Commit aa1d0d73 authored by Misbah Mubarak's avatar Misbah Mubarak
Bug fix in dragonfly reverse handler
parent f129da66
...@@ -25,5 +25,5 @@ PARAMS ...@@ -25,5 +25,5 @@ PARAMS
global_bandwidth="4.7"; global_bandwidth="4.7";
cn_bandwidth="5.25"; cn_bandwidth="5.25";
message_size="544"; message_size="544";
routing="adaptive"; routing="minimal";
...@@ -165,6 +165,7 @@ struct nw_message ...@@ -165,6 +165,7 @@ struct nw_message
short wait_completed; short wait_completed;
dumpi_req_id saved_matched_req; dumpi_req_id saved_matched_req;
struct codes_workload_op * op;
double saved_send_time; double saved_send_time;
double saved_recv_time; double saved_recv_time;
double saved_wait_time; double saved_wait_time;
...@@ -278,16 +279,6 @@ static tw_lpid rank_to_lpid(int rank) ...@@ -278,16 +279,6 @@ static tw_lpid rank_to_lpid(int rank)
return codes_mapping_get_lpid_from_relative(rank, NULL, "nw-lp", NULL, 0); return codes_mapping_get_lpid_from_relative(rank, NULL, "nw-lp", NULL, 0);
static void notify_posted_wait_rc(
nw_state* s, tw_bf * bf,
nw_message * m,
tw_lp * lp)
if(m->wait_completed > 0)
s->wait_op->num_completed--;
static int notify_posted_wait(nw_state* s, static int notify_posted_wait(nw_state* s,
tw_bf * bf, nw_message * m, tw_lp * lp, tw_bf * bf, nw_message * m, tw_lp * lp,
dumpi_req_id completed_req) dumpi_req_id completed_req)
...@@ -752,7 +743,10 @@ static tw_stime s_to_ns(tw_stime ns) ...@@ -752,7 +743,10 @@ static tw_stime s_to_ns(tw_stime ns)
static void update_completed_queue_rc(nw_state * s, tw_bf * bf, nw_message * m, tw_lp * lp) static void update_completed_queue_rc(nw_state * s, tw_bf * bf, nw_message * m, tw_lp * lp)
notify_posted_wait_rc(s, bf, m, lp); if(m->wait_completed > 0)
if(bf->c0) if(bf->c0)
struct qlist_head * ent = qlist_pop_back(&s->completed_reqs); struct qlist_head * ent = qlist_pop_back(&s->completed_reqs);
...@@ -781,7 +775,6 @@ static void update_completed_queue(nw_state* s, ...@@ -781,7 +775,6 @@ static void update_completed_queue(nw_state* s,
int waiting = notify_posted_wait(s, bf, m, lp, req_id); int waiting = notify_posted_wait(s, bf, m, lp, req_id);
/* 2 is for completed wait operations */
if(!waiting) if(!waiting)
bf->c0 = 1; bf->c0 = 1;
...@@ -990,8 +983,9 @@ void nw_test_event_handler(nw_state* s, tw_bf * bf, nw_message * m, tw_lp * lp) ...@@ -990,8 +983,9 @@ void nw_test_event_handler(nw_state* s, tw_bf * bf, nw_message * m, tw_lp * lp)
static void get_next_mpi_operation_rc(nw_state* s, tw_bf * bf, nw_message * m, tw_lp * lp) static void get_next_mpi_operation_rc(nw_state* s, tw_bf * bf, nw_message * m, tw_lp * lp)
struct codes_workload_op * mpi_op = (struct codes_workload_op *)rc_stack_pop(s->processed_ops); // struct codes_workload_op * mpi_op = (struct codes_workload_op *)rc_stack_pop(s->processed_ops);
struct codes_workload_op * mpi_op = m->op;
codes_workload_get_next_rc(wrkld_id, 0, (int)s->nw_id, mpi_op); codes_workload_get_next_rc(wrkld_id, 0, (int)s->nw_id, mpi_op);
if(mpi_op->op_type == CODES_WK_END) if(mpi_op->op_type == CODES_WK_END)
...@@ -1044,14 +1038,20 @@ static void get_next_mpi_operation_rc(nw_state* s, tw_bf * bf, nw_message * m, t ...@@ -1044,14 +1038,20 @@ static void get_next_mpi_operation_rc(nw_state* s, tw_bf * bf, nw_message * m, t
break; break;
case CODES_WK_WAITSOME:
case CODES_WK_WAITANY:
s->num_waitsome--;
codes_issue_next_event_rc(lp);
break;
case CODES_WK_WAIT: case CODES_WK_WAIT:
s->num_wait--; s->num_wait--;
