GitLab maintenance scheduled for Tomorrow, 2020-03-31, from 17:00 to 18:00 CT - Services will be unavailable during this time.
Commit b0691ffb authored by Neil McGlohon's avatar Neil McGlohon
dragonfly dally allow qos to be optional
parent 06f3402d
......@@ -1425,10 +1425,10 @@ terminal_dally_init( terminal_state * s,
s->rev_events = 0;
rc_stack_create(&s->st);
s->vc_occupancy = (int*)calloc(num_qos_levels, sizeof(int));
s->vc_occupancy = (int*)calloc(num_qos_levels, sizeof(int)); //1 vc times the number of qos levels
s->last_buf_full = 0.0;
s->terminal_length = (int*)calloc(num_qos_levels, sizeof(int));
s->terminal_length = (int*)calloc(num_qos_levels, sizeof(int)); //1 vc times number of qos levels
/* Whether the virtual channel group is active or over-bw*/
s->qos_status = (int*)calloc(num_qos_levels, sizeof(int));
......@@ -4338,7 +4338,9 @@ static void router_packet_send_rc(router_state * s,
terminal_dally_message_list * cur_entry = (terminal_dally_message_list *)rc_stack_pop(s->st);
assert(cur_entry);
int vcg = get_vcg_from_category(&(cur_entry->msg));
int vcg = 0;
if(num_qos_levels > 1)
int msg_size = s->params->chunk_size;
if(cur_entry->msg.packet_size < s->params->chunk_size)
......@@ -4425,7 +4427,10 @@ router_packet_send( router_state * s,
s->last_buf_full[output_port] = 0.0;
int vcg = 0;
int to_terminal = 1, global = 0;
double delay = s->params->cn_delay;
double bandwidth = s->params->cn_bandwidth;
Markdown is supported
0% or
Please register or to comment
