Commit b073000d authored by Shane Snyder's avatar Shane Snyder
Update codes-base build to use darshan-util.pc
parent 9a410d55
...@@ -100,16 +100,6 @@ if test "x${with_darshan}" != "x" ; then ...@@ -100,16 +100,6 @@ if test "x${with_darshan}" != "x" ; then
DARSHAN_CFLAGS=`PKG_CONFIG_PATH=${with_darshan}/lib/pkgconfig pkg-config darshan-util --cflags` DARSHAN_CFLAGS=`PKG_CONFIG_PATH=${with_darshan}/lib/pkgconfig pkg-config darshan-util --cflags`
AC_SUBST(DARSHAN_LIBS) AC_SUBST(DARSHAN_LIBS)
AC_SUBST(DARSHAN_CFLAGS) AC_SUBST(DARSHAN_CFLAGS)
# darshan_headers="${with_darshan}/include"
# AC_CHECK_FILE([$darshan_headers/darshan-logutils.h],
# AM_CONDITIONAL(USE_DARSHAN, true),
# AC_MSG_ERROR(Could not find darshan-logutils.h at: $darshan_headers))
# DARSHAN_CPPFLAGS="-DUSE_DARSHAN=1 -DDARSHAN_CONFIG_H=\\\"${with_darshan}/include/darshan-util-config.h\\\" -I${with_darshan}/include"
# DARSHAN_LDFLAGS="-L${with_darshan}/lib"
# DARSHAN_LIBS="-ldarshan-util -lz"
# AC_SUBST(DARSHAN_CPPFLAGS)
# AC_SUBST(DARSHAN_LDFLAGS)
# AC_SUBST(DARSHAN_LIBS)
else else
AM_CONDITIONAL(USE_DARSHAN, false) AM_CONDITIONAL(USE_DARSHAN, false)
fi fi
...@@ -6,13 +6,12 @@ ross_cflags=@ROSS_CFLAGS@ ...@@ -6,13 +6,12 @@ ross_cflags=@ROSS_CFLAGS@
ross_ldflags=@ROSS_LDFLAGS@ ross_ldflags=@ROSS_LDFLAGS@
ross_libs=@ROSS_LIBS@ ross_libs=@ROSS_LIBS@
darshan_libs=@DARSHAN_LIBS@ darshan_libs=@DARSHAN_LIBS@
darshan_cflags=@DARSHAN_CPPFLAGS@ darshan_cflags=@DARSHAN_CFLAGS@
darshan_ldflags=@DARSHAN_LDFLAGS@
Name: codes-base Name: codes-base
Description: Base functionality for CODES storage simulation Description: Base functionality for CODES storage simulation
Version: @CODES_BASE_VERSION@ Version: @CODES_BASE_VERSION@
URL: http://trac.mcs.anl.gov/projects/CODES URL: http://trac.mcs.anl.gov/projects/CODES
Requires: Requires:
Libs: -L${libdir} -lcodes-base ${ross_ldflags} ${ross_libs} ${darshan_ldflags} ${darshan_libs} Libs: -L${libdir} -lcodes-base ${ross_ldflags} ${ross_libs} ${darshan_libs}
Cflags: -I${includedir} ${ross_cflags} ${darshan_cflags} Cflags: -I${includedir} ${ross_cflags} ${darshan_cflags}
Markdown is supported
0% or
Please register or to comment