codes_exec_mpi_wait_rc(s, lp, mpi_op); codes_exec_mpi_wait_rc(s, lp, mpi_op);
break; break;
case CODES_WK_WAITALL: case CODES_WK_WAITALL:
s->num_waitall--; s->num_waitall--;
...@@ -1069,12 +1069,12 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l ...@@ -1069,12 +1069,12 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l
struct codes_workload_op * mpi_op = malloc(sizeof(struct codes_workload_op)); struct codes_workload_op * mpi_op = malloc(sizeof(struct codes_workload_op));
codes_workload_get_next(wrkld_id, 0, (int)s->nw_id, mpi_op); codes_workload_get_next(wrkld_id, 0, (int)s->nw_id, mpi_op);
//m->op = mpi_op; m->op = mpi_op;
s->elapsed_time = tw_now(lp) - s->start_time; s->elapsed_time = tw_now(lp) - s->start_time;
rc_stack_push(lp, mpi_op, free, s->processed_ops); //rc_stack_push(lp, mpi_op, free, s->processed_ops);
return; return;
switch(mpi_op->op_type) switch(mpi_op->op_type)
...@@ -1104,6 +1104,12 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l ...@@ -1104,6 +1104,12 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l
case CODES_WK_WAITSOME: case CODES_WK_WAITSOME:
case CODES_WK_WAITANY: case CODES_WK_WAITANY:
s->num_waitsome++;
codes_issue_next_event(lp);
break;
s->num_waitall++; s->num_waitall++;
...@@ -1132,7 +1138,7 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l ...@@ -1132,7 +1138,7 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l
default: default:
printf("\n Invalid op type %d ", mpi_op->op_type); printf("\n Invalid op type %d ", mpi_op->op_type);
rc_stack_push(lp, mpi_op, free, s->processed_ops); // rc_stack_push(lp, mpi_op, free, s->processed_ops);
return; return;
...@@ -1002,6 +1002,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1002,6 +1002,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
for(i = 0; i < num_chunks; i++) { for(i = 0; i < num_chunks; i++) {
delete_terminal_message_list(return_tail(s->terminal_msgs, delete_terminal_message_list(return_tail(s->terminal_msgs,
s->terminal_msgs_tail, 0)); s->terminal_msgs_tail, 0));
s->terminal_length -= s->params->chunk_size;
if(bf->c5) { if(bf->c5) {
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
...@@ -1116,8 +1117,8 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1116,8 +1117,8 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
return; return;
s->terminal_available_time = msg->saved_available_time;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
if(bf->c2) { if(bf->c2) {
...@@ -1252,8 +1253,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1252,8 +1253,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
if(msg->path_type == NON_MINIMAL) if(msg->path_type == NON_MINIMAL)
nonmin_count--; nonmin_count--;
uint64_t num_chunks = msg->packet_size / s->params->chunk_size;
N_finished_chunks--; N_finished_chunks--;
total_hops -= msg->my_N_hop; total_hops -= msg->my_N_hop;
...@@ -1313,6 +1312,7 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1313,6 +1312,7 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
stat->recv_time = msg->saved_start_time; stat->recv_time = msg->saved_start_time;
s->total_msg_time = msg->saved_start_time; s->total_msg_time = msg->saved_start_time;
s->total_msg_size -= msg->total_size; s->total_msg_size -= msg->total_size;
dragonfly_total_time = msg->saved_avg_time; dragonfly_total_time = msg->saved_avg_time;
...@@ -1320,8 +1320,8 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1320,8 +1320,8 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link));
