Commit a4ef8e74 authored by Noah Wolfe's avatar Noah Wolfe
adding bisection workload to ftree synthetic
parent 585499b5
...@@ -72,8 +72,9 @@ enum svr_event ...@@ -72,8 +72,9 @@ enum svr_event
enum TRAFFIC enum TRAFFIC
UNIFORM = 1, /* sends message to a randomly selected node */ UNIFORM = 1, /* sends message to a randomly selected node */
NEAREST_GROUP = 2, /* sends message to the node connected to the neighboring router */ BISECTION = 2, /* sends messages to node established in bisection pairing*/
NEAREST_NEIGHBOR = 3 /* sends message to the next node (potentially connected to the same router) */ NEAREST_GROUP = 3, /* sends message to the node connected to the neighboring router */
NEAREST_NEIGHBOR = 4 /* sends message to the next node (potentially connected to the same router) */
struct svr_state struct svr_state
...@@ -171,7 +172,7 @@ void ft_svr_register_model_stats() ...@@ -171,7 +172,7 @@ void ft_svr_register_model_stats()
const tw_optdef app_opt [] = const tw_optdef app_opt [] =
TWOPT_GROUP("Model net synthetic traffic " ), TWOPT_GROUP("Model net synthetic traffic " ),
TWOPT_UINT("traffic", traffic, "UNIFORM RANDOM=1, NEAREST NEIGHBOR=2 "), TWOPT_UINT("traffic", traffic, "UNIFORM RANDOM=1, BISECTION=2 "),
TWOPT_STIME("arrival_time", arrival_time, "INTER-ARRIVAL TIME"), TWOPT_STIME("arrival_time", arrival_time, "INTER-ARRIVAL TIME"),
TWOPT_STIME("load", load, "percentage of terminal link bandiwdth to inject packets"), TWOPT_STIME("load", load, "percentage of terminal link bandiwdth to inject packets"),
TWOPT_END() TWOPT_END()
...@@ -281,16 +282,23 @@ static void handle_kickoff_event( ...@@ -281,16 +282,23 @@ static void handle_kickoff_event(
ns->start_ts = tw_now(lp); ns->start_ts = tw_now(lp);
codes_mapping_get_lp_info(lp->gid, group_name, &group_index, lp_type_name, &lp_type_index, anno, &rep_id, &offset); codes_mapping_get_lp_info(lp->gid, group_name, &group_index, lp_type_name, &lp_type_index, anno, &rep_id, &offset);
int local_id = codes_mapping_get_lp_relative_id(lp->gid, 0, 0);
/* in case of uniform random traffic, send to a random destination. */ /* in case of uniform random traffic, send to a random destination. */
if(traffic == UNIFORM) if(traffic == UNIFORM)
local_dest = tw_rand_integer(lp->rng, 0, num_nodes - 1); local_dest = tw_rand_integer(lp->rng, 0, num_nodes - 1);
if(traffic == BISECTION)
local_dest = (local_id + num_nodes/2) % num_nodes;
assert(local_dest < LLU(num_nodes)); assert(local_dest < LLU(num_nodes));
global_dest = codes_mapping_get_lpid_from_relative(local_dest, group_name, lp_type_name, NULL, 0); global_dest = codes_mapping_get_lpid_from_relative(local_dest, group_name, lp_type_name, NULL, 0);
//printf("global_src:%d, local_src:%d, global_dest:%d, local_dest:%d num_nodes:%d \n",(int)lp->gid, local_id, (int)global_dest,(int)local_dest, num_nodes);
// If Destination is self, then generate new destination // If Destination is self, then generate new destination
if((int)global_dest == (int)lp->gid) if((int)global_dest == (int)lp->gid)
...@@ -298,14 +306,6 @@ static void handle_kickoff_event( ...@@ -298,14 +306,6 @@ static void handle_kickoff_event(
int div1 = floor((int)lp->gid/11);
int mult1 = div1 * 4;
int mod1 = (int)lp->gid % 11;
int sum1 = mult1 + mod1;
// if((int)lp->gid == 3)
printf("global_src:%d, local_src:%d, global_dest:%d, local_dest:%d\n",(int)lp->gid, sum1, (int)global_dest,(int)local_dest);
ns->msg_sent_count++; ns->msg_sent_count++;
model_net_event(net_id, "test", global_dest, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp); model_net_event(net_id, "test", global_dest, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp);
Markdown is supported
0% or
Please register or to comment
