Commit b69b148e authored by Misbah Mubarak's avatar Misbah Mubarak
Fixing format warnings in dragonfly-custom
parent 1c5ee457
...@@ -1990,7 +1990,7 @@ dragonfly_custom_terminal_final( terminal_state * s, ...@@ -1990,7 +1990,7 @@ dragonfly_custom_terminal_final( terminal_state * s,
s->finished_packets, (double)s->total_hops/s->finished_chunks, s->finished_packets, (double)s->total_hops/s->finished_chunks,
s->busy_time); s->busy_time);
lp_io_write(lp->gid, "dragonfly-msg-stats", written, s->output_buf); lp_io_write(lp->gid, (char*)"dragonfly-msg-stats", written, s->output_buf);
if(s->terminal_msgs[0] != NULL) if(s->terminal_msgs[0] != NULL)
printf("[%llu] leftover terminal messages \n", LLU(lp->gid)); printf("[%llu] leftover terminal messages \n", LLU(lp->gid));
...@@ -2041,7 +2041,7 @@ void dragonfly_custom_router_final(router_state * s, ...@@ -2041,7 +2041,7 @@ void dragonfly_custom_router_final(router_state * s,
written += sprintf(s->output_buf + written, " %lf", s->busy_time[d]); written += sprintf(s->output_buf + written, " %lf", s->busy_time[d]);
sprintf(s->output_buf + written, "\n"); sprintf(s->output_buf + written, "\n");
lp_io_write(lp->gid, "dragonfly-router-stats", written, s->output_buf); lp_io_write(lp->gid, (char*)"dragonfly-router-stats", written, s->output_buf);
written = 0; written = 0;
if(!s->router_id) if(!s->router_id)
...@@ -2059,7 +2059,7 @@ void dragonfly_custom_router_final(router_state * s, ...@@ -2059,7 +2059,7 @@ void dragonfly_custom_router_final(router_state * s,
written += sprintf(s->output_buf2 + written, " %lld", LLD(s->link_traffic[d])); written += sprintf(s->output_buf2 + written, " %lld", LLD(s->link_traffic[d]));
sprintf(s->output_buf2 + written, "\n"); sprintf(s->output_buf2 + written, "\n");
lp_io_write(lp->gid, "dragonfly-router-traffic", written, s->output_buf2); lp_io_write(lp->gid, (char*)"dragonfly-router-traffic", written, s->output_buf2);
static int get_intra_router(int src_router_id, int dest_router_id, int num_rtrs_per_grp) static int get_intra_router(int src_router_id, int dest_router_id, int num_rtrs_per_grp)
...@@ -2641,7 +2641,7 @@ router_packet_receive( router_state * s, ...@@ -2641,7 +2641,7 @@ router_packet_receive( router_state * s,
if(cur_chunk->msg.packet_ID == LLU(TRACK_PKT)) if(cur_chunk->msg.packet_ID == LLU(TRACK_PKT))
printf("\n Packet %llu arrived at router %ld next stop %ld final stop %ld local hops %d", cur_chunk->msg.packet_ID, s->router_id, next_stop, dest_router_id, cur_chunk->msg.my_l_hop); printf("\n Packet %llu arrived at router %u next stop %d final stop %d local hops %d", cur_chunk->msg.packet_ID, s->router_id, next_stop, dest_router_id, cur_chunk->msg.my_l_hop);
/* If the packet route has just changed to non-minimal with prog-adaptive /* If the packet route has just changed to non-minimal with prog-adaptive
* routing, we have to compute the next stop based on that */ * routing, we have to compute the next stop based on that */
int do_chan_selection = 0; int do_chan_selection = 0;
Markdown is supported
0% or
Please register or to comment
