Commit 9d3b2da6 authored by Noah Wolfe's avatar Noah Wolfe
Changes made to codes files to integrate the Fat Tree model into the compilation and execution.
parent ee617f8d
...@@ -61,6 +61,7 @@ typedef struct mn_stats mn_stats; ...@@ -61,6 +61,7 @@ typedef struct mn_stats mn_stats;
X(SIMPLEP2P, "modelnet_simplep2p", "simplep2p", &simplep2p_method)\ X(SIMPLEP2P, "modelnet_simplep2p", "simplep2p", &simplep2p_method)\
X(TORUS, "modelnet_torus", "torus", &torus_method)\ X(TORUS, "modelnet_torus", "torus", &torus_method)\
X(SLIMFLY, "modelnet_slimfly", "slimfly", &slimfly_method)\ X(SLIMFLY, "modelnet_slimfly", "slimfly", &slimfly_method)\
X(FATTREE, "modelnet_fattree", "fattree", &fattree_method)\
X(DRAGONFLY, "modelnet_dragonfly", "dragonfly", &dragonfly_method)\ X(DRAGONFLY, "modelnet_dragonfly", "dragonfly", &dragonfly_method)\
X(DRAGONFLY_ROUTER, "modelnet_dragonfly_router", "dragonfly_router", &dragonfly_router_method)\ X(DRAGONFLY_ROUTER, "modelnet_dragonfly_router", "dragonfly_router", &dragonfly_router_method)\
X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\ X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\
...@@ -25,6 +25,7 @@ EXTRA_DIST += src/iokernellang/codesparser.y.in \ ...@@ -25,6 +25,7 @@ EXTRA_DIST += src/iokernellang/codesparser.y.in \
src/network-workloads/conf/allocation-random.conf \ src/network-workloads/conf/allocation-random.conf \
src/network-workloads/conf/modelnet-synthetic-dragonfly.conf \ src/network-workloads/conf/modelnet-synthetic-dragonfly.conf \
src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf \ src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf \
src/network-workloads/conf/modelnet-synthetic-fattree.conf \
src/networks/model-net/doc/README \ src/networks/model-net/doc/README \
src/networks/model-net/doc/README.dragonfly.txt \ src/networks/model-net/doc/README.dragonfly.txt \
src/networks/model-net/doc/README.loggp.txt \ src/networks/model-net/doc/README.loggp.txt \
...@@ -88,6 +89,7 @@ nobase_include_HEADERS = \ ...@@ -88,6 +89,7 @@ nobase_include_HEADERS = \
codes/model-net-inspect.h \ codes/model-net-inspect.h \
codes/net/dragonfly.h \ codes/net/dragonfly.h \
codes/net/slimfly.h \ codes/net/slimfly.h \
codes/net/fattree.h \
codes/net/loggp.h \ codes/net/loggp.h \
codes/net/simplenet-upd.h \ codes/net/simplenet-upd.h \
codes/net/simplep2p.h \ codes/net/simplep2p.h \
...@@ -148,6 +150,7 @@ src_libcodes_a_SOURCES = \ ...@@ -148,6 +150,7 @@ src_libcodes_a_SOURCES = \
src/networks/model-net/torus.c \ src/networks/model-net/torus.c \
src/networks/model-net/dragonfly.c \ src/networks/model-net/dragonfly.c \
src/networks/model-net/slimfly.c \ src/networks/model-net/slimfly.c \
src/networks/model-net/fattree.c \
src/networks/model-net/loggp.c \ src/networks/model-net/loggp.c \
src/networks/model-net/simplep2p.c \ src/networks/model-net/simplep2p.c \
src/networks/model-net/model-net-lp.c \ src/networks/model-net/model-net-lp.c \
...@@ -22,6 +22,7 @@ extern struct model_net_method simplep2p_method; ...@@ -22,6 +22,7 @@ extern struct model_net_method simplep2p_method;
extern struct model_net_method torus_method; extern struct model_net_method torus_method;
extern struct model_net_method dragonfly_method; extern struct model_net_method dragonfly_method;
extern struct model_net_method slimfly_method; extern struct model_net_method slimfly_method;
extern struct model_net_method fattree_method;
extern struct model_net_method dragonfly_router_method; extern struct model_net_method dragonfly_router_method;
extern struct model_net_method loggp_method; extern struct model_net_method loggp_method;
Markdown is supported
0%
or
Please register or to comment
