init_time = time_to_ns_lf(wall->stop); check_set_init_time(wall, myctx);
return 0; return 0;
...@@ -215,6 +227,7 @@ int handleDUMPIIgnore(const void* prm, uint16_t thread, const dumpi_time *cpu, c ...@@ -215,6 +227,7 @@ int handleDUMPIIgnore(const void* prm, uint16_t thread, const dumpi_time *cpu, c
rank_mpi_context* myctx = (rank_mpi_context*)uarg; rank_mpi_context* myctx = (rank_mpi_context*)uarg;
update_compute_time(wall, myctx); update_compute_time(wall, myctx);
return 0; return 0;
...@@ -225,6 +238,7 @@ static void update_times_and_insert( ...@@ -225,6 +238,7 @@ static void update_times_and_insert(
const dumpi_time *t, const dumpi_time *t,
rank_mpi_context *ctx) rank_mpi_context *ctx)
check_set_init_time(t, ctx);
op->start_time = time_to_ns_lf(t->start) - ctx->init_time; op->start_time = time_to_ns_lf(t->start) - ctx->init_time;
op->end_time = time_to_ns_lf(t->stop) - ctx->init_time; op->end_time = time_to_ns_lf(t->stop) - ctx->init_time;
update_compute_time(t, ctx); update_compute_time(t, ctx);
...@@ -539,6 +553,7 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank) ...@@ -539,6 +553,7 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
my_ctx->my_rank = rank; my_ctx->my_rank = rank;
my_ctx->my_app_id = app_id; my_ctx->my_app_id = app_id;
my_ctx->last_op_time = 0.0; my_ctx->last_op_time = 0.0;
my_ctx->is_init = 0;
my_ctx->dumpi_mpi_array = dumpi_init_op_data(); my_ctx->dumpi_mpi_array = dumpi_init_op_data();
if(rank < 10) if(rank < 10)
Markdown is supported
0%
or
Please register or to comment