s->rank_tbl_pop++; s->rank_tbl_pop++;
hash_link = &(d_entry_pop->hash_link); hash_link = qhash_search(s->rank_tbl, &key);
tmp = d_entry_pop; tmp = qhash_entry(hash_link, struct dfly_qhash_entry, hash_link);
if(bf->c4) if(bf->c4)
model_net_event_rc2(lp, &msg->event_rc); model_net_event_rc2(lp, &msg->event_rc);
...@@ -1531,6 +1531,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1531,6 +1531,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
N_finished_msgs++; N_finished_msgs++;
total_msg_sz += msg->total_size; total_msg_sz += msg->total_size;
s->total_msg_size += msg->total_size;
msg->saved_avg_time = dragonfly_total_time; msg->saved_avg_time = dragonfly_total_time;
dragonfly_total_time += tw_now( lp ) - msg->travel_start_time; dragonfly_total_time += tw_now( lp ) - msg->travel_start_time;
...@@ -1538,9 +1539,10 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1538,9 +1539,10 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
msg->saved_start_time = s->total_msg_time; msg->saved_start_time = s->total_msg_time;
stat->recv_time += (tw_now(lp) - msg->msg_start_time); stat->recv_time += (tw_now(lp) - msg->msg_start_time);
/*if(!s->terminal_id)
printf("\n Forward message time %lf ", s->total_msg_time);
s->total_msg_time += (tw_now(lp) - msg->msg_start_time); s->total_msg_time += (tw_now(lp) - msg->msg_start_time);
s->finished_msgs++; s->finished_msgs++;
if (dragonfly_max_latency < tw_now( lp ) - msg->travel_start_time) { if (dragonfly_max_latency < tw_now( lp ) - msg->travel_start_time) {
...@@ -2181,8 +2183,8 @@ static int do_adaptive_routing( router_state * s, ...@@ -2181,8 +2183,8 @@ static int do_adaptive_routing( router_state * s,
int min_port_count = s->vc_occupancy[minimal_out_port][min_vc]; int min_port_count = s->vc_occupancy[minimal_out_port][min_vc];
// Now get the expected number of hops to be traversed for both routes // Now get the expected number of hops to be traversed for both routes
//int num_min_hops = get_num_hops(s->router_id, dest_router_id, int num_min_hops = get_num_hops(s->router_id, dest_router_id,
// s->params->num_routers, 0, s->params->num_groups); s->params->num_routers, 0, s->params->num_groups);
int intm_router_id = getRouterFromGroupID(intm_id, int intm_router_id = getRouterFromGroupID(intm_id,
s->router_id / s->params->num_routers, s->params->num_routers, s->router_id / s->params->num_routers, s->params->num_routers,
...@@ -2196,7 +2198,7 @@ static int do_adaptive_routing( router_state * s, ...@@ -2196,7 +2198,7 @@ static int do_adaptive_routing( router_state * s,
assert(num_nonmin_hops <= 6); assert(num_nonmin_hops <= 6);
/* average the local queues of the router */ /* average the local queues of the router */
/*unsigned int q_avg = 0; unsigned int q_avg = 0;
int i; int i;
for( i = 0; i < s->params->radix; i++) for( i = 0; i < s->params->radix; i++)
...@@ -2205,21 +2207,21 @@ static int do_adaptive_routing( router_state * s, ...@@ -2205,21 +2207,21 @@ static int do_adaptive_routing( router_state * s,
s->vc_occupancy[i][2]; s->vc_occupancy[i][2];
q_avg = q_avg / (s->params->radix - 1); q_avg = q_avg / (s->params->radix - 1);
//int min_out_chan = minimal_out_port; int min_out_chan = minimal_out_port;
//int nonmin_out_chan = nonmin_out_port; int nonmin_out_chan = nonmin_out_port;
/* Adding history window approach, not taking the queue status at every /* Adding history window approach, not taking the queue status at every
