Commit b653b2d9 authored by Noah Wolfe's avatar Noah Wolfe Committed by Nikhil
Minor Bug Fix
- Cleaned packet_generate()
- Fixed bug in decrementing terminal_length
parent 2f89192a
...@@ -1071,45 +1071,6 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg ...@@ -1071,45 +1071,6 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg
nic_ts = g_tw_lookahead + (num_chunks * s->params->cn_delay) + tw_rand_unif(lp->rng); nic_ts = g_tw_lookahead + (num_chunks * s->params->cn_delay) + tw_rand_unif(lp->rng);
// codes_mapping_get_lp_info(msg->final_dest_gid, lp_group_name, &mapping_grp_id,
// NULL, &mapping_type_id, NULL, &mapping_rep_id, &mapping_offset);
// msg->dest_terminal_id = (mapping_rep_id * (p->switch_radix[0] / 2)) +
// (mapping_offset % (p->switch_radix[0]/2));
/* //message for process on the same terminal
if(msg->dest_terminal_id == s->terminal_id) {
bf->c1 = 1;
model_net_method_idle_event(nic_ts - s->params->cn_delay * msg->packet_size, 0, lp);
// Trigger an event on receiving server
if(msg->remote_event_size_bytes)
void *tmp_ptr = model_net_method_get_edata(FATTREE, msg);
bf->c2 = 1;
ts = codes_local_latency(lp);
tw_event *e = tw_event_new(msg->final_dest_gid, ts, lp);
fattree_message* m = tw_event_data(e);
memcpy(m, tmp_ptr, msg->remote_event_size_bytes);
//printf("[%d] pack gen Send to %d\n", lp->gid, msg->final_dest_gid);
tw_event_send(e);
if(msg->local_event_size_bytes > 0)
tw_event* e_new;
fattree_message* m_new;
void* local_event;
bf->c3 = 1;
e_new = tw_event_new(msg->sender_lp, ts, lp);
m_new = tw_event_data(e_new);
local_event = (char*)model_net_method_get_edata(FATTREE, msg) +
msg->remote_event_size_bytes;
memcpy(m_new, local_event, msg->local_event_size_bytes);
tw_event_send(e_new);
return;
msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter; msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter;
// msg->dest_terminal_id = msg->final_dest_gid; // msg->dest_terminal_id = msg->final_dest_gid;
if(msg->packet_ID == LLU(TRACK_PKT)) if(msg->packet_ID == LLU(TRACK_PKT))
...@@ -1145,6 +1106,8 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg ...@@ -1145,6 +1106,8 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg
0, cur_chunk); 0, cur_chunk);
s->terminal_length += s->params->chunk_size; s->terminal_length += s->params->chunk_size;
// if(s->terminal_id == 1)
// printf("gene time:%5.6lf lp_id:%3llu terminal_length:%5d \n",tw_now(lp),LLU(lp->gid),s->terminal_length);
if(s->terminal_length < 2 * s->params->cn_vc_size) { if(s->terminal_length < 2 * s->params->cn_vc_size) {
model_net_method_idle_event(nic_ts, 0, lp); model_net_method_idle_event(nic_ts, 0, lp);
...@@ -1254,7 +1217,10 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1254,7 +1217,10 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg,
cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0); cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0);
//delete_fattree_message_list(cur_entry); //delete_fattree_message_list(cur_entry);
rc_stack_push(lp, cur_entry, free, s->st); rc_stack_push(lp, cur_entry, free, s->st);
s->terminal_length -= s->params->packet_size; s->terminal_length -= s->params->chunk_size;
// printf("send time:%5.6lf lp_id:%3llu terminal_length:%5d \n",tw_now(lp),LLU(lp->gid),s->terminal_length);
cur_entry = s->terminal_msgs[0]; cur_entry = s->terminal_msgs[0];
...@@ -2134,16 +2100,19 @@ void ft_terminal_rc_event_handler(ft_terminal_state * s, tw_bf * bf, ...@@ -2134,16 +2100,19 @@ void ft_terminal_rc_event_handler(ft_terminal_state * s, tw_bf * bf,
prepend_to_fattree_message_list(s->terminal_msgs, prepend_to_fattree_message_list(s->terminal_msgs,
s->terminal_msgs_tail, 0, cur_entry); s->terminal_msgs_tail, 0, cur_entry);
s->terminal_length += s->params->packet_size; s->terminal_length += s->params->packet_size;
if(s->terminal_id == 0)
printf("time:%lf terminal_length:%d \n",tw_now(lp),s->terminal_length);
if(bf->c3) { if(bf->c3) {
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
if(bf->c4) { if(bf->c4) {
s->in_send_loop = 1; s->in_send_loop = 1;
if(bf->c5) { /*if(bf->c5) {
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
s->issueIdle = 1; s->issueIdle = 1;
break; break;
...@@ -2284,6 +2253,7 @@ void switch_rc_event_handler(switch_state * s, tw_bf * bf, ...@@ -2284,6 +2253,7 @@ void switch_rc_event_handler(switch_state * s, tw_bf * bf,
prepend_to_fattree_message_list(s->pending_msgs, prepend_to_fattree_message_list(s->pending_msgs,
s->pending_msgs_tail, output_port, cur_entry); s->pending_msgs_tail, output_port, cur_entry);
Markdown is supported
0% or
Please register or to comment