* simulation time thats why, we are maintaining the current history * simulation time thats why, we are maintaining the current history
* window number and an average of the previous history window number. */ * window number and an average of the previous history window number. */
//int min_hist_count = s->cur_hist_num[min_out_chan] + int min_hist_count = s->cur_hist_num[min_out_chan] +
// (s->prev_hist_num[min_out_chan]/2); (s->prev_hist_num[min_out_chan]/2);
//int nonmin_hist_count = s->cur_hist_num[nonmin_out_chan] + int nonmin_hist_count = s->cur_hist_num[nonmin_out_chan] +
int nonmin_port_count = s->vc_occupancy[nonmin_out_port][nomin_vc]; int nonmin_port_count = s->vc_occupancy[nonmin_out_port][nomin_vc];
//if(num_min_hops * (min_port_count - min_hist_count) <= (num_nonmin_hops * ((q_avg + 1) - nonmin_hist_count))) { if(num_min_hops * (min_port_count - min_hist_count) <= (num_nonmin_hops * ((q_avg + 1) - nonmin_hist_count))) {
if(min_port_count <= nonmin_port_count) { //if(min_port_count <= nonmin_port_count) {
msg->path_type = MINIMAL; msg->path_type = MINIMAL;
next_stop = minimal_next_stop; next_stop = minimal_next_stop;
msg->intm_group_id = -1; msg->intm_group_id = -1;
...@@ -2402,6 +2404,17 @@ void router_packet_send_rc(router_state * s, ...@@ -2402,6 +2404,17 @@ void router_packet_send_rc(router_state * s,
create_prepend_to_terminal_message_list(s->pending_msgs[output_port], create_prepend_to_terminal_message_list(s->pending_msgs[output_port],
s->pending_msgs_tail[output_port], output_chan, msg); s->pending_msgs_tail[output_port], output_chan, msg);
if(routing == PROG_ADAPTIVE)
if(bf->c2)
s->cur_hist_num[output_port] = s->prev_hist_num[output_port];
s->prev_hist_num[output_port] = msg->saved_hist_num;
s->cur_hist_start_time[output_port] = msg->saved_hist_start_time;
else
s->cur_hist_num[output_port]--;
if(bf->c3) { if(bf->c3) {
...@@ -2410,17 +2423,6 @@ void router_packet_send_rc(router_state * s, ...@@ -2410,17 +2423,6 @@ void router_packet_send_rc(router_state * s,
s->in_send_loop[output_port] = 1; s->in_send_loop[output_port] = 1;
if(bf->c2)
s->cur_hist_num[output_chan] = s->prev_hist_num[output_chan];
s->prev_hist_num[output_chan] = msg->saved_hist_num;
s->cur_hist_start_time[output_chan] = msg->saved_hist_start_time;
else
s->cur_hist_num[output_chan]--;
/* routes the current packet to the next stop */ /* routes the current packet to the next stop */
void void
...@@ -2508,6 +2510,7 @@ router_packet_send( router_state * s, ...@@ -2508,6 +2510,7 @@ router_packet_send( router_state * s,
if(routing == PROG_ADAPTIVE) if(routing == PROG_ADAPTIVE)
if(tw_now(lp) - s->cur_hist_start_time[output_port] >= WINDOW_LENGTH) { if(tw_now(lp) - s->cur_hist_start_time[output_port] >= WINDOW_LENGTH) {
bf->c2 = 1;
s->prev_hist_num[output_port] = s->cur_hist_num[output_port]; s->prev_hist_num[output_port] = s->cur_hist_num[output_port];
s->cur_hist_start_time[output_port] = tw_now(lp); s->cur_hist_start_time[output_port] = tw_now(lp);
s->cur_hist_num[output_port] = 1; s->cur_hist_num[output_port] = 1;
...@@ -2549,9 +2552,7 @@ router_packet_send( router_state * s, ...@@ -2549,9 +2552,7 @@ router_packet_send( router_state * s,
} else { } else {
bf->c4 = 1; bf->c4 = 1;
s->in_send_loop[output_port] = 0; s->in_send_loop[output_port] = 0;
//printf("[%d] Router skipping send at end %d\n", lp->gid, output_port);
return; return;
Markdown is supported
0% or
Please register or to comment
